MachFlex 350 SY Cables
Armored (SY) PVC Control Cables
Galvanized Steel Wire Braid (GSWB) Excellent Mechanical Protection
Applications
Designed for applications which are installed in occasional flexing and fixed locations. Cable
applications include precision control sensors, multi axis control machines, temperature
controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control,
production machinery and many more.
General Reference Standards
DIN VDE 0295, IEC 60228, BS6360
DIN EN 50290-2-22, DIN VDE 0207-363-4-1
DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2
RoHS & REACH & CE Directives
Construction and Performance
1.
Conductor Material
Stranded bare copper (DIN VDE 0295 Class 5)
2.
Insulation Material & Color
Insulation Material & Colour PVC (polyvinyl chloride).
A) All black color with number coding = without protective conductor. B) Black
color with number coding plus 1 green & yellow = with protective conductor.
3.
Braid Shield Material
GSWB (Galvanized Steel Wire Braid)
4.
Jacket / Sheath Material
5.
Flame Retardancy
6.
Voltage Rating (Uo/U)
300 / 500 V
7.
Oil Resistant
DIN EN 50290-2-22 (TM54)
8.
Temperature Range
-30 °C TO +70 °C (Occasional movement)
-40 °C TO +80 °C (Fixed installation)
9.
Bending Radius
20 x OD (Occasional movement)
6 x OD (Fixed installation)
10.
Other Properties
Good UV resistance, chemical resistance & flexibility
MachFlex 350 SY Armored (SY) PVC Control Cables
GALVANIZED STEEL WIRE BRAID SHIELD (GSWB) CABLE WITH (G) PROTECTIVE GROUND
5
4
3
2
1 = Conductor
2 = Insulation
3 = Inner Sheath
4 = Galvanized Steel Wire Braid Shield
5 = Outer Sheath
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.5
8.0
8.5
9.1
11.4
13.9
Conductor 0.75 mm2
Copper Weight
(kg/km)
14.40
19.20
24.00
33.60
58.00
96.70
EMEA
Part Code
3GASY
4GASY
5GASY
7GASY
12GASY
20GASY
APAC
Part Code
3G0.5SY
4G0.5SY
5G0.5SY
7G0.5SY
12G0.5SY
20G0.5SY
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
8.0
8.6
9.2
9.9
12.4
15.2
Copper Weight
(kg/km)
21.60
28.80
36.00
50.00
86.00
143.30
EMEA
Part Code
3GBSY
4GBSY
5GBSY
7GBSY
12GBSY
20GBSY
APAC
Part Code
3G0.75SY
4G0.75SY
5G0.75SY
7G0.75SY
12G0.75SY
20G0.75SY
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.4
28.80
4
9.1
38.40
5
9.8
48.00
7
10.5
67.00
12
13.3
115.00
192.00
Conductor 2.50 mm2
EMEA
Part Code
3GCSY
4GCSY
5GCSY
7GCSY
12GCSY
20GCSY
APAC
Part Code
3G1.0SY
4G1.0SY
5G1.0SY
7G1.0SY
12G1.0SY
20G1.0SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
9.0
43.00
4
9.7
58.00
5
10.5
72.00
7
11.3
101.00
12
14.6
173.00
288.30
Conductor 4.00 mm2
EMEA
Part Code
3GDSY
4GDSY
5GDSY
7GDSY
12GDSY
20GDSY
APAC
Part Code
3G1.5SY
4G1.5SY
5G1.5SY
7G1.5SY
12G1.5SY
20G1.5SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
11.0
72.00
4
11.9
96.00
5
12.9
120.00
7
14.2
168.00
12
18.4
288.00
480.00
Conductor 6.00 mm2
EMEA
Part Code
3GESY
4GESY
5GESY
7GESY
12GESY
20GESY
APAC
Part Code
3G2.5SY
4G2.5SY
5G2.5SY
7G2.5SY
12G2.5SY
20G2.5SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
12.6
115.00
4
13.9
154.00
5
15.1
192.00
7
16.4
269.00
9
19.9
345.90
12
21.5
461.00
Conductor 10.00 mm2
EMEA
Part Code
3GFSY
4GFSY
5GFSY
7GFSY
9GFSY
12GFSY
APAC
Part Code
3G4SY
4G4SY
5G4SY
7G4SY
9G4SY
12G4SY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
3GGSY
4GGSY
5GGSY
7GGSY
9GGSY
APAC
Part Code
3G6SY
4G6SY
5G6SY
7G6SY
9G6SY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
3GHSY
4GHSY
5GHSY
7GHSY
9GHSY
APAC
Part Code
3G10SY
4G10SY
5G10SY
7G10SY
9G10SY
EMEA
Part Code
3GJSY
4GJSY
5GJSY
7GJSY
APAC
Part Code
3G25SY
4G25SY
5G25SY
7G25SY
Nom. Overall
Diameter (mm)
14.9
16.2
17.7
19.3
23.5
Copper Weight
(kg/km)
172.80
230.00
288.00
403.00
518.10
Conductor 16.00 mm2
No. of
Cores
3
4
5
7
Nom. Overall
Diameter (mm)
21.4
23.6
26.1
28.4
Copper Weight
(kg/km)
460.50
614.00
768.00
1,075.00
Nom. Overall
Diameter (mm)
18.0
19.8
21.7
23.7
29.1
Copper Weight
(kg/km)
288.00
384.00
480.00
672.00
864.00
Conductor 25.00 mm2
EMEA
Part Code
3GISY
4GISY
5GISY
7GISY
APAC
Part Code
3G16SY
4G16SY
5G16SY
7G16SY
No. of
Cores
3
4
5
7
Nom. Overall
Diameter (mm)
25.9
28.6
31.2
33.9
• Putup length & tolerance of the cables will vary depending on the construction of the cable
• MOQ will vary depending on the construction of the cable & provided at the time of quotation
• Cable requested outside the above design criteria can be reviewed and quoted
Copper Weight
(kg/km)
720.00
960.00
1,200.00
1,680.00
GALVANIZED STEEL WIRE BRAID SHIELD (GSWB) CABLE WITHOUT (G) PROTECTIVE GROUND
5
4
3
2
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.5
8.0
8.5
9.1
11.4
13.9
1 = Conductor
2 = Insulation
3 = Inner Sheath
5 = Outer Sheath
Conductor 0.75 mm2
Copper Weight
(kg/km)
14.40
19.20
24.00
33.60
58.00
96.70
EMEA
Part Code
3XASY
4XASY
5XASY
7XASY
12XASY
20XASY
APAC
Part Code
3X0.5SY
4X0.5SY
5X0.5SY
7X0.5SY
12X0.5SY
20X0.5SY
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
8.0
8.6
9.2
9.9
12.4
15.2
Copper Weight
(kg/km)
21.60
28.80
36.00
50.00
86.00
143.30
EMEA
Part Code
3XBSY
4XBSY
5XBSY
7XBSY
12XBSY
20XBSY
APAC
Part Code
3X0.75SY
4X0.75SY
5X0.75SY
7X0.75SY
12X0.75SY
20X0.75SY
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.4
28.80
4
9.1
38.40
5
9.8
48.00
7
10.5
67.00
12
13.3
115.00
192.00
Conductor 2.50 mm2
EMEA
Part Code
3XCSY
4XCSY
5XCSY
7XCSY
12XCSY
20XCSY
APAC
Part Code
3X1.0SY
4X1.0SY
5X1.0SY
7X1.0SY
12X1.0SY
20X1.0SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
9.0
43.00
4
9.7
58.00
5
10.5
72.00
7
11.3
101.00
12
14.6
173.00
288.30
Conductor 4.00 mm2
EMEA
Part Code
3XDSY
4XDSY
5XDSY
7XDSY
12XDSY
20XDSY
APAC
Part Code
3X1.5SY
4X1.5SY
5X1.5SY
7X1.5SY
12X1.5SY
20X1.5SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
11.0
72.00
4
11.9
96.00
5
12.9
120.00
7
14.2
168.00
12
18.4
288.00
480.00
Conductor 6.00 mm2
EMEA
Part Code
3XESY
4XESY
5XESY
7XESY
12XESY
20XESY
APAC
Part Code
3X2.5SY
4X2.5SY
5X2.5SY
7X2.5SY
12X2.5SY
20X2.5SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
12.6
115.00
4
13.9
154.00
5
15.1
192.00
7
16.4
269.00
9
19.9
345.90
12
21.5
461.00
Conductor 10.00 mm2
EMEA
Part Code
3XFSY
4XFSY
5XFSY
7XFSY
9XFSY
12XFSY
APAC
Part Code
3X4SY
4X4SY
5X4SY
7X4SY
9X4SY
12X4SY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
3XGSY
4XGSY
5XGSY
7XGSY
9XGSY
APAC
Part Code
3X6SY
4X6SY
5X6SY
7X6SY
9X6SY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
3XHSY
4XHSY
5XHSY
7XHSY
9XHSY
APAC
Part Code
3X10SY
4X10SY
5X10SY
7X10SY
9X10SY
EMEA
Part Code
3XJSY
4XJSY
5XJSY
7XJSY
APAC
Part Code
3X25SY
4X25SY
5X25SY
7X25SY
Nom. Overall
Diameter (mm)
14.9
16.2
17.7
19.3
23.5
Copper Weight
(kg/km)
172.80
230.00
288.00
403.00
518.10
Conductor 16.00 mm2
No. of
Cores
3
4
5
7
Nom. Overall
Diameter (mm)
21.4
23.6
26.1
28.4
Copper Weight
(kg/km)
460.50
614.00
768.00
1,075.00
Nom. Overall
Diameter (mm)
18.0
19.8
21.7
23.7
29.1
Copper Weight
(kg/km)
288.00
384.00
480.00
672.00
864.00
Conductor 25.00 mm2
EMEA
Part Code
3XISY
4XISY
5XISY
7XISY
APAC
Part Code
3X16SY
4X16SY
5X16SY
7X16SY
No. of
Cores
3
4
5
7
Nom. Overall
Diameter (mm)
25.9
28.6
31.2
33.9
Copper Weight
(kg/km)
720.00
960.00
1,200.00
1,680.00
很抱歉,暂时无法提供与“12GBSY-KC50”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2773.51723
- 5+2690.32108
- 国内价格 香港价格
- 1+22.319391+2.88150
- 25+18.4682025+2.38430
- 50+16.5426150+2.13570
- 100+14.52949100+1.87580
