A0266827
A0266827
    BELDEN
    BELDEN  A0266827  BIX MULTIPLYING CONNECTOR, 25POS
A0266827 数据手册
C O M M E R C I A L N E T W O R K I N G — C O P P E R 15.13 BIX Cross-Connect System Distribution Connectors, Multiplying Connectors and Modular Jack Connectors A0393146 QCBIX1A4 Connector BIX Distribution Connector The BIX Distribution Connector is a 25-pair connector. The connector's symmetrical construction allows termination of cables on one side and cross-connect jumper wires or BIX Patch Cords on the other. Each BIX connector is equipped with 50 double-ended Insulation Displacement Connection (IDC) clips for terminating plastic insulated solid copper conductors without stripping and pair splitters on each side of the connector facilitate wire insertion. BIX Multiplying Connector A0266827 QCBIX5A Multiplying Connector BIX Multiplying Connectors are used to generate multiple outputs from a single input. Construction of these connectors is identical to that of BIX Distribution Connectors, except for the IDC clips which are bridged. BIX Multiplying Connectors are typically used in voice applications. The QCBIX2A Connector is built using 24 sets of bridged clips (2 clips each). It is used to terminate various facilities where multiples of 2 are required. The QCBIX7A Connector is built using 10 sets of bridged clips (four 2-clip and six 7-clip bridged arrangements). It is primarily intended for use with 1A type key telephone systems. Each connector can terminate up to three lines of key equipment providing service to as many as seven key telephone sets per line. AX100798 BIX Modular Jack Connector BIX Modular Jack Connector BIX Modular Jack Connectors provide a fast and flexible method to manage small-to-medium crossconnect installations. These connectors are built with a BIX connector pre-wired to standard modular jacks. They allow front-access termination and patching. The NXXCBMC6U Connector is a 6-port, 8-position modular connector used for data applications. It exceeds all Category 5e channel requirements when used with PS5E Modular Cords in a Belden IBDN 1200 System. QCBIX36-type Connectors are used mostly for voice applications. The QCBIX36D connector is a 6-port, 8-position modular connector. It is pre-wired to USOC 8-wire wiring scheme specifications. The QCBIX36C connector is an 8-port, 6-position modular connector. It is pre-wired to USOC 6-wire wiring scheme specifications. The QCBIX36B connector is a 12-port, 6-position modular connector. It is pre-wired to USOC 4-wire wiring scheme specifications. Description Belden Part Number BIX Cross-Connect System Distribution Connector BIX Distribution Connector, 5-pair Marking BIX Distribution Connector, 4-pair Marking Multiplying Connector BIX Multiplying Connector, QCBIX2A, 25-pair, 12x2-pair BIX Multiplying Connector, QCBIX5A, 25-pair, 5x5-pair BIX Multiplying Connector, QCBIX7A, 25-pair, 2x2-pair & 3x7-pair Modular Jack Connector BIX Modular Jack Connector, NXXCBMC6U, 6-port, PS5E, T568A/B Coded BIX Modular Jack Connector, QCBIX36D, 6-port, USOC, 8-pin BIX Modular Jack Connector, QCBIX36C, 8-port, USOC, 6-pin BIX Modular Jack Connector, QCBIX36B, 12-port, USOC, 4-pin A0266828 A0393146 A0269923 A0266827 A0269925 AX100798 A0341173 A0330864 A0330863 These products are in the process of being assessed for RoHS compliance. Please check our Web Site for the most current RoHS status. F o r m o r e i n f o r m a t i o n , c o n t a c t B e l d e n Te c h n i c a l S u p p o r t : 1 - 8 0 0 - B E L D E N - 1 • w w w . b e l d e n . c o m 15 • Networking — Copper The QCBIX5A Connector is built using 10 sets of bridged clips (5 clips each). It is used for multiple jumper connections to the same equipment. C O M M E R C I A L N E T W O R K I N G — C O P P E R 15.14 BIX Cross-Connect System Mounts, Covers and Wire Management Accessories A0340836 QMBIX12E BIX Mount, 300-pair BIX Mount BIX Mounts are basic components used in building a cross-connect system. They can accept BIX Distribution, Multiplying or Modular Jack Connectors. The 300 and 250-pair mounts can be wall-mounted or installed on BIX Frames. These mounts feature an interlocking design allowing them to be stacked for larger cross-connect installations. The BIX 50-pair Mount is typically used in small cross-connect installations. Also available is a 50-pair mount with cover that is sold as an assembly and is typically used in small cross-connect installations where security and/or dust protection is required. BIX Cover A0284798 QMBIX10C BIX Mount, 50-pair BIX Covers can be used to restrict access of cross-connect installations for better protection and security. Two sizes are available to suit either the QMBIX12E 300-pair mount or the QMBIX10A 250-pair mount. The two locking covers used in wall or frame-mounted installations are molded with translucent plastic allowing visual inspection. Also available are two covers used exclusively in stand-alone QMBIX10A 250-pair mount installations: one locking, the other non-locking—both have four cable entries, one at each corner. Distribution Ring A0277853 QMBIX31A 50-pair Mount with Locking Cover The Distribution Ring is used in wall mount installations providing a cross-connect channel for jumper wires, patch cords and cables. The Distribution Ring interlocks with the QMBIX12E or QMBIX10A mounts, providing proper spacing and alignment. Description A0285986 Locking Cover for 250-pair Mount A0276396 BIX Cover, QMBIX10A, Stand-alone installation, Locking Belden Part Number BIX Cross-Connect System BIX Mount BIX Mount, QMBIX12E (300-pair) BIX Mount, QMBIX10A (250-pair) BIX Mount, QMBIX10C (50-pair) BIX Mount with Cover BIX Mount with Cover, (Locking), 50-pair BIX Mount with Cover, (Snap-on), 50-pair BIX Locking Cover BIX Locking Cover, for QMBIX12E (300-pair) BIX Locking Cover, for QMBIX10A (250-pair) BIX Cover BIX Cover, QMBIX10A, Stand-alone installation, locking BIX Cover, QMBIX10A, Stand-alone installation, non-locking Distribution Ring Distribution Ring A0340836 A0270164 A0284798 A0277853 A0277854 A0340838 A0285986 A0276396 A0276394 A0270168 These products are in the process of being assessed for RoHS compliance. Please check our Web Site for the most current RoHS status. A0270168 Distribution Ring F o r m o r e i n f o r m a t i o n , c o n t a c t B e l d e n Te c h n i c a l S u p p o r t : 1 - 8 0 0 - B E L D E N - 1 • w w w . b e l d e n . c o m C O M M E R C I A L N E T W O R K I N G — C O P P E R 15.15 BIX Cross-Connect System BIX Distribution Frames, Universal BIX-PAC and Trunk Access Blocks BIX Distribution Frame A0340837 BIX Frame BIX Distribution Frames provide a compact mounting unit for large cross-connect installations. The QFBIX24E BIX Frame can accommodate up to 16 QMBIX12E 300-pair mounts, eight on the vertical side and eight on the horizontal side. The QFBIX24E BIX Frame has a capacity of 4800-pair. The QFBIX24A BIX Frame can accommodate up to 16 QMBIX10A 250-pair mounts, eight on the vertical side and eight on the horizontal side. The QFBIX24A BIX Frame has a capacity of 4000-pair. The BIX Frame End Kit consists of eight cable trays and eight distribution rings plus appropriate mounting hardware. One kit is required to support cross-connect wires on the sides of the shelves in a singleframe installation or on the end frames of a multi-frame installation. The Distribution Rings are plastic rings used to manage cross-connect wires. A0321776 Universal BIX-PAC Version 10-10 The Universal BIX-PAC provides a fast, factory-wired, pre-tested and easy-to-install method of terminating wiring for the voice environment. A typical application for this product is in the main distribution terminal system or the riser terminal system, where it can provide connectivity and cross-connection for up to 250 pairs. The units come equipped with up to 10 QCBIX1A Connectors and 10 fifty-pin type telco connectors for the termination of connectorized cables. Also available is a BIX-PAC Enclosure, which is a fire-retardant polystyrene structural foam box that can house one BIX-PAC. The enclosure has a snap-on cover and removable panels for cable entry on top, bottom and sides. BIX Trunk Access Block BIX Trunk Access Blocks provide a fast, factory-wired, pre-tested and easy-to-install method for demarcation or testing points on customer premises. Typical applications are in the building entrance system or the main distribution terminal system, where the demarcation point between the network provider and the customer equipment usually can be found. Description Belden Part Number BIX Cross-Connect System BIX Distribution Frame BIX Distribution Frame, 4800-pair (4 Shelves for 16 Mounts, 300-pair) A0340837 BIX Distribution Frame, 4000-pair (4 Shelves for 16 Mounts, 250-pair) A0275511 BIX Distribution Frame Accessories BIX Distribution Frame Accessories, End Kit (4 Shelves) A0275512* BIX Distribution Frame Accessories, Distribution Ring P0596540* Universal BIX-PAC Universal BIX-PAC, 10-8, 8 RJ21X Female to 8 QCBIX1A Connectors A0321775 Universal BIX-PAC, 10-10, 10 RJ21X Female to 10 QCBIX1A Connectors A0321776 BIX PAC Enclosure BIX PAC Enclosure, Gray A0318897 BIX Trunk Access Block BIX Trunk Access Block, 1 RJ21X Female to 1 QCBIX1A Connector A0327325 BIX Trunk Access Block, 2 RJ21X Female to 2 QCBIX1A Connector A0327326 *Eight Distribution Rings come as part of the BIX Distribution Frame End Kit. Additional Distribution Rings can be ordered separately. A0318897 BIX PAC Enclosure A0327326 BIX Trunk Access Block Use (1) end kit per row of frames. These products are in the process of being assessed for RoHS compliance. Please check our Web Site for the most current RoHS status. F o r m o r e i n f o r m a t i o n , c o n t a c t B e l d e n Te c h n i c a l S u p p o r t : 1 - 8 0 0 - B E L D E N - 1 • w w w . b e l d e n . c o m 15 • Networking — Copper Universal BIX-PAC C O M M E R C I A L N E T W O R K I N G — C O P P E R 15.16 BIX Cross-Connect System BIX Patch Cords and B-Plus Cross-Connect Wire A0410494 BIX Patch Cord, BIX-BIX, 2-pair BIX Patch Cords BIX Patch Cords allow for high-density connections, coupled with flexibility for cost-effective installation and administration. Installation and rearrangement of patch cords do not require any special tools or training. BIX Patch Cord plugs terminate directly into QCBIX1A/1A4 connectors. B-Plus Cross-Connect Wire B-Plus Cross-Connect Wire is intended primarily for use between incoming cables and station equipment in a Telecommunications Room or at a Main Cross-Connect. Z Cross-Connect Wire is intended primarily for use in voice applications such as cross-connecting PBX or Key Telephone system equipment to backbone or horizontal distribution cables. A0410469 BIX Patch Cord, BIX-BIX, 1-pair Description Belden Part Number BIX Cross-Connect System 22208260 B-Plus Cross-Connect Wire BIX Patch Cord BIX Patch Cord, BIX-BIX, 2-pair, 1.2 m (4 ft.) BIX Patch Cord, BIX-BIX, 1-pair, 1.2 m (4 ft.) BIX Patch Cord, BIX-BIX, 2-pair, 2.1 m (7 ft.) BIX Patch Cord, BIX-BIX, 1-pair, 2.1 m (7 ft.) BIX Patch Cord, BIX-BIX, 2-pair, 3.0 m (10 ft.) BIX Patch Cord, BIX-BIX, 1-pair, 3.0 m (10 ft.) BIX Patch Cord, BIX-BIX, 2-pair, 4.6 m (15 ft.) BIX Patch Cord, BIX-BIX, 1-pair, 4.6 m (15 ft.) BIX Patch Cord, BIX-BIX, 1-pair, 7.6 m (25 ft.) A0410494 A0410469 A0410495 A0410471 A0410496 A0410473 A0410497 A0410475 A0410493 For 4-pair connections, please see the GigaBIX Patch Cord section. B-Plus Cross-Connect Wire 24 AWG, 1-pair, Wh/Bl, 305 m (1000 ft.), K-Carton 24 AWG, 1-pair, Wh/Bl, 305 m (1000 ft.), Spool (S77) 24 AWG, 2-pair, Wh/Bl/Wh/Or, 305 m (1000 ft.), K-Carton 24 AWG, 2-pair, Wh/Gr/Wh/Or, 305 m (1000 ft.), K-Carton 24 AWG, 3-pair, Wh/Bl/Wh/Or/Wh/Gr, 152 m (500 ft.), K-Carton 24 AWG, 3-pair, Wh/Bl/Wh/Or/Wh/Gr, 200 m, K-Carton 24 AWG, 4-pair, Wh/Bl/Wh/Or/Wh/Gr/Wh/Br, 152 m (500 ft.), K-Carton Z Cross-Connect Wire Z Cross-Connect Wire, 24 AWG, 1-pair, Bl/Ye, 300 m (984 ft.), Spool Z Cross-Connect Wire, 24 AWG, 1-pair, Bl/Rd, 300 m (984 ft.), Spool 22208250 22208253 22208260 22208231 22208265 22208235 22208270 22208010 22208067 These products are in the process of being assessed for RoHS compliance. Please check our Web Site for the most current RoHS status. F o r m o r e i n f o r m a t i o n , c o n t a c t B e l d e n Te c h n i c a l S u p p o r t : 1 - 8 0 0 - B E L D E N - 1 • w w w . b e l d e n . c o m C O M M E R C I A L N E T W O R K I N G — C O P P E R 15.17 BIX Cross-Connect System BIX Tools, Testing Tools, Accessories and Designation Strip BIX Connecting Tool A0270165 BIX Connecting Tool The BIX Connecting Tool is the only tool required to terminate cables, pigtails or jumper wires on all GigaBIX and BIX connection products. The BIX Connecting Tool is a spring-activated hand tool. A single forward movement will seat the wire into the BIX IDC clip and cut off the excess wire. The tool will terminate 22-26-AWG plastic insulated solid copper conductors. A separate leather BIX Tool Pouch to carry and protect the BIX Tool can be ordered. BIX Test Probe Tool in CUT position Tool in NO CUT position The BIX Test Probe is a single-pair probe that clips onto the termination clip of BIX Distribution or BIX Modular Jack Connectors to facilitate testing. BIX Accessories The BIX Bridging Clip is a single-pair clip used to bridge single-pair connections of two BIX connectors. The BIX Wire Retainer is a plastic extrusion that fits over the terminated wires on a BIX Connector to prevent them from being pulled out of the IDC contacts. It can be used to secure a permanent connection on either side of a BIX Connector. A0270166 BIX Test Probe This 19 in. Rack Bracket Kit provides the hardware for BIX Mount installation into a 19 in. rack. This kit comes complete with two mounting bars, four screws for rack mounting, four screws for BIX Mount assemblies and an installation guide. BIX Cable Ties are used for securing wire bundles to the BIX Connector. BIX Designation Strip A0270172 Special Service Guard The BIX Designation Strip is designed to be used in conjunction with all BIX Mounts and BIX Connectors. It snaps in between two connectors and provides space for self adhesive BIX labels. The strip is made of white fire-retardant plastic, with ridges on the top and bottom for easy alignment and placement of designation labels. (See the LabelFlex section for designation labels.) Description A0325493 Bridging Clip Belden Part Number BIX Cross-Connect System BIX Tools BIX Connecting Tool Tool Pouch BIX Test Probe BIX Test Probe, 1-pair, 1/pack BIX Accessories BIX Special Service Guard, 1-pair, Red, 50/pack BIX Bridging Clip, 1-pair, Gray, 50/pack BIX Bridging Clip, 1-pair, White, 50/pack BIX Wire Retainer, 100/pack 19 in. Rack Bracket Kit, 2 bars/pack BIX Cable Tie, 100/pack BIX Designation Strip BIX Designation Strip, White, 50/pack P0660798 BIX Wire Retainer C0039222 BIX Cable Tie A0352331 19 in. Rack Bracket Kit A0270165 C0054642 A0270166 A0270172 A0325091 A0325493 P0660798 A0352331 C0039222 A0270169 These products are in the process of being assessed for RoHS compliance. Please check our Web Site for the most current RoHS status. A0270169 BIX Designation Strip F o r m o r e i n f o r m a t i o n , c o n t a c t B e l d e n Te c h n i c a l S u p p o r t : 1 - 8 0 0 - B E L D E N - 1 • w w w . b e l d e n . c o m 15 • Networking — Copper The BIX Special Service Guard is a single-pair red plastic clip used to identify a connection within a BIX distribution field that requires special attention prior to any maintenance work. C0054642 Tool Pouch
A0266827 价格&库存
很抱歉,暂时无法提供与“A0266827”相匹配的价格&库存,您可以联系我们找货
A0266827
    • 1+178.466861+22.32975
