10GX24 0041000
10GX24 0041000
    BELDEN
    BELDEN - 10GX24 0041000 - UNSHLD NTWRK CABLE, 4PAIR, 23AWG, 1000FT
10GX24 0041000 数据手册
Part Number: 10GX24 CAT6A 10GX, 4pr, UTP, LSZH Jkt Product Description CAT6A (625MHz), 4-Pair, U/UTP-unshielded, Zero Halogen, Premise Horizontal cable, 23 AWG solid bare copper conductors, polyolefin insulation, patented Double-H spline, ripcord, LSZH jacket Technical Specifications Product Overview Premise Horizontal Cable, 10 Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU Digital Audio, AES51, RS-422, Noisy Environments, PoE Suitable Applications: Physical Characteristics (Overall) Conductor AWG Stranding 23 Solid Material No. of Pairs BC - Bare Copper 4 Conductor Count: 8 Total Number of Pairs: 4 Insulation Material PO - Polyolefin Bonded-Pair: N/A Color Chart Number Color 1 White & Blue 2 White & Orange 3 White & Green 4 White & Brown Outer Jacket Material Material Material Trade Name Nominal Diameter Ripcord LSZH - Low Smoke Zero Halogen Haloarrest® 0.295 in Yes Electrical Characteristics Conductor DCR Max. Conductor DCR Max. DCR Unbalance Max DCR Unbalanced Between Pairs [%] 74 Ohm/km 3% 5% Capacitance Max. Capacitance Unbalance Nom.Mutual Capacitance 330 pF/100m 17 pF/ft Delay Frequency [MHz] 100 MHz Max. Delay Max. Delay Skew Nominal Velocity of Propagation (VP) [%] 537.6 ns/100m 45 ns/100m 64 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) Min. PSNEXT [dB] Min. PSACR [dB] Min. PSACRF (PSELFEXT) [dB] Min. RL (Return Loss) [dB] Max./Min. Input Impedance (unFitted) Max./Min. Fitted Impedance Min. PSANEXT Min. PSAACRF Min. Min. TCL [dB] ELTCTL [dB] 1 MHz 2.1 dB/100m 73.3 dB 71.2 dB 68.8 dB 20.0 dB 100 ± 15 Ohm 100 ± 15 Ohm 67.0 dB 67.0 dB 40.0 dB 35.0 dB 4 MHz 3.8 dB/100m 64.3 dB 60.5 dB 56.8 dB 23.0 dB 100 ± 15 Ohm 100 ± 10 Ohm 67.0 dB 67.0 dB 40.0 dB 23.0 dB 8 MHz 5.3 dB/100m 59.8 dB 54.4 dB 50.7 dB 24.5 dB 100 ± 15 Ohm 100 ± 10 Ohm 67.0 dB 61.1 dB 40.0 dB 16.9 dB 10 MHz 5.9 dB/100m 58.3 dB 52.4 dB 48.8 dB 25.0 dB 100 ± 15 Ohm 100 ± 10 Ohm 67.0 dB 59.2 dB 40.0 dB 15.0 dB 16 MHz 7.5 dB/100m 55.2 dB 47.8 dB 44.7 dB 25.0 dB 100 ± 15 Ohm 100 ± 10 Ohm 67.0 dB 55.1 dB 40.0 dB 10.9 dB 20 MHz 8.4 dB/100m 53.8 dB 45.4 dB 42.8 dB 25.0 dB 100 ± 15 Ohm 100 ± 10 Ohm 67.0 dB 53.2 dB 38.0 dB 9.0 dB 25 MHz 9.4 dB/100m 52.3 dB 43.0 dB 40.8 dB 24.3 dB 100 ± 15 Ohm 100 ± 10 Ohm 67.0 dB 51.2 dB 36.0 dB 7.0 dB 31.25 MHz 10.5 dB/100m 50.9 dB 40.4 dB 38.9 dB 23.6 dB 100 ± 15 Ohm 100 ± 10 Ohm 67.0 dB 49.3 dB 35.1 dB 62.5 MHz 15.0 dB/100m 46.4 dB 31.4 dB 32.9 dB 21.5 dB 100 ± 15 Ohm 100 ± 10 Ohm 66.6 dB 43.3 dB 32.0 dB 100 MHz 19.1 dB/100m 43.3 dB 24.2 dB 28.8 dB 20.1 dB 100 ± 15 Ohm 100 ± 10 Ohm 63.5 dB 39.2 dB 30.0 dB 200 MHz 27.6 dB/100m 38.8 dB 11.2 dB 22.8 dB 18.0 dB 100 ± 22 Ohm 100 ± 10 Ohm 59.0 dB 33.2 dB 27.0 dB 250 MHz 31.1 dB/100m 37.3 dB 6.3 dB 20.8 dB 17.3 dB 100 ± 32 Ohm 100 ± 10 Ohm 57.5 dB 31.2 dB 26.0 dB 300 MHz 34.3 dB/100m 36.1 dB 1.9 dB 19.3 dB 16.8 dB 100 ± 32 Ohm 100 ± 10 Ohm 56.3 dB 29.7 dB 25.2 dB 350 MHz 37.2 dB/100m 35.1 dB 17.9 dB 16.3 dB 100 ± 32 Ohm 100 ± 10 Ohm 55.3 dB 28.3 dB 24.6 dB 400 MHz 40.1 dB/100m 34.3 dB 16.8 dB 15.9 dB 100 ± 32 Ohm 100 ± 10 Ohm 54.5 dB 27.2 dB 24.0 dB 450 MHz 42.7 dB/100m 33.5 dB 15.7 dB 15.5 dB 100 ± 32 Ohm 100 ± 10 Ohm 53.7 dB 26.1 dB 23.5 dB 500 MHz 45.3 dB/100m 32.8 dB 14.8 dB 15.2 dB 100 ± 32 Ohm 100 ± 10 Ohm 53.0 dB 25.2 dB 23.0 dB 550 MHz 47.7 dB/100m 32.2 dB 14.0 dB 14.9 dB 100 ± 32 Ohm 100 ± 10 Ohm 52.4 dB 24.4 dB 600 MHz 50.1 dB/100m 31.6 dB 13.2 dB 14.7 dB 100 ± 32 Ohm 100 ± 10 Ohm 51.8 dB 23.6 dB 625 MHz 51.2 dB/100m 31.4 dB 12.9 dB 14.5 dB 100 ± 32 Ohm 100 ± 10 Ohm 51.6 dB 23.3 dB 750 MHz 56.7 dB/100m 30.2 dB 11.3 dB 14.0 dB 50.4 dB 21.7 dB 860 MHz 61.2 dB/100m 29.3 dB 10.1 dB 13.6 dB 49.5 dB 20.5 dB Segregation class according EN50174-2: a Voltage UL Voltage Rating 300 V RMS Temperature Range Installation Temp Range: +5°C To +50°C Non-UL Temp Rating: +75°C Storage Temp Range: -20°C To +75°C Operating Temp Range: -20°C To +75°C Mechanical Characteristics Bulk Cable Weight: 35 lbs/1000ft Max Recommended Pulling Tension: 25 lbs Min Bend Radius During Installation: 3.0 in Min Bend Radius/Minor Axis: 1.25 in Standards NEC/(UL) Specification: N/A ISO/IEC Compliance: 11801 ed 2.2 (2011) Class EA CPR Euroclass: Eca Data Category: Category 6A ANSI Compliance: S-116-732-2013 Category 6A, ANSI/NEMA WC-66 Category 6A Telecommunications Standards: ANSI/TIA-568-C.2 Category 6A IEEE Specification: IEEE 802.3bt Type 1, Type 2, Type 3, Type 4 Other Specification: Verified Channel/Category 6A Applicable Environmental and Other Programs Environmental Space: LSZH EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: Yes EU CE Mark: No EU REACH SVHC Compliance (yyyy-mm-dd): 2017-07-10 EU RoHS Compliance Date (yyyy-mm-dd): 2009-06-11 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Aerial: No Suitability - Burial: No Suitability - Hazardous Locations: No Suitability - Indoor: Yes Suitability - Non-Halogenated: Yes Suitability - Oil Resistance: No Suitability - Outdoor: No Suitability - Sunlight Resistance: No Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1-2 UL voltage rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 10GX13 Part Number Non-Plenum Number: 10GX12 Variants Item # Color 10GX24.10305 Black 10GX24.06305 Blue 10GX24 0061000 Blue UPC Length 305 m 305 m 612825061854 1,000 ft 10GX24.K6305 Blue 305 m 10GX24.08305 Gray 305 m 10GX24.K8305 Gray 305 m 10GX24.08500 Gray 500 m 10GX24.K5305 Green 305 m 10GX24.071000 Purple 1,000 m 10GX24.07305 Purple 305 m 10GX24 0071000 Purple 612825061830 1,000 ft 10GX24.07500 Purple 500 m 10GX24.K7305 Purple 305 m 10GX24.K71000 Purple 1,000 m 10GX24.09305 White 10GX24 0091000 White 305 m 612825061847 1,000 ft 10GX24.09500 White 500 m 10GX24.04305 Yellow 305 m 10GX24 0041000 Yellow 612825061861 1,000 ft 10GX24.K4305 Yellow 305 m 10GX24.041525 Yellow 1,525 m Patent: https://www.belden.com/resources/patents Product Notes Notes: Values above 625 MHz are for Engineering Information Only. 0.295" Cable Dimension per TIA 6@1 Equivalent Diameter. Print Includes Descending Footage/Meter Markings from Max. Put-Up Length to 0. History Update and Revision: Revision Number: 0.380 Revision Date: 08-22-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
10GX24 0041000 价格&库存
很抱歉,暂时无法提供与“10GX24 0041000”相匹配的价格&库存,您可以联系我们找货
