11221.
11221.
    BELDEN
    BELDEN - 11221. - Sensor Connector, M12, Female, 5 Positions, Screw Socket, Straight Cable Mount
11221. 数据手册
New Product Bulletin PB 327 Lumberg Automation™ EtherNet/IP™ Modules for Industrial Automation Applications These 16 digital I/O channels with universal input/output functionality for direct connections between sensors/ actuators and control systems offer a high level of flexibility. Easy, Fast and Secure Operations with the New Ethernet/IP Modules from the LioN-M Series are Particularly Suitable for Use in Mechanical Engineering, Materials Handling and Filling and Packaging Systems. EtherNet/IP is one of the most important network standards in the field of automation. These two new LioN-M I/O modules support the latest EtherNet/IP protocols and connect sensors and actuators directly to control systems. The I/O modules integrated dual-port switch facilitates a line topology as well as star topology. They also enable one to continue using existing communications structures, such as cable trays and energy chains, without modifying the physical layout, which leads to cost savings. These modules also facilitate a highavailability ring topology: if the connection goes down, the device level ring protocol (DLR) immediately, switches to an alternative ring segment without interrupting machinery operations. These two I/O modules provide 16 digital channels. In one version (16DI) the channels are used as inputs. The universal modules (16DIO universal) provide both 16 digital inputs and outputs – in any desired combination and without any need for individual parameterization. Accordingly, these modules offer a very high level of flexibility not only at the planning stage but also when making changes during commissioning or subsequent upgrades. In addition, the “easy diagnostic” concept with a diagnostic display for each I/O port enables one to pinpoint any fault. The same information is also available via the Ethernet/ IP protocol, facilitating detailed analysis on a centralized control and display system – without any need to configure the module. Thus, time-consuming error localization is outdated: minimizing downtimes and maintenance periods, while increasing the availability of installation. The color-coding of the individual plug-in connectors enables immediate recognition of the function of various sockets (fieldbus, power supply or I/O). At a glance, one can see which cable connection is required. The optimized arrangement of the M12 I/O sockets considerably simplifies the installation process – even T distributors can be installed with ease. Benefits: • High degree of flexibility • Functional stability • Ease of use • Reduces install and maintenance costs LioN-M I/O Modules from Lumberg Automation™ Connections at a Glance: The power supply, connected via two gray four-pole 7/8” sockets, has a rated voltage of 24 V and a range of 11 to 30 V. The eight black I/O sockets, each of which can send and/or receive two digital signals, have five-pole A-coded M12 connectors. Each of these 16 digital channels has a rated output current of up to 1.6 A and a maximum current density of 9 A. The optimized arrangement of the M12 I/O sockets considerably simplifies the installation process, permitting the ease of installation of Tee-distributors. The two network ports have four-pole D-coded M12 connectors. To prevent confusion, the network ports – like the casing of the EtherNet/IP cables – are marked in green. The IP address can conveniently be set up using rotary switches. The I/O modules are configured directly via the user interface of the control unit. You can download the necessary base data from “www.lumberg-automtion.com”. The I/O modules are remarkable for their strong PBT (polybutylene terephthalate) housings and measure 243L x 60W x 39.5H mm, including the sockets for the power supply. They also fulfill the requirements for an ingress protection rating of IP 67 and are designed for use within the temperature range -10°C to +60°C. The Advantages at a Glance: • Connection of sensors and actuators to EtherNet/IP networks • Integrated dual-port switch (10/100 Mbit/s) facilitates line topology These new Ethernet/IP I/O modules fully support the device level ring (DLR) protocol and permit both ring and line topologies. • Ring topology by means of the device level ring protocol • 16 digital channels, either as inputs (0980 ESL 711) or universally as inputs and/or outputs (980 ESL 710) • M12 connections for network ports and I/O sockets • Fail-safe connections - color coding of network ports • Rotary switches for easy IP address selection • Configuration via the control system’s user interface • Strong and compact PBT housing • Ingress protection rating IP67 • Temperature range -10°C to +60°C • Power supply with voltage rating of 24 V • Flexible front or side mounting 2 Be Certain with Belden EtherNet/IP I/O Modules with 16 Digital Inputs and 16 Digital Outputs 16 IN / 16 OUT (universal) 0980 ESL 710 EtherNet/IP Device with 16 digital I/O channels, channels can be used universally as inputs or outputs, M12 socket, rotary address switches for addressing, M12 LAN-Ports, D-coded, 7/8” power supply. Bit Assignment Bit 7 6 Diagnostic Indication 5 4 3 2 1 0 M12 Input Byte 0 4B 4A 3B 3A 2B 2A 1B 1A Byte 1 8B 8A 7B 7A 6B 6A 5B 5A M12 Output Byte 0 4B 4A 3B 3A 2B 2A 1B 1A Byte 1 8B 8A 7B 7A 6B 6A 5B 5A LED Indication Condition 1...8 A Yellow Channel status 1 1...8 DIA A Red Periphery fault 1... 8 B Yellow Channel status 2 1... 8 DIA B Red Periphery fault US Green Off Green Off Green Yellow flashing Green Yellow flashing Green Green flashing Red/Green flashing Red flashing Off Green Green flashing Red Red flashing Off Sensor power supply applied Sensor power supply missing Actuator power supply applied Actuator power supply missing Connected to an Ethernet device I/O device exchanging data Connected to an Ethernet device I/O device exchanging data Device is ready for operating Wrong configuration Self test is running Firmware update Device is off Connection to master exists IP address exists, but no connection to the master IP address is used by a different device Connection has timed out Device is off UL P1 Lnk/Act P2 Lnk/Act MS (Module status) NS (Network status) Pin Assignment LAN connection M12, D-Coded Power supply 7/8” 1 = TD+ 2 = RD+ 3 = TD4 = RD Housing = shielding The use of these products in aggressive media should be verified in each case. Technical modifications reserved. Input M12 1 = +24 V Actuators 2 = +24 V Logic/Sensors 3 = GND (0 V) Logic/Sensors 4 = GND (0 V) Actuators Housing = PE 1 = +24 V 2 = IN B 3 = GND (0 V) 4 = IN A 5 = earth Housing = FE 3 EtherNet/IP I/O Modules with 16 Digital Inputs and 16 Digital Outputs 0980 ESL 710 Technical Data Environmental Degree of Protection Operating Temperature Range IP 67 -10°C (+14°F) to +60°C (+140°F) Mechanical Weight Housing Material 380 g PBT Bus system EtherNet/IP Transmission Rate Address Range Rotary Address Switches Default Address 10/100 Mbs 0-255 0-255 0 System/Sensor Power Supply Rated Voltage Voltage Range Power Consumption Reverse Polarity Protection 24 V DC 11–30 V DC typ. 90 mA yes Input power supply Us Voltage range Sensor current Short-circuit proof Indication 19–30 V DC 200 mA (at Tamb 30°C) yes LED green Inputs Type 3, IEC 61131-3 Rated Input Voltage Channel Type N.O. Number of Digital Channels Channel Status Indicator Diagnostic Indication 24 V DC p-switching max. 16 LED yellow per channel LED red per socket Part Number 0980 ESL 710 The application of these products in harsh environments should always be checked before use. Specifications subject to alteration. 4 Output power supply UL Rated Voltage Voltage Range Reverse Polarity Protection Indication 24 V DC 19–30 V DC yes/antiparallel diode LED green Outputs Rated Output Current Short-circuit Proof Max. Output Current Overload-proof Number of Digital Channels Channel Type N.O. Channel Status Indicator Diagnostic Indication 1.6 A per channel yes 9 A (12 A) per module yes max. 16 p-switching LED yellow per channel LED red per socket Included in delivery/accessories Dust covers M12 Attachable labels 4 pieces 10 pieces Be Certain with Belden EtherNet/IP I/O Modules with16 Digital Inputs 16 IN 0980 ESL 711 EtherNet/IP Device with 16 digital input channels, M12 socket, rotary address switches for addressing, M12 LAN-Ports, D-coded, 7/8” power supply. Bit Assignment Bit 7 6 Diagnostic Indication 5 4 3 2 1 0 M12 Input Byte 0 4B 4A 3B 3A 2B 2A 1B 1A Byte 1 8B 8A 7B 7A 6B 6A 5B 5A LED Indication Condition 1...8 A Yellow Channel status 1 1...8 DIA A Red Periphery fault 1... 8 B Yellow Channel status 2 1... 8 DIA B Red Periphery fault US Green Off Green Off Green Yellow flashing Green Yellow flashing Green Green flashing Red/Green flashing Red flashing Off Green Green flashing Red Red flashing Off Sensor power supply applied Sensor power supply missing Actuator power supply applied Actuator power supply missing Connected to an Ethernet device I/O device exchanging data Connected to an Ethernet device I/O device exchanging data Device is ready for operating Wrong configuration Self test is running Firmware update Device is off Connection to master exists IP address exists, but no connection to the master IP address is used by a different device Connection has timed out Device is off UL P1 Lnk/Act P2 Lnk/Act MS (Module status) NS (Network status) Pin Assignment LAN connection M12, D-Coded 1 = TD+ 2 = RD+ 3 = TD4 = RD Housing = shielding Power supply 7/8” Input M12 1 = +24 V Actuators 2 = +24 V Logic/Sensors 3 = GND (0 V) Logic/Sensors 4 = GND (0 V) Actuators Housing = PE 1 = +24 V 2 = IN B 3 = GND (0 V) 4 = IN A 5 = earth Housing = FE 5 EtherNet/IP I/O Modules with16 Digital Inputs 0980 ESL 711 Technical Data Environmental Degree of Protection Operating Temperature Range IP 67 -10°C (+14°F) to +60°C (+140°F) Mechanical Weight Housing Material 380 g PBT Bus system EtherNet/IP Transmission Rate Address Range Rotary Address Switches Default Address 10/100 Mbs 0-255 0-255 0 System/Sensor Power Supply Rated Voltage Voltage Range Power Consumption Reverse Polarity Protection 24 V DC 11–30 V DC typ. 90 mA yes Input power supply Us Voltage range Sensor current Short-circuit proof Indication 19–30 V DC 200 mA (at Tamb 30°C) yes LED green Inputs Type 3, IEC 61131-3 Rated Input Voltage Channel Type N.O. Number of Digital Channels Channel Status Indicator Diagnostic Indication 24 V DC p-switching max. 16 LED yellow per channel LED red per socket Included in delivery/accessories Dust covers M12 Attachable labels 2 pieces 10 pieces Part Number 0980 ESL 711 The application of these products in harsh environments should always be checked before use. Specifications subject to alteration. 6 Be Certain with Belden EtherNet/IP I/O Module Connecting Information Power Supply 7/8” Male Connector, 4 Poles Best Part Number RSC 40/9 or Description Field Attachable, Male Connector, 4-Pole, PG9 Threads RSC 40/11 Field Attachable, Male Connector, 4-Pole, PG11 Threads Best Part Number RKC 40/9 or Description Field Attachable, Female Connector, 4-Pole, PG9 Threads RKC 40/11 Field Attachable, Female Connector, 4-Pole, PG11 Threads Best Part Number RK 40-XXX/...F RKW 40-XXX/...F Description Single- Ended 4-Pole Female and Male 7/8” Power Supply Cordsets. Cable Type: TPE or PUR (U.S. Color Code) Cable Number: 637 or 602. NOTE: Also available in double-ended (male to female): RSRK 40-637/...F and RSRK 40602/...M versions. Featured Module: 0980 ESL 710 EtherNet/IP Device with 16 digital I/O channels, channels can be used universally as inputs or outputs, M12 socket, rotary address switches for addressing, M12 LAN-Ports, D-coded, 7/8“ power supply. I/O Connection Options Best Part Number ASB 2-RKT 4-3-XXX/...M or ASB 2 RKT 4-3-632/...M Actuator/sensor cordset, double-ended, M12 Duo male connector with one M12 male connector and one M12 female connector, selflocking threaded joint. Cable Options: 224: PUR, black, halogenfree, 632: PVC, yellow, OR 610: PUR, yellow EtherNet/IP Connection Options Best Part Number 0986 EMC 102 Description Field Attachable, Male Connector, 4-Pole, D-Code, Shieldable with Spring-Type Terminals. Best Part Number 0985 XXX 100 Description Double-Ended Media Cordsets, M12, D-Code to M12, D-Code Best Part Number ASBS 2 M12-5 Splitter/T-connector with two M12 female connectors, with self-locking Threaded joint Best Part Numbers *0985 XXX 101 Cable Options: 706: 24 AWG, TPE, Stranded/Unshielded 707: 24 AWG, PVC, Solid/Shielded **S4549: 26 AWG, PUR Halogen-Free, Stranded/Shielded * Denotes cross-over cable ** Denotes not available in cross-over cable Best Part Number 0985 XXX 103 Description Double-Ended Media Cordsets, M12, D-Code to RJ45 Cable Options: 706: 24 AWG, TPE, Stranded/Unshielded S4549: 26 AWG, PUR Halogen-Free, Stranded/Shielded RST 5-RKT 5-XXX/...M Actuator/sensor cordset, double-ended, M12, 5-poles, male straight to female straight connector with self-locking thread and molded cable Cable Options: 228: PUR, black, halogen-free, 259: PUR, orange, halogen-free, weld spark proof, 612: PVC, yellow, 22 AWG, 644: PUR, yellow, 22 AWG NOTE: Also available in right-angle: RST 5-RKWT 5-XXX/...M and single-ended: RST 5-XXX/...M versions. Best Part Number RSC 5/7 or RSC 5/9 Field attachable connector, M12 male connector, 5-pole with threaded joint, assembling with screw terminals. NOTE: Also available in in right-angle: RSCW 5/7 or RSCW 5/9 and female: RKC 5/7, RKC 5/9, RKCW 5/7, and RKCW 5/9 versions. 7 Other EtherNet/IP Products EtherNet/IP Cord Sets CORD SET VERSIONS Description M12 to M12 M12 to RJ45 M12 to M12 Panel RJ45 to RJ45 0985 706 100 0985 706 101 0985 706 103 0985 706 104 0985 706 500 0985 S4549 100 0985 S4549 103 0985 S4549 104 0985 S4549 500 EtherNet/IP high flex double-ended cord set, 4-pin, D-coding, 24 gauge, TPE cable, stranded/ unshielded, 2 twisted pair with teal jacket. Part Numbers: EtherNet/IP double-ended cord set, 4-pin, D-coding, 26 gauge, PUR halogen-free cable, stranded/shielded, 2 twisted pair with water blue jacket. Part Numbers: EtherNet/IP moderate flex double-ended cord set, 4-pin, D-coding, 24 gauge, TPE cable, solid/ unshielded, 2 twisted pair with teal jacket. Part Numbers: 0985 705 500 EtherNet/IP moderate flex double-ended cord set, 4-pin, D-coding, 24 gauge, PVC cable, solid/ shielded, 2 twisted pair with teal jacket. Part Numbers: 0985 707 100 0985 707 101 0985 707 500 0982 EEC 100 0986 EFC 101 Ethernet/IP Unmannaged Switch, IP 67, 5-port switch for 10 and 100 Mbaud transmission rates, M12 socket 4 poles D coding, M12 power supply 5 poles standard coding. Receptacle connector, M12 female connector, 4-pole, D-coding, PCB contacts with board lock, chassis side thread PG 9. 0986 EFC 152 Receptacle connector, M12 female connector for rear mounting, 4-pole, D-coding, printed contacts, chassis side thread PG 9 (panel nut RSKF 9). 0981 ENC 100 0986 EFC 151 A RJ45/M12 adaptor, female receptacle connector M12, D coding, chassis side thread PG 9, RJ45 female connector, 90 degree. Receptacle connector, M12 female connector for front mounting, 4 poles, D coding, adjustable, assembled stranded wire, solder contacts potted with epoxy, chassis side thread M16 x 1.5. 8 Phone: 1-717-217-2299 ©Copyright 2011, Belden, Inc. www.lumberg-automationusa.com PB 327 - ETHERNET/IP I/O MODULES 112011
11221. 价格&库存
很抱歉,暂时无法提供与“11221.”相匹配的价格&库存,您可以联系我们找货
