1480A 0102500
1480A 0102500
    BELDEN
    CBL 24PR/18AWG 1COND/22AWG SHLD
1480A 0102500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1480A Multi-Conductor - 300V Power-Limited Tray Cable For more Information please call 1-800-Belden1 General Description: 18 AWG pairs stranded (7x26) bare copper conductors, twisted pairs, individually shielded plus an overall Beldfoil (100% coverage), PVC insulation, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors # Pairs AWG Stranding Conductor Material 24 1 18 7x26 BC - Bare Copper 22 7x30 BC - Bare Copper Total Number of Conductors: 49 Insulation Insulation Material: Insulation Material PVC - Polyvinyl Chloride Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG Stranding Conductor Material 20 7x28 TC - Tinned Copper Inner Shield Drain Wire Stranding: 7x28 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 18 7x26 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .074 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 1.017 in. Pair Pair Color Code Chart: Number Color White and Numbered 24 Black & White and Numbered 1 Communication Wire Black & White and Numbered 2 Black & White and Numbered 3 Black & White and Numbered 4 Black & White and Numbered 5 Black & White and Numbered 6 Black & White and Numbered 7 Black & White and Numbered 8 Black & White and Numbered 9 Black & White and Numbered 10 Black & White and Numbered 11 Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1480A Multi-Conductor - 300V Power-Limited Tray Cable Black & White and Numbered 12 Black & White and Numbered 13 Black & White and Numbered 14 Black & White and Numbered 15 Black & White and Numbered 16 Black & White and Numbered 17 Black & White and Numbered 18 Black & White and Numbered 19 Black & White and Numbered 20 Black & White and Numbered 21 Black & White and Numbered 22 Black & White and Numbered 23 Black & White and Numbered 24 Orange Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +105°C Bulk Cable Weight: 614.130 lbs/1000 ft. Max. Recommended Pulling Tension: 1443 lbs. Min. Bend Radius/Minor Axis: 10.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG, ITC-ER, PLTC-ER CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: NEC Type PLTC Listed, which is approved for cable tray use in Class 1, Division 2, hazardous areas and non-hazardous areas, cable trays, raceways, conduit and supported by messenger wires. Flame Test UL Flame Test: UL1685 FT4 Loading CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Burial: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .19 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 51 Nom. Capacitance Cond. to Other Conductor & Shield: Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1480A Multi-Conductor - 300V Power-Limited Tray Cable Capacitance (pF/ft) 95 Nom. Conductor DC Resistance: Description DCR @ 20°C (Ohm/1000 ft) 18 AWG 5.86 22 AWG 14.7 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.8 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 10.300 Ohm/1000 ft Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2 Amps per conductor @ 25°C Notes (Overall) Notes: Alternate color coding available upon request. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1480A 0061000 1,000 FT 590.000 LB BLUE, LIGHT C 24 FS PR #18 +1 #22 PVC FS PVC 1480A 0102500 2,500 FT 1,490.000 LB BLACK CZ 18/24 PR PLTC IS/OS 1480A 0104100 4,100 FT 2,652.700 LB BLACK TRANSFER REVIEW (20 TO 30) 1480A 0104400 4,400 FT 2,811.600 LB BLACK 24 FS PR #18 +1 #22 PVC FS PVC 1480A 0104500 4,500 FT 2,862.000 LB BLACK 24 FS PR #18 +1 #22 PVC FS PVC 1480A 0104800 4,800 FT 3,571.200 LB BLACK 1480A 0105000 5,000 FT 3,295.000 LB BLACK 24 FS PR #18 +1 #22 PVC FS PVC CZ 24 FS PR #18 +1 #22 PVC FS PVC Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 2 Revision Date: 05-24-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
1480A 0102500 价格&库存
很抱歉,暂时无法提供与“1480A 0102500”相匹配的价格&库存,您可以联系我们找货
