1505ANH.01500
1505ANH.01500
    BELDEN
    BELDEN - 1505ANH.01500 - Coaxial Cable, RG59U, 20 AWG, 75 ohm, 1640 ft, 500 m
1505ANH.01500 数据手册
Part Number: 1505ANH COAX RG59/U LSZH-C HDTV PRECISION VIDEO Product Description COAX [0.8/3.7] RG59/U LSZH-C HDTV CLASSICS PRO Technical Specifications Product Overview Environmental Space: Indoor - Euroclass Cca Suitable Applications: Low loss HDTV/SDI Digital coax used in analog and digital video circuits and high quality applications; The cable is UV-resistant and suitable for indoor and outdoor use Physical Characteristics (Overall) Conductor AWG Stranding 20 Solid Material Nominal Diameter Diameter +/- Tolerance No. of Coax BC - Bare Copper 0.81 mm Conductor Count: 0.03 mm 1 1 Insulation Type Material Nominal Diameter Diameter +/- Tolerance Dielectric FPE - Foamed Polyethylene 3.68 mm 0.15 mm Outer Shield Material Type Layer Material Coverage [%] Min. Overlap Nominal Diameter Coverage +/- Tolerance Tape 1 Aluminum/Polyester/Aluminum Braid 2 TC - Tinned Copper 2 mm 95 % 4.4 mm Outer Jacket Material Material Nominal Diameter Diameter +/- Tolerance LSZH / FRNC 5.92 mm 0.2 mm OuterJacket1, Table Note: According to European Standard HD 624 Construction and Dimensions Min Elongation at Breakof Jacket: 125 % Min Tensile Strength of Jacket: 9 MPa Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 32 Ohm/km 12 Ohm/km Capacitance Nom. Capacitance Capacitance Tolerance 53 pF/m 2 pF/m Impedance Nominal Characteristic Impedance Nominal Characteristic Tolerance 5% 75 Ohm 3 Ohm Return Loss (RL) Frequency [MHz] Minimum Return (RL) 5 - 1600 MHz 23 dB 1600 - 4500 MHz 21 dB 4500 - 6000 MHz 15 dB High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 1 dB/100m 3.6 MHz 2 dB/100m 10 MHz 3 dB/100m 71.5 MHz 6.9 dB/100m 135 MHz 8.9 dB/100m 270 MHz 12.5 dB/100m 360 MHz 14.4 dB/100m 540 MHz 18.1 dB/100m 720 MHz 21.0 dB/100m 750 MHz 21.3 dB/100m 1000 MHz 24.9 dB/100m 1500 MHz 31.2 dB/100m 2250 MHz 39.0 dB/100m 3000 MHz 45.9 dB/100m 4500 MHz 57.4 dB/100m 6000 MHz 69.2 dB/100m Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] Velocity of Propagation Tolerance 400 ns/ft 83 % 2% Voltage Voltage Test Dielectric 2.0 kV DC Temperature Range Installation Temp Range: -5°C To +50°C Storage Temp Range: -30°C To +70°C Operating Temp Range: -30°C To +70°C Mechanical Characteristics Max Recommended Pulling Tension: 200 N Min Bend Radius (W/o Pulling Strength): 60 mm Standards CPR Euroclass: Cca-s1a,d1,a1 CENELEC Compliance: EN 50117-1 RG Type: 59/U Type Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2005-01-01 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1-2 and IEC 60332-3-24 Other Flammability: CEI 20-22-3 LOI of Jacket: Min. 35 % Amount of Halogen acc. to IEC 60754-1 & EN50267-1: Zero Part Number Variants Item # Color Length 1505ANH.00100 Black 100 m 1505ANH.001000 Black 1,000 m 1505ANH.00305 Black 305 m 1505ANH.00500 Black 500 m 1505ANH.K0305 Black 305 m 1505ANH.041000 Blue 1,000 m 1505ANH.04500 500 m Blue 1505ANH.K41000 Blue 1,000 m 1505ANH.02100 100 m Green 1505ANH.021000 Green 1,000 m 1505ANH.02305 Green 305 m 1505ANH.02500 Green 500 m 1505ANH.011000 Purple 1,000 m 1505ANH.011220 Purple 1,220 m 1505ANH.01305 Purple 305 m 1505ANH.01500 Purple 500 m 1505ANH.051000 Red 1,000 m 1505ANH.031000 Yellow 1,000 m 1505ANH.03305 Yellow 305 m History Update and Revision: Revision Number: 0.167 Revision Date: 08-22-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
1505ANH.01500 价格&库存
很抱歉,暂时无法提供与“1505ANH.01500”相匹配的价格&库存,您可以联系我们找货
