9937 060100
9937 060100
    BELDEN
    CBL 25COND 24AWG SHLD
9937 060100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9937 Multi-Conductor - Low-Capacitance Computer Cable for EIA RS-232/423 For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (7x32) TC conductors, Datalene® insulation, overall Beldfoil® (100% coverage) + TC braid shield (65% coverage), drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 25 24 7x32 TC - Tinned Copper Total Number of Conductors: 25 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® Wall Thickness (in.) FPE - Foam Polyethylene 0.015 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 2 Braid TC - Tinned Copper 65 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 Stranded TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.049 Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 White 3 Red 4 Green 5 Orange 6 Blue 7 White/Black 8 Red/Black 9 Green/Black 10 Orange/Black 11 Blue/Black 12 Black/White 13 Red/White 14 Green/White 15 Blue/White 16 Black/Red 17 White/Red 18 Orange/Red 19 Blue/Red 20 Red/Green 21 Orange/Green 22 Black/White/Red 23 White/Black/Red 24 Red/Black/White 25 Green/Black/White Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9937 Multi-Conductor - Low-Capacitance Computer Cable for EIA RS-232/423 Overall Nominal Diameter: 0.445 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 2919) Bulk Cable Weight: 99 lbs/1000 ft. Min. Bend Radius/Minor Axis: 4.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CM AWM Specification: UL Style 2919 (30 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 12 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 22 Nominal Velocity of Propagation: VP (%) 78 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 24 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.77 Max. Operating Voltage - UL: Voltage Description 30 V RMS UL AWM Style 2919 300 V RMS CM Max. Recommended Current: Current 1.1 Amps per conductor @ 25°C Notes (Overall) Notes: Datalene® insulatin features include a low dielectric constant and a low dissipation factor for high-speed, low-distortin data handling. Physical properties include good crush resistance and light weight. Put Ups and Colors: Item # Putup Ship Weight 9937 1 EA 0.000 Color Notes 9937 060100 100 FT 9937 0601000 1,000 FT Item Desc 11.600 LB CHROME C 25 #24 FHDPE SH PVC 108.000 LB CHROME C 25 #24 FHDPE SH PVC 0985 508 120/3 M Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9937 Multi-Conductor - Low-Capacitance Computer Cable for EIA RS-232/423 9937 060500 500 FT 54.500 LB CHROME C 25 #24 FHDPE SH PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 09-17-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9937 060100 价格&库存
很抱歉,暂时无法提供与“9937 060100”相匹配的价格&库存,您可以联系我们找货
  • 1+252.449261+32.56660
  • 30+199.8045730+25.77530
  • 60+178.7817360+23.06330
  • 90+157.7588990+20.35130
库存:20
