Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
C501108025 Cable Assemblies - CAT5E Modular Cord
For more Information
please call
1-800-Belden1
General Description:
CAT5E Patch Cord, Bonded-Pair, 4 Pair, 24 AWG Solid, CMR, T568A/B-T568A/B, Gray, 25 ft. (7.6 m).
Usage (Overall)
Suitable Applications:
IBDN System 1200, TIA Category 5E, ISO Class D, 1000BASE-T, 100BASE-T
Related Parts:
CAT5E Modular Jacks, CAT5E Patch Panels
Multi Conductor
Physical Characteristics
Conductor
AWG:
# Pairs AWG Stranding Conductor Material
4
24
Solid
BC - Bare Copper
Insulation
Insulation Material:
Insulation Material
PO - Polyolefin
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Outer Jacket Color Code Chart:
Color
Gray
Overall Diameter
Overall Nominal Diameter:
0.208 in.
Individual Cable Diameter:
0.240 in.
Physical Characteristics (Connectivity)
Materials
Materials:
Description
Type
Material
Plug
RJ45
Polycarbonate
Boot
Rubber
Front Connection Blades Phosphor Bronze with 50u inch Gold over Nickel Plating
Color
Boot Color:
Translucent
Wiring Scheme
Wiring Scheme:
T568A/B
Weight
Weight:
0.060 lbs.
Packaging
Packaging:
Individually packaged in a clear plastic bag.
Mechanical Characteristics (Connectivity)
Plug / Jack Compatibility:
RJ45
Termination Interface:
Termination Connection
RJ45
Durabilities
Mated Connection 750 Cycles
Storage Temperature Range:
-40°C To +70°C
Installation Temperature Range:
-10°C To +60°C
Page 1 of 3
02-01-2017
Operating Temperature Range:
-10°C To +60°C
Max. Recommended Pull Tension:
25 lbs.
Min. Bend Radius (Overall Cable):
1.040 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
Riser
Other Standards:
FCC Part 68, Subpart F, IEC 60603-7
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2006
MII Order #39 (China RoHS):
EUP 50
Telecommunications Standards:
Category 5e - TIA 568.B.2, Category 5 - ISO/IEC 11801:2002 Ed.2
Safety Listing:
ACA, Bi-national Standard Listed
Suitability
Suitability - Indoor:
Yes
Transmission Characteristics (Connectivity)
Performance Table 1:
Max.
Min.
Min
Min.
Min.
Frequency Max.
Insertion Loss Insertion Loss PSNEXT PSNEXT
PSACRF PSACRF
(MHz)
TIA* (dB)
Belden (dB)
TIA* (dB) Belden (dB) TIA* (dB) Belden (dB)
1.000
2.400
2.000
62.300
65.300
60.800
60.800
4.000
4.900
4.000
53.300
56.300
48.800
48.800
8.000
6.900
5.700
48.800
51.800
42.700
42.700
10.000
7.800
6.400
47.300
50.300
40.800
40.800
16.000
9.900
8.100
44.200
47.300
36.700
36.700
20.000
11.100
9.200
42.800
45.800
34.800
34.800
25.000
12.500
10.300
41.300
44.300
32.800
32.800
31.250
14.100
11.600
39.900
42.900
30.900
30.900
62.500
20.400
16.800
35.400
38.400
24.900
24.900
100.000
26.400
21.700
32.300
35.300
20.800
20.800
160.000
28.200
32.300
Performance Table - Footnote:
16.700
100 Meter Cable Specifications - * TIA-EIA-568-B.2 Category 5e Standard -------- PSACRF is formally
PSELFEXT
Performance Table 2:
Min.
Min.
Frequency (MHz) Return Loss Return Loss
TIA* (dB)
Belden (dB)
1.000
20.000
20.000
4.000
23.000
23.000
8.000
24.500
24.500
10.000
25.000
25.000
16.000
25.000
25.000
20.000
25.000
25.000
25.000
24.200
25.000
31.250
23.300
25.000
62.500
20.700
25.000
100.000
19.000
20.000
160.000
19.000
Dielectric Strength:
1,000 V RMS @ 60 Hz for 1 minute
Current Rating:
1.500 A
Insulation Resistance:
500 M-Ohm Minimum
Max. Contact Resistance:
20 m-Ohm
Notes (Overall)
Product Family
Product List:
Length
Yellow
2 ft. (0.6 m)
C501104002 C501105002 C501106002 C501108002 C501109002 C501100002
Green
Blue
Gray
White
Black
4 ft. (1.2 m)
C501104004 C501105004 C501106004 C501108004 C501109004 C501100004
7 ft. (2.1 m)
C501104007 C501105007 C501106007 C501108007 C501109007 C501100007
10 ft. (3.0 m) C501104010 C501105010 C501106010 C501108010 C501109010 C501100010
Page 2 of 3
02-01-2017
15 ft. (4.6 m) C501104015 C501105015 C501106015 C501108015 C501109015 C501100015
25 ft. (7.6 m) C501104025 C501105025 C501106025 C501108025 C501109025 C501100025
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
C501108025
1 EA
0.580 LB
GRAY 1SR
Revision Number: 0
Notes
Item Desc
PATCHCORD BCAT5E CMR GRY 25FT
Revision Date: 06-08-2009
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
02-01-2017
很抱歉,暂时无法提供与“C501108025”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+172.436111+21.62321
- 10+146.5659410+18.37913
- 25+137.3871125+17.22812
- 50+130.8299950+16.40587
- 100+124.58908100+15.62327
- 250+116.79537250+14.64595
- 500+111.22752500+13.94775
