9167 G751000
9167 G751000
    BELDEN
    #20 GIFHDLDPE SH FS PVC
9167 G751000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9167 Coax - Headend/Video Cable For more Information please call 1-800-Belden1 General Description: 20 AWG solid .032" silver-plated, copper-covered steel conductor, gas-injected foam polyethylene insulation, Duobond Plus® + aluminum braid shield (95% coverage), PVC jacket (available in 13 colors). Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 20 Solid Dia. (in.) SPCCS - Silver Plated Copper Covered Steel .032 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FPE - Foam Polyethylene 0.145 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material Coverage (%) 1 Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 2 Braid AL - Aluminum 95 3 Tape Bonded Aluminum Foil-Polyester Tape w/Shorting Fold 100 Bonded Duofoil® Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.242 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +75°C Bulk Cable Weight: 27 lbs/1000 ft. Max. Recommended Pulling Tension: 140 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CATVR, CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Series Type: Series 59 Flame Test Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9167 Coax - Headend/Video Cable UL Flame Test: UL1666 Riser CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) Tolerance (Ohms) 75 ±3 Nom. Inductance: Inductance (µH/ft) 0.097 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.2 Nominal Velocity of Propagation: VP (%) 83 Nominal Delay: Delay (ns/ft) 1.2 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 25.8 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.5 Max. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 5 0.89 55 1.95 211 3.59 270 4.05 300 4.27 350 4.64 400 4.88 450 5.30 550 5.90 750 6.96 870 7.54 1000 8.09 Max. Operating Voltage - UL: Voltage 300 V RMS Minimum Structural Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 1000 20 Sweep Test Sweep Testing: 5 MHz to 1 GHz Put Ups and Colors: Item # Putup Ship Weight Color 9167 G751000 1,000 FT 26.000 LB AQUA Notes #20 GIFHDLDPE SH FS PVC 9167 0011000 1,000 FT 26.000 LB BROWN #20 GIFHDLDPE SH FS PVC 9167 0021000 1,000 FT 26.000 LB RED #20 GIFHDLDPE SH FS PVC 9167 0031000 1,000 FT 26.000 LB ORANGE #20 GIFHDLDPE SH FS PVC 9167 0041000 1,000 FT 26.000 LB YELLOW #20 GIFHDLDPE SH FS PVC 9167 0051000 1,000 FT 26.000 LB GREEN, DARK #20 GIFHDLDPE SH FS PVC 9167 0061000 1,000 FT 26.000 LB BLUE, LIGHT #20 GIFHDLDPE SH FS PVC 9167 0071000 1,000 FT 26.000 LB VIOLET #20 GIFHDLDPE SH FS PVC 9167 0081000 1,000 FT 26.000 LB GRAY #20 GIFHDLDPE SH FS PVC 9167 0091000 1,000 FT 26.000 LB WHITE #20 GIFHDLDPE SH FS PVC Page 2 of 3 Item Desc 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9167 Coax - Headend/Video Cable 9167 0101000 1,000 FT 26.000 LB BLACK 9167 0121000 1,000 FT 26.000 LB PINK #20 GIFHDLDPE SH FS PVC 9167 2901000 1,000 FT 26.000 LB BEIGE, LIGHT #20 GIFHDLDPE SH FS PVC C #20 GIFHDLDPE SH FS PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 12-15-2010 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
9167 G751000 价格&库存
很抱歉,暂时无法提供与“9167 G751000”相匹配的价格&库存,您可以联系我们找货
9167 G751000
  • 1000+6.913791000+0.89877
