Detailed Specifications & Technical Data
METRIC MEASUREMENT VERSION
AX104501 Modular Connectors - 10GX KeyConnect Shielded RJ45 Coupler
For more Information
please call
1-800-Belden1
General Description:
10GX Shielded RJ45 Coupler, Category 6A, KeyConnect, Gray
Usage (Overall)
Suitable Applications:
IBDN Shielded System 10GX, TIA Category 6A, 10GBASE-T
Related Parts:
KeyConnect Shielded Modular Patch Panel, 10GX Shielded Patch Cord, 10GX Shielded Pre-Terminated
Cable Assembly
Multi Conductor
Physical Characteristics
Overall Cabling
Overall Diameter
Physical Characteristics (Connectivity)
Dimensions
Dimensions:
Height (mm) Width (mm) Depth (mm)
22.581
16.205
38.506
Materials
Materials:
Description
Type
Material
Front Connection Flexible PCB Flexible PCB with 50u inch Gold over Nickel
Rear Connection Flexible PCB Flexible PCB with 50u inch Gold over Nickel
Connector Body
Metal
Color
Color:
Gray
Wiring Scheme
Wiring Scheme:
T568A/B-T568A/B
Weight
Weight:
0.022 kg
Packaging
Packaging:
Individually packaged in a clear plastic bag.
Mechanical Characteristics (Connectivity)
Footprint/Type:
KeyConnect
Plug / Jack Compatibility:
RJ45
Termination Interface:
Termination Connection
Durabilities
Front
Mated Connection 750 cycles
Rear
Connector/Hardware Retention:
88.964 N
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
Other Standards:
FCC Part 68, Subpart F, IEC 60603-7
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
08/01/2008
MII Order #39 (China RoHS):
EUP 50
Telecommunications Standards:
Category 6A - TIA 568.C.2, Class EA - ISO/IEC 11801:2002 Amendment 2
Safety Listing:
Bi-national Standard Listed
Suitability
Page 1 of 3
07-31-2017
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Transmission Characteristics (Connectivity)
Mated Connection Table 1:
Max.
Min.
Min.
Min.
Min.
Frequency Max.
Insertion Loss Insertion Loss NEXT
NEXT
FEXT
FEXT
(MHz)
TIA* (dB)
Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB)
1.000
0.100
0.100
75.000
75.000
75.000
75.000
4.000
0.100
0.100
75.000
75.000
71.100
75.000
8.000
0.100
0.100
75.000
75.000
65.000
69.000
10.000
0.100
0.100
74.000
75.000
63.100
67.100
16.000
0.100
0.100
69.900
70.920
59.000
63.000
20.000
0.100
0.100
68.000
68.980
57.100
61.100
25.000
0.100
0.100
66.000
67.040
55.100
59.100
31.250
0.110
0.110
64.100
65.100
53.200
57.200
62.500
0.160
0.160
58.100
59.080
47.200
51.200
100.000
0.200
0.200
54.000
55.000
43.100
47.100
200.000
0.280
0.280
48.000
48.980
37.100
41.100
250.000
0.320
0.320
46.000
47.040
35.100
39.100
300.000
0.350
0.350
42.900
43.870
33.600
37.600
400.000
0.400
0.400
37.900
38.880
31.100
35.100
500.000
0.450
0.450
34.000
35.000
29.100
33.100
625.000
0.500
31.120
31.200
Mated Connection Table - Footnote:
* TIA/EIA-568-C.2 Category 6A ** Worst-case performance for a 10GX mated connection using 10GX
modular plugs on both sides
Mated Connection Table 2:
Min.
Min.
Min.
Min.
Min.
Min.
Min.
Frequency Min.
Return Loss Return Loss PSANEXT PSANEXT
PSAACRF PSAACRF
Balanced TCL Balanced TCL
(MHz)
TIA* (dB)
Belden** (dB)
1.000
30.000
30.000
70.500
72.000
67.000
72.000
40.000
45.000
4.000
30.000
30.000
70.500
72.000
67.000
72.000
40.000
45.000
8.000
30.000
30.000
70.500
72.000
67.000
72.000
40.000
45.000
10.000
30.000
30.000
70.500
72.000
67.000
72.000
40.000
45.000
16.000
30.000
30.000
70.500
72.000
67.000
72.000
40.000
45.000
20.000
30.000
30.000
70.500
72.000
67.000
72.000
40.000
45.000
25.000
30.000
30.000
70.500
72.000
67.000
72.000
40.000
45.000
31.250
30.000
30.000
70.500
72.000
67.000
72.000
38.100
45.000
62.500
30.000
30.000
70.500
72.000
67.000
72.000
32.100
42.100
100.000
28.000
28.000
70.500
72.000
67.000
72.000
28.000
38.000
200.000
22.000
22.000
64.500
66.000
61.000
66.000
22.000
32.000
250.000
20.000
20.000
62.500
64.000
59.000
64.000
20.000
30.000
300.000
18.500
18.500
61.000
62.500
57.500
62.500
18.500
28.500
400.000
16.000
16.000
58.500
60.000
55.000
60.000
16.000
26.000
500.000
14.000
14.000
56.500
58.000
53.000
58.000
14.000
24.000
625.000
12.100
56.100
56.100
22.100
Dielectric Strength:
1,000 V RMS @ 60 Hz for 1 minute
Current Rating:
1.500 A
Insulation Resistance:
500 M-Ohm Minimum
Max. Contact Resistance:
20 m-Ohm
Notes (Overall)
Product Family
Put Ups and Colors:
Item #
Putup
Ship Weight
AX104501
1 EA
0.062 LB
Revision Number: 0
Color
Notes
Item Desc
10GX SHIELDED KEYCONNECT RJ45
Revision Date: 05-16-2011
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
Page 2 of 3
07-31-2017
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
07-31-2017
很抱歉,暂时无法提供与“AX104501”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+392.763301+49.25187
- 10+333.8303710+41.86178
- 25+312.9343925+39.24146
- 50+298.0074750+37.36965
- 100+283.79750100+35.58774
- 250+266.05518250+33.36288
