9641 0081000
9641 0081000
    BELDEN
    23 CONDR IEEE 488 CABLE
9641 0081000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9641 Multi-Conductor - Computer Cable for EIA RS-232 Applications For more Information please call 1-800-Belden1 General Description: 26 AWG stranded (7x34)and 24 AWG stranded (7x32) tinned copper conductors, semi-rigid PVC insulation, overall Beldfoil (100% Coverage) plus inned copper braid shield (90% Coverage), drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors # Pairs AWG Stranding Conductor Material 26 7x34 TC - Tinned Copper 10 6 26 7x34 TC - Tinned Copper 1 24 7x32 TC - Tinned Copper Total Number of Conductors: 23 Insulation Insulation Material: Insulation Material S-R PVC - Semi-Rigid Polyvinyl Chloride Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Tape/Braid TC - Tinned Copper 90 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 26 7x34 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Cabling Color Code Chart: Number Color AWG Group/Cond. Color 1 Blue and White/Gray 26 Pair 2 Purple and White/Black/Brown 26 Pair 3 Gray and White/Black/Red 26 Pair 4 White and White/Black/Orange 26 Pair 5 White/Black and White/Black/Yellow 26 Pair 6 White/Brown and White/Black/Green 26 Pair 7 Brown 26 Conductor 8 Red 26 Conductor 9 Orange 26 Conductor 10 Yellow 26 Conductor 11 Lt. Green 26 Conductor 12 White/Orange 26 Conductor 13 White/Yellow 26 Conductor 14 White/Green 26 Conductor 15 White/Blue 26 Conductor 16 White/Purple 26 Conductor 17 White/Black/Blue 24 Conductor Overall Cabling Separator Material: Polyester Overall Nominal Diameter: 0.350 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9641 Multi-Conductor - Computer Cable for EIA RS-232 Applications UL Temperature Rating: 80°C (UL AWM Style 2464) Bulk Cable Weight: 71 lbs/1000 ft. Max. Recommended Pulling Tension: 140 lbs. Min. Bend Radius/Minor Axis: 3.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG AWM Specification: UL Style 2464 (300 V 80°C) CSA Specification: AWM I A EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: 488 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test C(UL) Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: Description DCR @ 20°C (Ohm/1000 ft) 24 AWG 23.3 26 AWG 37.3 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.6 Max. Operating Voltage - UL: Voltage 300 V RMS (UL AWM Style 2464) Max. Recommended Current: Current 0.6 Amps per conductor @ 25°C (26 AWG) 1.1 Amps per conductor @ 25°C (24 AWG) Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9641 0081000 1,000 FT 82.000 LB GRAY C 23 CONDR IEEE 488 CABLE Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 04-11-2008 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9641 Multi-Conductor - Computer Cable for EIA RS-232 Applications Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9641 0081000 价格&库存
很抱歉,暂时无法提供与“9641 0081000”相匹配的价格&库存,您可以联系我们找货
