8406 010100
8406 010100
    BELDEN
    3 #24 CS EPDM BRD CS SBR
8406 010100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8406 Multi-Conductor - Three-Conductor, Low-Impedance Cable For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (45x40) TC alloy conductors, EPDM rubber insulation, conductive textile wrap (100% coverage), TC braid shield (60% coverage), cotton serve, EPDM rubber jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material Dia. (in.) 3 24 45x40 Tinned Copper Alloy .024 Total Number of Conductors: 3 Insulation Insulation Material: Insulation Material Dia. (in.) EPDM - Ethylene Propylene Diene Monomer Rubber 0.065 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Tape Conductive Textile 100 2 Braid TC - Tinned Copper 60 3 Spiral Serve Cotton 100 Outer Jacket Outer Jacket Material: Outer Jacket Material EPDM - Ethylene Propylene Diene Monomer Rubber Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 Red 3 White Overall Nominal Diameter: 0.223 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +90°C Non-UL Temperature Rating: 90°C Bulk Cable Weight: 33 lbs/1000 ft. Max. Recommended Pulling Tension: 67 lbs. Min. Bend Radius/Minor Axis: 2.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2002/95/EC (RoHS): No Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 30 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 55 Nom. Conductor DC Resistance: Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8406 Multi-Conductor - Three-Conductor, Low-Impedance Cable DCR @ 20°C (Ohm/1000 ft) 28.7 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 11.38 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.2 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color 8406 010100 100 FT 4.100 LB BLACK 3 #24 CS EPDM BRD CS SBR 8406 010500 500 FT 16.500 LB BLACK 3 #24 CS EPDM BRD,CS SBR Revision Number: 2 Notes Item Desc Revision Date: 10-15-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
8406 010100 价格&库存
很抱歉,暂时无法提供与“8406 010100”相匹配的价格&库存,您可以联系我们找货
