9924 0105000
9924 0105000
    BELDEN
    HOOK-UP 24AWG STR BLK
9924 0105000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9924 Hook-up/Lead - UL AWM Style 1015 For more Information please call 1-800-Belden1 General Description: Tinned copper conductor, PVC insulation. Rated 105ºC, 600V. Rated 2500V peak for electronic circuits, and internal wiring of electronic and electrical equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 24 7x32 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .030 Overall Insulation Overall Cable Overall Nominal Diameter: 0.088 in. Mechanical Characteristics (Overall) Bulk Cable Weight: 4.700 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 600 V, 105°C UL Type: AWM 1015 or 1230 CSA Rating: 600 V, 105°C CSA Type: AWM I A/B or TEW EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 CSA Flame Test: FT1 Plenum/Non-Plenum Plenum (Y/N): No Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9924 0011000 1,000 FT 6.000 LB BROWN P 24 STR PVC BRN 9924 0021000 1,000 FT 6.000 LB RED P 24 STR PVC RED 9924 0031000 1,000 FT 5.000 LB ORANGE P 24 STR PVC ORG 9924 0041000 1,000 FT 6.000 LB YELLOW P 24 STR PVC YEL Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9924 Hook-up/Lead - UL AWM Style 1015 9924 0091000 1,000 FT 6.000 LB WHITE P 24 STR PVC WHT 9924 0101000 1,000 FT 6.000 LB BLACK P 24 STR PVC BLK 9924 0105000 5,000 FT 25.000 LB BLACK C #24 STR PVC BLK 9924 0131000 1,000 FT 5.000 LB BLUE, DARK P 24 STR PVC D. BLU Notes: C = CRATE REEL PUT-UP. P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 1 Revision Date: 08-26-2008 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
9924 0105000 价格&库存
很抱歉,暂时无法提供与“9924 0105000”相匹配的价格&库存,您可以联系我们找货
