8722 060U1000
8722 060U1000
    BELDEN
    2#20FS PVC,2#20 PVC PVC
8722 060U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8722 Multi-Conductor - Special Audio, Communication and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (7x28) TC conductors, PVC insulation, conductors cabled, Beldfoil® shield as noted (100% coverage), 22 AWG stranded TC drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 20 7x28 TC - Tinned Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Dia. (in.) PVC - Polyvinyl Chloride 0.068 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 22 Inner Shield Drain Wire Stranding: Stranded Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.226 in. Pair Pair Color Code Chart: Number Color 1 Shielded: Red & Black 2 Unshielded: Green & White Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C UL Temperature Rating: 80°C Bulk Cable Weight: 33 lbs/1000 ft. Max. Recommended Pulling Tension: 56 lbs. Min. Bend Radius/Minor Axis: 2.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8722 Multi-Conductor - Special Audio, Communication and Instrumentation Cable EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test C(UL) Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .2 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 60 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 99 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 12.500 Ohm/1000 ft Max. Operating Voltage - UL: Voltage 350 V RMS Max. Recommended Current: Current 3.1 Amps per conductor @ 25°C Notes (Overall) Notes: Beldfoil® shield over Red and Black conductors only. Request Technical Bulletin T/8-21 before planning high and low level circuits in the same cable. Put Ups and Colors: Item # Putup Ship Weight Color 8722 060U1000 1,000 FT 35.000 LB CHROME Notes Item Desc 8722 060U500 500 FT 18.000 LB CHROME 8722 0601000 1,000 FT 36.000 LB CHROME C 2#20 FS PVC,2#20 PVC PVC 8722 060500 500 FT 18.500 LB CHROME C 2#20 FS PVC,2#20 PVC PVC 2#20FS PVC,2#20 PVC PVC 2#20 FS PVC,2#20 PVC PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 10-15-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
8722 060U1000 价格&库存
很抱歉,暂时无法提供与“8722 060U1000”相匹配的价格&库存,您可以联系我们找货
