Part Number: 10GX UTP LSZH PATCH CORDS
10GX Patch Cord UTP LSZH
Product Description
10GX Copper Patch Cord UTP LSZH
Technical Specifications
Product Overview
Environmental Space:
Indoor Rated (Not Riser or Plenum)
Suitable Applications:
Horizontal and building cabling. Support current and future Category 6a and 6 applications, such as: 10GBase-T (10 Gigabit Ethernet), 1000Base-T (Gigabit Ethernet),
100 Base-T, 10 Base-T, FDDI, ATM
Physical Characteristics (Overall)
Conductor
AWG Stranding Material Nominal Diameter No. of Pairs
26
Stranded
Copper
6.1 mm
4
Total Number of Pairs:
4
Conductor Size:
26 AWG
Insulation
Material
FPE - Foamed Polyethylene
Inner Shield Material
Element
Type
Material
Floating shielded pair Tape Laminated aluminum-polyester
Inner Jacket Material
Material
No inner Jacket
Outer Shield Material
Type
Material
Coverage [%]
Braid (Floating) TC - Tinned Copper 30 %
Outer Jacket Material
Material
Nominal Diameter
LSZH - Low Smoke Zero Halogen 6.1 mm
Wiring Scheme:
T568A/B-T568A/B
Packaging:
Individually packaged in a clear plastic bag.
Connectors
Materials
Description
Material
Type
Plug
Polycarbonate
RJ45
Boot
PVC
Snagless
Front Connection Phosphor Bronze with 50u inch Gold over Nickel Plating Blades
Electrical Characteristics
Dielectric Strength:
2.5 kV DC
Current Rating:
1A
Insulation Resistance:
5000 MOhm*km
Max Contact Resistance:
20 mOhm
Voltage
Voltage Rating [V]
72 V DC
Performance Footnote1:
There is 1dB margin on NEXT and RL guaranteed compared to ISO/IEC 11801-1:2017
Performance Footnote2:
The performance data below 4Mhz or above 500Mhz are for information only.
Temperature Range
Installation Temp Range:
0°C To +50°C
Operating Temp Range:
-20°C to +60°C
Mechanical Characteristics
Min Bend Radius (Overall Cable):
25 mm
Plug /Jack Compatibility:
RJ45
Termination Interface
Termination
RJ45
Connection
Durabilities
Mated Connection 750 Cycles
Standards
ISO/IEC Compliance:
Data Category:
Category 6A
Telecommunications Standards:
ISO/IEC 11801-1:2017; EN 50173-1 Amd 1 Caregory 6A; ANSI/TIA/EIA 568 C.2 Category 6A
Applicable Environmental and Other Programs
EU RoHS Compliance Date
(yyyy-mm-dd):
2013-01-25
Suitability
Suitability - Indoor:
Yes
Part Number
Related Parts:
10GX Modular Jacks, 10GX Patch Panels
Variants
Item #
Color
Length
CA24100001M Black
1m
CA24100002M Black
2m
CA24100003M Black
3m
CA24100005M Black
5m
CA24100007M Black
7m
CA24100010M Black
10 m
CA24100015M Black
15 m
CA241000D5M Black
0.5 m
CA24106001M Blue
1m
CA24106002M Blue
2m
CA24106003M Blue
3m
CA24106004M Blue
4m
CA24106005M Blue
5m
CA24106006M Blue
6m
CA24106010M Blue
10 m
CA24106015M Blue
15 m
CA24106016M Blue
16 m
CA241060D5M Blue
0.5 m
CA241060D3M Blue
0.3 m
CA24106020M Blue
20 m
CA24108001M Gray
1m
CA24108002M Gray
2m
CA24108003M Gray
3m
CA24108005M Gray
5m
CA24108007M Gray
7m
CA24108010M Gray
10 m
CA24108012M Gray
12 m
CA24108015M Gray
15 m
CA24108016M Gray
16 m
CA24108020M Gray
20 m
CA24108050M Gray
50 m
CA241080D5M Gray
0.5 m
CA241084D6M Gray
4.6 m
CA24105001M Green
1m
CA24105002M Green
2m
CA24105003M Green
3m
CA24105005M Green
5m
CA24105010M Green
10 m
CA24105016M Green
16 m
CA241050D5M Green
0.5 m
CA24103001M Orange 1 m
CA24103002M Orange 2 m
CA24103003M Orange 3 m
CA24103005M Orange 5 m
CA24103010M Orange 10 m
CA24102001M Red
1m
CA24102002M Red
2m
CA24102003M Red
3m
CA24102005M Red
5m
CA24102010M Red
10 m
CA24102015M Red
15 m
CA24102016M Red
16 m
CA241020D5M Red
0.5 m
CA24107001M Violet
1m
CA24107002M Violet
2m
CA24107003M Violet
3m
CA24107005M Violet
5m
CA24107010M Violet
10 m
CA24109001M White
1m
CA24109002M White
2m
CA24109003M White
3m
CA24109005M White
5m
CA24109010M White
10 m
CA241090D5M White
0.5 m
CA24104001M Yellow
1m
CA24104002M Yellow
2m
CA24104003M Yellow
3m
CA24104005M Yellow
5m
CA24104010M Yellow
10 m
CA241040D5M Yellow
0.5 m
© 2019 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief
at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product
Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and
regulations based on their individual usage of the product.
很抱歉,暂时无法提供与“CA24106001M”相匹配的价格&库存,您可以联系我们找货
