8520 0051000
8520 0051000
    BELDEN
    HOOK-UP 14AWG STR GRN
8520 0051000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8520 Hook-up/Lead - (Type MW) MIL-W-76C-PVC For more Information please call 1-800-Belden1 General Description: Tinned copper, PVC insulation, medium wall. The extruded PVC insulation is flame and ozone resistant. Inert to most chemicals, oils, and solvents. Covers single cond., PVC insulated hook-up wire for internal wiring of electrical and electronic equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 14 41x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .018 Overall Insulation Overall Cable Overall Nominal Diameter: 0.111 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-W-76C MIL Spec Rating: 1000 V, 80°C Plenum/Non-Plenum Plenum (Y/N): No Put Ups and Colors: Item # Putup Ship Weight Color 8520 001100 100 FT 1.700 LB BROWN 8520 0011000 1,000 FT 17.000 LB BROWN 8520 002100 100 FT 1.700 LB RED 8520 0021000 1,000 FT 17.000 LB RED 8520 003100 100 FT 1.700 LB ORANGE 8520 0031000 1,000 FT 17.000 LB ORANGE 8520 005100 100 FT 1.700 LB GREEN, DARK 8520 0051000 1,000 FT 17.000 LB GREEN, DARK 8520 006100 100 FT 1.700 LB BLUE, LIGHT 8520 0061000 1,000 FT 17.000 LB BLUE, LIGHT 8520 009100 100 FT 1.700 LB WHITE 8520 0091000 1,000 FT 17.000 LB WHITE 8520 010100 100 FT 1.700 LB BLACK Page 1 of 2 Notes Item Desc 14 STR PVC BRN P 14 STR PVC BRN 14 STR PVC RED P 14 STR PVC RED 14 STR PVC ORG P 14 STR PVC ORG 14 STR PVC GRN P 14 STR PVC GRN 14 STR PVC LBLU P 14 STR PVC LBLU 14 STR PVC WHT P 14 STR PVC WHT 14 STR PVC BLK 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8520 Hook-up/Lead - (Type MW) MIL-W-76C-PVC 8520 0101000 1,000 FT 17.000 LB BLACK 8520 013100 100 FT 1.700 LB BLUE, DARK 8520 0181000 1,000 FT 17.000 LB WHITE/BLUE P 14 STR PVC BLK 14 STR PVC DBLU A 14 STR PVC WHT/BLU Notes: A = STOCKED STRIPE COLORS. P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 1 Revision Date: 05-14-2007 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
8520 0051000 价格&库存
很抱歉,暂时无法提供与“8520 0051000”相匹配的价格&库存,您可以联系我们找货
