AX104552
AX104552
    BELDEN
    CAT6A PLUG TEST ADAPT
AX104552 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION AX104552 Modular Connectors - Field Mount Plug Test Adapter (Coupler) For more Information please call 1-800-Belden1 General Description: Field Mount Plug Test Adapter (Coupler) Usage (Overall) Suitable Applications: Use with Permanent Link Adapter to test a cable terminated with a male RJ45 connector (plug) Related Parts: Category 6A Field Mount Plugs, Cat 5e/Cat 6/Cat 6A Field Crimpable Plugs Multi Conductor Physical Characteristics Overall Cabling Overall Diameter Physical Characteristics (Connectivity) Dimensions Dimensions: Height (mm) Width (mm) Depth (mm) 22.581 16.205 38.506 Materials Materials: Description Type Material Front Connection Flexible PCB Flexible PCB with 50u inch Gold over Nickel Rear Connection Flexible PCB Flexible PCB with 50u inch Gold over Nickel Connector Body Metal Color Color: Gray Wiring Scheme Wiring Scheme: T568A/B-T568A/B Weight Weight: 0.022 kg Packaging Packaging: Individually packaged in a clear plastic bag. Mechanical Characteristics (Connectivity) Footprint/Type: KeyConnect Plug / Jack Compatibility: RJ45 Termination Interface: Termination Connection Durabilities Front Mated Connection 1000 cycles Rear Mated Connection 1000 cycles Connector/Hardware Retention: 88.964 N Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 08/01/2008 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: Category 6A - TIA 568.C.2, Class EA - ISO/IEC 11801:2002 Amendment 2 Safety Listing: Bi-national Standard Listed Suitability Suitability - Indoor: Yes Page 1 of 2 07-31-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION AX104552 Modular Connectors - Field Mount Plug Test Adapter (Coupler) Plenum/Non-Plenum Transmission Characteristics (Connectivity) Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Notes (Overall) Notes: Selected items for Best Performance. Product Family Put Ups and Colors: Item # Putup Ship Weight AX104552 1 EA 0.062 LB Revision Number: 0 Color Notes Item Desc CAT6A PLUG TEST ADAPT Revision Date: 07-13-2015 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 07-31-2017
AX104552 价格&库存
很抱歉,暂时无法提供与“AX104552”相匹配的价格&库存,您可以联系我们找货
