9503 060U100
9503 060U100
    BELDEN
    BELDEN - 9503 060U100 - Multipair Cable, Computer, Screened, 3 Pair, 24 AWG, 0.2 mm², 98.43 ft, 30 m
9503 060U100 数据手册
9503 Paired - Computer Cable for EIA RS-232 Applications For more information please call 1-800-Belden1 See Put-ups and Colors Related Documents : No. 3 for Paired Cables (Belden Standard).pdf Description: 24 AWG stranded (7x32) TC conductors, semi-rigid PVC insulation, twisted pairs, overall Beldfoil shield (100% coverage), 24 AWG stranded TC drain Wire, PVC jacket. PHYSICAL CHARACTERISTICS: CONDUCTOR: Number of Pairs 3 Total Number of Conductors 6 AWG 24 Stranding 7x32 Conductor Material TC - Tinned Copper INSULATION: Insulation Material S-R PVC - Semi-Rigid Polyvinyl Chloride Lay Length 1.5 in. Twists/ft. 8 Pair Color Code Chart : Number 1 2 Color Black & Red Black & White Number 3 OUTER SHIELD: Outer Shield Material Trade Name Beldfoil® Outer Shield Type Tape Outer Shield Material Aluminum Foil-Polyester Tape Outer Shield %Coverage 100 % OUTER SHIELD DRAIN WIRE : Outer Shield Drain Wire AWG 24 Outer Shield Drain Wire Stranding 7x32 Outer Shield Drain Wire Conductor Material TC - Tinned Copper Page 1 of 3 Color Black & Green 9503 Paired - Computer Cable for EIA RS-232 Applications OUTER JACKET: Outer Jacket Material PVC - Polyvinyl Chloride OVERALL NOMINAL DIAMETER: Overall Nominal Diameter .232 in. MECHANICAL CHARACTERISTICS: Operating Temperature Range -30°C To +80°C UL Temperature Rating 80°C (UL AWM Style 2464) Bulk Cable Weight 27.1 lbs/1000 ft. Max. Recommended Pulling Tension 33 lbs. Min. Bend Radius (Install) 2.5 in. APPLICABLE SPECIFICATIONS AND AGENCY COMPLIANCE: APPLICABLE STANDARDS: NEC/(UL) Specification CMG CEC/C(UL) Specification CMG AWM Specification UL Style 2464 (300 V 80°C) CSA Specification AWM I A EU CE Mark (Y/N) Yes EU RoHS Compliant (Y/N) Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 FLAME TEST: UL Flame Test UL1685 FT4 Loading C(UL) Flame Test FT4 PLENUM/NON-PLENUM: Plenum (Y/N) N Plenum Number 89503, 82503 ELECTRICAL CHARACTERISTICS: Nom. Characteristic Impedance 75 Ohms Nom. Capacitance Conductor to Conductor @ 1 KHz 30 pF/ft Nom. Cap. Cond. to Other Cond. & Shield @ 1 KHz 50 pF/ft Nominal Velocity of Propagation 60 % Nom. Conductor DC Resistance @ 20 Deg. C 24 Ohms/1000 ft Nominal Outer Shield DC Resistance @ 20 Deg. C 17 Ohms/1000 ft Max. Operating Voltage - UL 300 V RMS (UL AWM Style 2464) Max. Recommended Current 1.76 Amps per conductor @ 25°C Page 2 of 3 9503 Paired - Computer Cable for EIA RS-232 Applications PUT-UPS AND COLORS: Item Description 9503 060100 3 PR #24 PVC FS PVC 9503 0601000 3 PR #24 PVC FS PVC 9503 060500 3 PR #24 PVC FS PVC 9503 060U1000 3 PR #24 PVC FS PVC 9503 060U500 3 PR #24 PVC FS PVC Put-Up (ft.) 100 Ship Weight (lbs.) 3.4 Jacket Color CHROME Notes 1000 30 CHROME C 500 14.5 CHROME C U1000 28 CHROME U500 15 CHROME C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 07-19-2005 © 2006 Belden Wire & Cable Company All Rights Reserved. Although Belden Electronics Division ("Belden") makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden CDT Electronics Division believes this product to be in compliance with the following environmental regulations: California Proposition 65 Consent Judgment For Wire & Cable Mfgs.(San Francisco Superior Court Nos. 312962 And 320342); EU RoHS (Directive 2002/95/EC, 27-Jan-2003);Material manufactured prior to the compliance date may still be in stock at Belden facilities and in our Distributor's inventory. EU ELV (Directive 2000/53/EC, 18-Sept-2000); EU WEEE (Directive 2002/96/EC, 27-Jan-2003); And EU BFR (Directive 2003/11/EC, 6-Feb-2003). The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information and belief at the date of its publication. The information provided in the Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden CDT Electronics Division declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3
9503 060U100 价格&库存
很抱歉,暂时无法提供与“9503 060U100”相匹配的价格&库存,您可以联系我们找货
