1219B B591000
1219B B591000
    BELDEN
    9 PR #22 FHDPE FS PVC PVC
1219B B591000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1219B Multi-Conductor - Flexible, Low-Capacitance Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductor, Datalene® insulation, individually shielded with Beldfoil® (100% coverage), numbered/color-coded PVC jackets, pair jackets and shields bonded so both strip simultaneously with automatic stripping equipment. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 9 22 7x30 TC - Tinned Copper .030 Total Number of Conductors: 18 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® Dia. (in.) FHDPE - Foam High Density Polyethylene 0.060 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 22 Inner Shield Drain Wire Stranding: 7x30 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride 0.153 Inner Jacket Color Code Chart: Number Color 1 Brown 2 Red 3 Orange 4 Yellow 5 Green 6 Blue 7 Purple 8 Gray 9 White Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.700 in. Pair Pair Color Code Chart: Color Red & Black Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1219B Multi-Conductor - Flexible, Low-Capacitance Cable Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 219 lbs/1000 ft. Max. Recommended Pulling Tension: 246 lbs. Min. Bend Radius/Minor Axis: 7 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .20 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 19 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 35 Nominal Velocity of Propagation: VP (%) 78 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 10.600 Ohm/1000 ft Max. Operating Voltage - Non-UL: Voltage 300 V RMS Max. Recommended Current: Current 1.5 Amps per conductor @ 20°C Notes (Overall) Notes: Datalene® insulation features include a low dielectric constant and a low dissipation factor for high-speed, low distortion data handling. Physical properties include good crush resistance and light weight. Pair jackets and shields are bonded so both strip simultaneously with automatic stripping equipment. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1219B B591000 1,000 FT 243.000 LB BLACK, MATTE C 9 PR #22 FHDPE FS PVC PVC 1219B B59500 500 FT 117.000 LB BLACK, MATTE C 9 PR #22 FHDPE FS PVC PVC Notes: C = CRATE REEL PUT-UP. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1219B Multi-Conductor - Flexible, Low-Capacitance Cable Revision Number: 2 Revision Date: 03-28-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1219B B591000 价格&库存
很抱歉,暂时无法提供与“1219B B591000”相匹配的价格&库存,您可以联系我们找货
