9239 010100
9239 010100
    BELDEN
    #26AWG LOW NOISE COAX
9239 010100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9239 Coax - Low Noise For more Information please call 1-800-Belden1 General Description: Low noise, RG-174/U Type, 26 AWG stranded (7x34) .019" bare copper-covered steel conductor, polyethylene insulation, conductive layer, TC braid shield (90% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 26 7x34 Dia. (in.) BCCS - Bare Copper Covered Steel .019 Total Number of Conductors: 1 Insulation Insulation Material: Layer # Insulation Material Dia. (in.) 1 PE - Polyethylene .044 2 Conductive PVC - Polyvinyl Chloride .056 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 90 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.101 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 7 lbs/1000 ft. Max. Recommended Pulling Tension: 14.400 lbs. Min. Bend Radius/Minor Axis: 1 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 174/U Plenum/Non-Plenum Plenum (Y/N): No Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9239 Coax - Low Noise Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 38 Nominal Velocity of Propagation: VP (%) 62 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 97.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14 Max. Operating Voltage - Other: Voltage 300 Vrms Other Electrical Characteristic 1: NBS Low Noise Test (Modified), MIL-C-17 Paragraph 4.8.14, 8 mV Peak to Peak Max Max. Noise Level (Peak to Peak): 5 mV Notes (Overall) Notes: Not recommended for RF use. Put Ups and Colors: Item # Putup Ship Weight Color 9239 010100 100 FT 1.000 LB BLACK #26AWG LOW NOISE COAX 9239 0101000 1,000 FT 8.000 LB BLACK #26 AWG LOW NOISE COAX 9239 010500 500 FT 4.500 LB BLACK #26AWG LOW NOISE COAX Revision Number: 2 Notes Item Desc Revision Date: 02-25-2015 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
9239 010100 价格&库存
很抱歉,暂时无法提供与“9239 010100”相匹配的价格&库存,您可以联系我们找货
