8281 0041000
8281 0041000
    BELDEN
    75 OHM VIDEO COAX
8281 0041000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8281 Coax - Double Braided RG-59/U Type For more Information please call 1-800-Belden1 General Description: 20 AWG solid .031" bare copper conductor, polyethylene insulation, tinned copper/bare copper double braid shield (95% coverage), polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 20 Solid BC - Bare Copper .031 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) PE - Polyethylene .198 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Braid TC - Tinned Copper 95.000 2 Braid TC - Tinned Copper 95.000 Outer Jacket Outer Jacket Material: Outer Jacket Material PE - Polyethylene Overall Cable Overall Nominal Diameter: 0.305 in. Mechanical Characteristics (Overall) Operating Temperature Range: -55°C To +80°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 69 lbs/1000 ft. Max. Recommended Pulling Tension: 168 lbs. Min. Bend Radius/Minor Axis: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 88281 Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8281 Coax - Double Braided RG-59/U Type Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.131 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 21 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.54 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.9 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .3 3.6 .5 10.0 .8 71.5 2.1 135 3.0 270 4.3 360 5.1 540 6.3 720 7.4 750 7.6 1000 9.2 Max. Operating Voltage - Non-UL: Voltage 2900 V RMS Other Electrical Characteristic 1: Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge and termination. 75 +/- 1.5 Ohms Other Electrical Characteristic 2: Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, using a 75 Ohm fixed bridge and termination. Minimum Structural Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 216 27 217 850 23 Sweep Test Sweep Testing: 100% Sweep tested 5MHz to 850MHz. Put Ups and Colors: Item # Putup Ship Weight 600006215 1 EA 0.416 LB Color Notes 8281 0021000 1,000 FT 8281 002500 Item Desc 73.000 LB RED C 75 OHM VIDEO COAX 500 FT 37.500 LB RED C 75 OHM VIDEO COAX 8281 0031000 1,000 FT 73.000 LB ORANGE C 75 OHM VIDEO COAX 8281 0041000 1,000 FT 73.000 LB YELLOW C 75 OHM VIDEO COAX 8281 004500 500 FT 37.500 LB YELLOW 8281 0051000 1,000 FT 73.000 LB GREEN, DARK C 75 OHM VIDEO COAX 8281 005500 500 FT 37.500 LB GREEN, DARK C 75 OHM VIDEO COAX 8281 0061000 1,000 FT 73.000 LB BLUE, LIGHT C 75 OHM VIDEO COAX 8281 006500 500 FT 37.500 LB BLUE, LIGHT 8281 0091000 1,000 FT 73.000 LB WHITE RSTS 5-183/3 M Page 2 of 3 75 OHM VIDEO COAX 75 OHM VIDEO COAX C 75 OHM VIDEO COAX 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8281 Coax - Double Braided RG-59/U Type 8281 0101000 1,000 FT 73.000 LB BLACK C 75 OHM VIDEO COAX 8281 010500 500 FT 37.500 LB BLACK C 75 OHM VIDEO COAX 8281 0105000 5,000 FT 380.000 LB BLACK CZ 75 OHM VIDEO COAX Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 2 Revision Date: 07-29-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
8281 0041000 价格&库存
很抱歉,暂时无法提供与“8281 0041000”相匹配的价格&库存,您可以联系我们找货
