Part Number: 89292
Analog Video, RG11, #14 Solid BC, Foil + 65% TC Braid, FEP Jacket, CMP
Product Description
14 AWG solid .064" bare copper conductor, plenum, foam FEP insulation, Duofoil®; tinned copper braid shield (65% coverage), FEP jacket.
Technical Specifications
Product Overview
Environmental Space:
Indoor - Plenum
Physical Characteristics (Overall)
Conductor
AWG Stranding
14
Solid
Material
Nominal Diameter No. of Coax
BC - Bare Copper 0.064 in
Conductor Count:
1
AWG Size:
14
1
Insulation
Material
Nominal Diameter
FFEP - Foam Fluorinated Ethylene Propylene 0.274 in
Outer Shield Material
Type Layer
Material
Material Trade Name Coverage [%]
Tape 1
Aluminum Foil-Polyester Tape-Aluminum Foil Duofoil®
100 %
Braid 2
TC - Tinned Copper
65 %
Outer Jacket Material
Material
Material Trade Name Nominal Diameter
FEP - Fluorinated Ethylene Propylene Teflon®
0.346 in
Electrical Characteristics
Conductor DCR
Nominal Conductor DCR Nominal Conductor DCR Conductor Resistance Nominal Outer Shield DCR Outer Conductor DCR
2.5 Ohm/1000ft
2.5 Ohm/1000ft
Capacitance
Nom. Capacitance Conductor to Shield
16.2 pF/ft
Inductance
Nominal Inductance
0.091 µH/ft
Impedance
Nominal Characteristic Impedance
75 Ohm
High Frequency (Nominal/Typical)
Frequency [MHz] Nom. Insertion Loss Nom. Structural Return Loss (SRL)
1 MHz
0.2 dB/100ft
23 dB
3 Ohm/1000ft
3 Ohm/1000ft
450 MHz
0.4 dB/100ft
5 MHz
1 dB/100ft
100 MHz
1.5 dB/100ft
200 MHz
2.2 dB/100ft
400 MHz
3.3 dB/100ft
700 MHz
4.5 dB/100ft
900 MHz
5.2 dB/100ft
1000 MHz
5.5 dB/100ft
Delay
Nominal Delay Nominal Velocity of Propagation (VP) [%]
1.22 ns/ft
83 %
Voltage
UL Voltage Rating
300 V RMS
Temperature Range
Non-UL Temp Rating:
200°C
Operating Temp Range:
-70°C To +200°C
Mechanical Characteristics
Bulk Cable Weight:
73 lbs/1000ft
Max Recommended Pulling Tension:
97 lbs
Min Bend Radius/Minor Axis:
4 in
Standards
NEC/(UL) Specification:
CMP, CATVP
CEC/C(UL) Specification:
CMP
RG Type:
RG-11/U Type
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2003/11/EC (BFR):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive 2015/863/EU:
Yes
EU Directive Compliance:
EU CE Mark:
Yes
EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Suitability
Suitability - Indoor:
Yes
Flammability, LS0H, Toxicity Testing
C(UL) Flammability:
FT6
UL Flammability:
NFPA 262
Part Number
Plenum (Y/N):
Yes
Non-Plenum Number:
9292
Footnote:
C - CRATE REEL PUT-UP.
Product Notes
Notes:
Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc.
© 2018 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's
inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product
itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
很抱歉,暂时无法提供与“89292 010500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+104.39127500+13.48654
- 国内价格 香港价格
- 1+40961.557841+5291.91390
- 2+39605.076602+5116.66710
