8405 060500
8405 060500
    BELDEN
    5 #20 PE SHLD PVC
8405 060500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8405 Multi-Conductor - Microphone/Musical Instrument Cable For more Information please call 1-800-Belden1 General Description: Mic, 20 AWG stranded (19x32) high-conductivity TC conductors, cabled, polyethylene insulation, rayon braid, TC braid shield (85% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 5 20 19x32 Dia. (in.) High Conductivity TC - Tinned Copper .037 Total Number of Conductors: 5 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) PE - Polyethylene .016 .069 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 85.000 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .035 Overall Cable Overall Cabling Fillers: Jute Overall Cabling Color Code Chart: Number Color 1 Black 2 Clear 3 Green 4 Red 5 Blue Overall Cabling Separator Material: Rayon Braid Overall Cabling Separator Thickness: 0.005 in. Overall Nominal Diameter: 0.281 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C UL Temperature Rating: 60°C (UL AWM Style 2094) Bulk Cable Weight: 59 lbs/1000 ft. Max. Recommended Pulling Tension: 139 lbs. Min. Bend Radius/Minor Axis: 2.800 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 2094 (300 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8405 Multi-Conductor - Microphone/Musical Instrument Cable EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading, VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 23 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 40 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10.2 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.47 Max. Operating Voltage - UL: Voltage 300 V RMS (UL AWM Style 2094) Max. Recommended Current: Current 3.2 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 8405 0601000 1,000 FT 63.000 LB CHROME C 5 #20 PE SHLD PVC 8405 060250 250 FT 16.500 LB CHROME C 5 #20 PE SHLD PVC 8405 060500 500 FT 31.000 LB CHROME 5 #20 PE SHLD PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 08-15-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
8405 060500
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:工作温度范围为-20℃至+70℃,隔离电压为5000Vrms,输入电流为10mA,输出电流为50mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有高隔离性、低功耗、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装形式。
8405 060500 价格&库存
很抱歉,暂时无法提供与“8405 060500”相匹配的价格&库存,您可以联系我们找货
