83010 0011000
83010 0011000
    BELDEN
    BELDEN - 83010 0011000 - HOOK-UP WIRE, 1000FT, 16AWG CU BROWN
83010 0011000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83010 Hook-up/Lead - UL AWM Style 1371 For more Information please call 1-800-Belden1 General Description: Stranded silver-coated copper conductor insulation with extruded TFE Teflon. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 16 19x29 SPC - Silver Plated Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) TFE - Tetrafluoroethylene 0.011 Overall Insulation Overall Cable Overall Nominal Diameter: 0.077 in. Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C Bulk Cable Weight: 10 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 105°C EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: NEMA HP3, MIL-W-16878/4 (Except For Stranding) MIL Spec Rating: 600 V, 200°C Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.000 Max. Operating Voltage - Other: Voltage Description 600 VRMS Mil-W-16878/4 Max. Recommended Current: Description Current Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83010 Hook-up/Lead - UL AWM Style 1371 Mil-Std-975M Table 3.16 (single wire) 13 amps Put Ups and Colors: Item # Putup Ship Weight Color 83010 001100 100 FT 1.200 LB BROWN Notes Item Desc 83010 0011000 1,000 FT 11.000 LB BROWN SWZ #16 STR TFE BRN 83010 001500 500 FT 6.000 LB BROWN SW #16 STR TFE BRN 83010 002100 100 FT 1.200 LB RED 83010 0021000 1,000 FT 11.000 LB RED SW #16 STR TFE RED 83010 002500 500 FT 6.000 LB RED SW #16 STR TFE RED 83010 003100 100 FT 1.200 LB ORANGE 83010 003500 500 FT 6.000 LB ORANGE 83010 004100 100 FT 1.200 LB YELLOW 83010 0041000 1,000 FT 11.000 LB YELLOW SW #16 STR TFE YEL 83010 004500 500 FT 6.000 LB YELLOW SW #16 STR TFE YEL 83010 005100 100 FT 1.200 LB GREEN, DARK 83010 0051000 1,000 FT 11.000 LB GREEN, DARK SW #16 STR TFE GRNDK 83010 005500 500 FT 6.000 LB GREEN, DARK SW #16 STR TFE GRNDK 83010 006100 100 FT 1.200 LB BLUE, LIGHT 83010 0061000 1,000 FT 11.000 LB BLUE, LIGHT SW #16 STR TFE BLULT 83010 006500 500 FT 6.000 LB BLUE, LIGHT SW #16 STR TFE LBLU 83010 007100 100 FT 1.200 LB VIOLET 83010 007500 500 FT 6.000 LB VIOLET 83010 008100 100 FT 1.200 LB GRAY 83010 008500 500 FT 6.000 LB GRAY 83010 009100 100 FT 1.200 LB WHITE 83010 0091000 1,000 FT 11.000 LB WHITE SW #16 STR TFE WHT 83010 009500 500 FT 6.000 LB WHITE SW #16 STR TFE WHT 83010 010100 100 FT 1.200 LB BLACK 83010 0101000 1,000 FT 11.000 LB BLACK SW #16 STR TFE BLK 83010 010500 500 FT 6.000 LB BLACK SW #16 STR TFE BLK #16 STR TFE BRN #16 STR TFE RED #16 STR TFE ORG SW #16 STR TFE ORG #16 STR TFE YEL #16 STR TFE GRNDK #16 STR TFE BLULT #16 STR TFE VIO SW #16 STR TFE VIO #16 STR TFE GRY SW #16 STR TFE GRY #16 STR TFE WHT #16 STR TFE BLK Notes: S = STRIPING ADDERS FOR TYPES E AND EE: 123 STRIPES. MINIMUM ORDER10 W = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 75' Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 2 Revision Date: 08-30-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
83010 0011000 价格&库存
很抱歉,暂时无法提供与“83010 0011000”相匹配的价格&库存,您可以联系我们找货
  • 305+43.70999305+5.63870
  • 610+37.92871610+4.89290
