9913F7 B59100
9913F7 B59100
    BELDEN
    #10 FHDPE SH PVC
9913F7 B59100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9913F7 Coax - RG-8/U Type For more Information please call 1-800-Belden1 General Description: RG-8/U type, 10 AWG stranded (7x19) .108" bare copper conductor, gas-injected foam HDPE insulation, Duobond II ® + tinned copper braid shield (95% coverage), Belflex® jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 10 7x19 BC - Bare Copper .108 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .285 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 2 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Belflex® PVC Blend - Polyvinyl Chloride Blend Overall Cable Overall Nominal Diameter: 0.405 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 94 lbs/1000 ft. Max. Recommended Pulling Tension: 210 lbs. Min. Bend Radius/Minor Axis: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 8/U Plenum/Non-Plenum Plenum (Y/N): No Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9913F7 Coax - RG-8/U Type Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 52 Nom. Inductance: Inductance (µH/ft) .059 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 22.5 Nominal Velocity of Propagation: VP (%) 85 Nominal Delay: Delay (ns/ft) 1.2 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.1 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.8 Maximum VSWR: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR 5 2250 1.43:1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 10 .6 50 1.1 100 1.5 200 2.0 400 3.0 700 4.0 900 4.7 1000 5.0 2000 7.5 2250 8.0 3000 9.8 4000 12.1 Nom. Power Rating: Freq. (MHz) Rating (W) 5 3217 10 2681 50 1463 100 1073 200 805 400 575 700 424 900 366 1000 350 1500 278 1800 252 2000 237 2500 210 3000 188 4000 157 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Other Electrical Characteristic 1: Actual Impedance specification is 51.5 +/- 2 ohms. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9913F7 Coax - RG-8/U Type Misc. Information (Overall) Notes (Overall) Notes: Low Loss, High Flex Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9913F7 B59100 100 FT 12.100 LB BLACK, MATTE C #10 FHDPE SH PVC 9913F7 B591000 1,000 FT 100.000 LB BLACK, MATTE C #10 FHDPE SH PVC 9913F7 B59250 250 FT 26.750 LB BLACK, MATTE C #10 FHDPE SH PVC 9913F7 B59500 500 FT 50.000 LB BLACK, MATTE C #10 FHDPE SH PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 07-29-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
9913F7 B59100 价格&库存
很抱歉,暂时无法提供与“9913F7 B59100”相匹配的价格&库存,您可以联系我们找货
