MachFlex 375 YY Cables
Unshielded PVC Control Cables
Applications
Designed for applications which are installed in occasional flexing and fixed locations. Cable
applications include precision control sensors, multi axis control machines, temperature
controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control,
production machinery and many more.
General Reference Standards
DIN VDE 0295, IEC 60228, BS6360
DIN EN 50290-2-22, DIN VDE 0207-363-4-1
IEC 60227-5, EN 50525-2-51
DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2
RoHS & REACH & CE Directives
Construction and Performance
1.
Conductor Material
Stranded bare copper (DIN VDE 0295 Class 5)
2.
Insulation Material & Color
PVC (polyvinyl chloride). A) Up to 5 cores: color-coded.
From 6 cores: Belden MachFlex Color code. B) G = with GN-YE protective
conductor; X = without protective conductor.
3.
Braid Shield Material
Tinned Copper Braid Shield
4.
Jacket / Sheath Material
5.
Flame Retardancy
6.
Voltage Rating (Uo/U)
Up to 1.5 mm2: 300 / 500 V
From 2.5 mm2: 450 / 750 V
7.
Oil Resistant
DIN EN 50290-2-22 (TM54)
8.
Temperature Range
-5 °C TO +70 °C (Occasional movement)
-40 °C TO +80 °C (Fixed installation)
9.
Bending Radius
10 x OD (Occasional movement)
4 x OD (Fixed installation)
10.
Other Properties
Good UV resistance, chemical resistance & flexibility
MachFlex 375 YY Unshielded PVC Control Cables
UNSHIELDED CABLE WITH (G) PROTECTIVE GROUND
1 = Conductor
2 = Insulation
3 = Sheath
3
2
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
5.1
5.6
6.2
6.8
9.1
11.4
Conductor 0.75 mm2
Copper Weight
(kg/km)
14.40
19.20
24.00
33.60
58.00
96.70
EMEA
Part Code
C3GA
C4GA
C5GA
C7GA
C12GA
C20GA
APAC
Part Code
C3G0.5
C4G0.5
C5G0.5
C7G0.5
C12G0.5
C20G0.5
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
5.6
6.2
6.8
7.5
10.1
12.7
Copper Weight
(kg/km)
21.60
28.80
36.00
50.00
86.00
143.30
EMEA
Part Code
C3GB
C4GB
C5GB
C7GB
C12GB
C20GB
APAC
Part Code
C3G0.75
C4G0.75
C5G0.75
C7G0.75
C12G0.75
C20G0.75
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
6.1
28.80
4
6.7
38.40
5
7.4
48.00
7
8.1
67.00
12
10.9
115.00
192.00
Conductor 2.50 mm2
EMEA
Part Code
C3GC
C4GC
C5GC
C7GC
C12GC
C20GC
APAC
Part Code
C3G1.0
C4G1.0
C5G1.0
C7G1.0
C12G1.0
C20G1.0
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
6.6
43.00
4
7.3
58.00
5
8.1
72.00
7
8.9
101.00
12
12.0
173.00
288.30
Conductor 4.00 mm2
EMEA
Part Code
C3GD
C4GD
C5GD
C7GD
C12GD
C20GD
APAC
Part Code
C3G1.5
C4G1.5
C5G1.5
C7G1.5
C12G1.5
C20G1.5
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
9.8
72.00
4
10.9
96.00
5
12.0
120.00
7
13.3
168.00
9
16.6
216.00
12
18.1
288.00
Conductor 6.00 mm2
EMEA
Part Code
C3GE
C4GE
C5GE
C7GE
C9GE
C12GE
APAC
Part Code
C3G2.5
C4G2.5
C5G2.5
C7G2.5
C9G2.5
C12G2.5
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
11.3
115.00
4
12.6
154.00
5
13.9
192.00
7
15.4
269.00
9
19.3
345.90
12
21.0
461.00
Conductor 10.00 mm2
EMEA
Part Code
3GF
4GF
5GF
7GF
C9GF
C12GF
APAC
Part Code
C3G4
C4G4
C5G4
C7G4
C9G4
C12G4
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3GG
C4GG
C5GG
C7GG
C9GG
APAC
Part Code
C3G6
C4G6
C5G6
C7G6
C9G6
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3GH
C4GH
C5GH
C7GH
C9GH
APAC
Part Code
C3G10
C4G10
C5G10
C7G10
C9G10
EMEA
Part Code
C3GJ
C4GJ
C5GJ
APAC
Part Code
C3G25
C4G25
C5G25
Nom. Overall
Diameter (mm)
12.8
14.2
15.8
17.4
21.9
Copper Weight
(kg/km)
172.80
230.00
288.00
403.00
518.10
Conductor 16.00 mm2
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
19.6
21.9
24.3
Copper Weight
(kg/km)
460.50
614.00
768.00
Nom. Overall
Diameter (mm)
15.3
17.1
19.0
21.0
26.4
Copper Weight
(kg/km)
288.00
384.00
480.00
672.00
864.00
Conductor 25.00 mm2
EMEA
Part Code
C3GI
C4GI
C5GI
APAC
Part Code
C3G16
C4G16
C5G16
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
22.3
24.9
27.7
• Putup length & tolerance of the cables will vary depending on the construction of the cable
• MOQ will vary depending on the construction of the cable & provided at the time of quotation
• Cable requested outside the above design criteria can be reviewed and quoted
Copper Weight
(kg/km)
720.00
960.00
1,200.00
UNSHIELDED CABLE WITHOUT (G) PROTECTIVE GROUND
1 = Conductor
2 = Insulation
3 = Sheath
3
2
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
5.1
5.6
6.2
6.8
9.1
11.4
Conductor 0.75 mm2
Copper Weight
(kg/km)
14.40
19.20
24.00
33.60
58.00
96.70
EMEA
Part Code
C3XA
C4XA
C5XA
C7XA
C12XA
C20XA
APAC
Part Code
C3X0.5
C4X0.5
C5X0.5
C7X0.5
C12X0.5
C20X0.5
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
5.6
6.2
6.8
7.5
10.1
12.7
Copper Weight
(kg/km)
21.60
28.80
36.00
50.00
86.00
143.30
EMEA
Part Code
C3XB
C4XB
C5XB
C7XB
C12XB
C20XB
APAC
Part Code
C3X0.75
C4X0.75
C5X0.75
C7X0.75
C12X0.75
C20X0.75
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
6.1
28.80
4
6.7
38.40
5
7.4
48.00
7
8.1
67.00
12
10.9
115.00
192.00
Conductor 2.50 mm2
EMEA
Part Code
C3XC
C4XC
C5XC
C7XC
C12XC
C20XC
APAC
Part Code
C3X1.0
C4X1.0
C5X1.0
C7X1.0
C12X1.0
C20X1.0
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
6.6
43.00
4
7.3
58.00
5
8.1
72.00
7
8.9
101.00
12
12.0
173.00
288.30
Conductor 4.00 mm2
EMEA
Part Code
C3XD
C4XD
C5XD
C7XD
C12XD
C20XD
APAC
Part Code
C3X1.5
C4X1.5
C5X1.5
C7X1.5
C12X1.5
C20X1.5
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
9.8
72.00
4
10.9
96.00
5
12.0
120.00
7
13.3
168.00
9
16.6
216.00
12
18.1
288.00
Conductor 6.00 mm2
EMEA
Part Code
C3XE
C4XE
C5XE
C7XE
C9XE
C12XE
APAC
Part Code
C3X2.5
C4X2.5
C5X2.5
C7X2.5
C9X2.5
C12X2.5
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
11.3
115.00
4
12.6
154.00
5
13.9
192.00
7
15.4
269.00
9
19.3
345.90
12
21.0
461.00
Conductor 10.00 mm2
EMEA
Part Code
C3XF
C4XF
C5XF
C7XF
C9XF
C12XF
APAC
Part Code
C3X4
C4X4
C5X4
C7X4
C9X4
C12X4
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3XG
C4XG
C5XG
C7XG
C9XG
APAC
Part Code
C3X6
C4X6
C5X6
C7X6
C9X6
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3XH
C4XH
C5XH
C7XH
C9XH
APAC
Part Code
C3X10
C4X10
C5X10
C7X10
C9X10
EMEA
Part Code
C3XJ
C4XJ
C5XJ
APAC
Part Code
C3X25
C4X25
C5X25
Nom. Overall
Diameter (mm)
12.8
14.2
15.8
17.4
21.9
Copper Weight
(kg/km)
172.80
230.00
288.00
403.00
518.10
Conductor 16.00 mm2
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
19.6
21.9
24.3
Copper Weight
(kg/km)
460.50
614.00
768.00
Nom. Overall
Diameter (mm)
15.3
17.1
19.0
21.0
26.4
Copper Weight
(kg/km)
288.00
384.00
480.00
672.00
864.00
Conductor 25.00 mm2
EMEA
Part Code
C3XI
C4XI
C5XI
APAC
Part Code
C3X16
C4X16
C5X16
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
22.3
24.9
27.7
Copper Weight
(kg/km)
720.00
960.00
1,200.00
很抱歉,暂时无法提供与“C3GE-BC50”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+17.034421+2.20350
- 25+14.1516825+1.83060
- 50+12.6666250+1.63850
- 100+11.26893100+1.45770
- 国内价格
- 1+1139.18005
- 5+1080.56056
