9841
9841
    BELDEN
9841 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9841 Multi-Conductor - Low Capacitance Computer Cable for EIA RS-485 Applications For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (7x32) TC conductors, polyethylene insulation, twisted pairs, overall Beldfoil® (100% coverage) + TC braid shield (90% coverage), 24 AWG stranded TC drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 1 24 7x32 TC - Tinned Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PE - Polyethylene 0.023 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Coverage (%) Beldfoil® (w/ shorting fold) Tape Aluminum Foil-Polyester Tape 100.000 2 Braid TC - Tinned Copper 90.000 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x#32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.035 Overall Cable Overall Cabling Fillers: Fibrous Polypropylene Overall Cabling Lay Length & Direction: Length (in.) Direction Twists (twist/ft) 2.500 Left Hand 4.800 Overall Nominal Diameter: 0.232 in. Pair Pair Color Code Chart: Color White/Blue and Blue/White Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +80°C Bulk Cable Weight: 36 lbs/1000 ft. Max. Recommended Pulling Tension: 72.300 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM NEC Articles: 800 CEC/C(UL) Specification: CM AWM Specification: UL Style 2919 (30 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9841 Multi-Conductor - Low Capacitance Computer Cable for EIA RS-485 Applications EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading CSA Flame Test: FT1 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 82841, 89841 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 120 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 12.8 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 23 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.6 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 24 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.4 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.600 Max. Operating Voltage - UL: Voltage Description 300 V RMS Type CM 30 V RMS AWM2919 Max. Recommended Current: Description Current 10C temperature rise 2.1 Amps per conductor @ 25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color 9841 060100 100 FT 4.300 LB CHROME Notes Item Desc 9841 0601000 1,000 FT 40.000 LB CHROME C 1 PR #24 PE SH PVC 9841 06010000 10,000 FT 380.000 LB CHROME C 1 PR #24 PE SH PVC 9841 060500 500 FT 20.000 LB CHROME C 1 PR #24 PE SH PVC 9841 0605000 5,000 FT 200.000 LB CHROME 1 PR #24 PE SH PVC 1 PR #24 PE SH PVC Notes: Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9841 Multi-Conductor - Low Capacitance Computer Cable for EIA RS-485 Applications C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 05-06-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
很抱歉,暂时无法提供与“9841”相匹配的价格&库存,您可以联系我们找货
