83606 0021000
83606 0021000
    BELDEN
    CBL 6COND 20AWG SHLD
83606 0021000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83606 Multi-Conductor - Audio, Control and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (7x28) TC conductors, conductors cabled, plenum, FEP insulation, overall Beldfoil® (100% coverage) + TC braid shield (85% coverage), FEP jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 6 20 7x28 TC - Tinned Copper Total Number of Conductors: 6 Insulation Insulation Material: Insulation Trade Name Insulation Material Teflon® Wall Thickness (in.) FEP - Fluorinated Ethylene Propylene .006 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Braid TC - Tinned Copper 85 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) FEP - Fluorinated Ethylene Propylene .014 Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 White 3 Red 4 Green 5 Orange 6 Blue Overall Nominal Diameter: 0.207 in. Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C Bulk Cable Weight: 43 lbs/1000 ft. Max. Recommended Pulling Tension: 125 lbs. Min. Bend Radius/Minor Axis: 2.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP NEC Articles: 800 CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83606 Multi-Conductor - Audio, Control and Instrumentation Cable EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Plenum/Non-Plenum Plenum (Y/N): Yes Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 26 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 51 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 8.6 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.1 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current 10C Temperature Rise 2.7 Amps per conductor @ 25°C ambient Notes (Overall) Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 83606 002100 100 FT 6.200 LB RED C 6#20 FEP SH FEP 83606 0021000 1,000 FT 47.000 LB RED C 6#20 FEP SH FEP 83606 002500 500 FT 23.000 LB RED C 6#20 FEP SH FEP Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-07-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
83606 0021000 价格&库存
很抱歉,暂时无法提供与“83606 0021000”相匹配的价格&库存,您可以联系我们找货
  • 1000+141.711281000+17.77036
库存:1000
