9815 0102000
9815 0102000
    BELDEN
    TW PR #20 PE PE BRD PE
9815 0102000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9815 Twinax - 100 Ohm Twinax For more Information please call 1-800-Belden1 General Description: 100 ohm, 20 AWG stranded (7x28) .037" one tinned/ one bare copper conductors, polyethylene insulation, Duofoil® + TC braid shield (95% coverage), high-density polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 1 20 7x28 TC - Tinned Copper BC - Bare Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (mm) PE - Polyethylene 0.610 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom Wall (mm) Nom. Dia. (mm) PE - Polyethylene 0.889 5.994 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 2 Braid TC - Tinned Copper Outer Shield Flooding Grease: 95 Polyethylene Grease Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) HDPE - High Density Polyethylene 0.864 Overall Cable Overall Nominal Diameter: 8.382 mm Pair Pair Color Code Chart: Number Color 1 Natural & Natural Mechanical Characteristics (Overall) Operating Temperature Range: -55°C To +80°C Bulk Cable Weight: 92.268 Kg/Km Max. Recommended Pulling Tension: 511.543 N Min. Bend Radius/Minor Axis: 88.900 mm Page 1 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9815 Twinax - 100 Ohm Twinax Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Burial: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 100 Nom. Inductance: Inductance (µH/m) 0.508555 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 47.5745 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 75.463 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/m) 5.05274 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 31.1695 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 6.562 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 1.3124 10 3.6091 50 8.2025 100 13.4521 200 20.9984 400 33.4662 Page 2 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9815 Twinax - 100 Ohm Twinax Max. Operating Voltage - Non-UL: Voltage 600 V RMS Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9815 0101000 305 MT 31.298 KG BLACK C TW PR #20 PE PE BRD PE 9815 010500 152 MT 15.649 KG BLACK TW PR #20 PE PE BRD PE Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 10-16-2012 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 10-30-2013
9815 0102000 价格&库存
很抱歉,暂时无法提供与“9815 0102000”相匹配的价格&库存,您可以联系我们找货
