1694A 0041000
1694A 0041000
    BELDEN
    #18 PE/GIFHDPE SH FR PVC
1694A 0041000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1694A Coax - Low Loss Serial Digital Coax For more Information please call 1-800-Belden1 General Description: RG-6/U Type, 18 AWG solid .040" bare copper conductor, gas-injected foam HDPE insulation, Duofoil® + tinned copper braid shield (95% coverage), PVC jacket. Usage (Overall) Suitable Applications: SMPTE 2081-1 6 Gb/s UHDTV, SMPTE 424M 3 Gb/s HD-SDI 1080p Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 18 Solid BC - Bare Copper .040 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .180 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.274 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +75°C Bulk Cable Weight: 41 lbs/1000 ft. Max. Recommended Pulling Tension: 69 lbs. Min. Bend Radius/Minor Axis: 2.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 6/U Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1694A Coax - Low Loss Serial Digital Coax RG Type: 6/U Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes - Black only. Suitability - Aerial: Yes - Black only, when supported by messenger wire. Suitability - Burial: No Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1695A Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.106 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.2 Nominal Velocity of Propagation: VP (%) 82 Nominal Delay: Delay (ns/ft) 1.24 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.4 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.8 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.240 3.580 0.440 5.000 0.520 6.000 0.570 7.000 0.610 10.000 0.710 12.000 0.780 25.000 1.080 67.500 1.650 71.500 1.690 88.500 1.860 100.000 1.950 135.000 2.240 143.000 2.300 180.000 2.570 270.000 3.170 360.000 3.690 540.000 4.500 720.000 5.300 750.000 5.400 1000.000 6.300 1500.000 7.800 2000.000 9.200 2250.000 9.800 3000.000 11.500 Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1694A Coax - Low Loss Serial Digital Coax 4500.000 14.500 6000.000 17.700 Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: TDR Impedance: 75 +/- 1.5 Ohms Other Electrical Characteristic 2: Return Loss: Fixed bridge and termination. Minimum Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5.000 1600.000 23.000 1600.000 4500.000 21.000 4500.000 6000.000 15.000 Sweep Test Sweep Testing: 100% Sweep tested 5 MHz to 6 GHz. Misc. Information (Overall) Notes (Overall) Notes: Also available in 4.5 GHz multi-coax bundled versions. See 7710A through 7713A. Put Ups and Colors: Item # Putup Ship Weight Color 1694A N3UN1000 1,000 FT 45.000 LB GREEN, MIL Notes Item Desc 1694A N3U1000 1,000 FT 45.000 LB GREEN, MIL C #18 PE/GIFHDPE SH FR PVC 1694A N3U5000 5,000 FT 225.000 LB GREEN, MIL CN #18 PE/GIFHDPE SH FR PVC 1694A 0011000 1,000 FT 45.000 LB BROWN C #18 PE/GIFHDPE SH FR PVC 1694A 0015000 5,000 FT 225.000 LB BROWN CN #18 PE/GIFHDPE SH FR PVC 1694A 0021000 1,000 FT 45.000 LB RED C #18 PE/GIFHDPE SH FR PVC 1694A 0025000 5,000 FT 225.000 LB RED CN #18 PE/GIFHDPE SH FR PVC 1694A 0031000 1,000 FT 45.000 LB ORANGE C #18 PE/GIFHDPE SH FR PVC 1694A 004N1000 1,000 FT 45.000 LB YELLOW 1694A 0041000 1,000 FT 45.000 LB YELLOW C #18 PE/GIFHDPE SH FR PVC 1694A 0061000 1,000 FT 45.000 LB BLUE, LIGHT C #18 PE/GIFHDPE SH FR PVC 1694A 0065000 5,000 FT 225.000 LB BLUE, LIGHT CN #18 PE/GIFHDPE SH FR PVC 1694A 0071000 1,000 FT 45.000 LB VIOLET C #18 PE/GIFHDPE SH FR PVC 1694A 0075000 5,000 FT 225.000 LB VIOLET CN #18 PE/GIFHDPE SH FR PVC 1694A 0081000 1,000 FT 45.000 LB GRAY C #18 PE/GIFHDPE SH FR PVC 1694A 0085000 5,000 FT 225.000 LB GRAY CN #18 PE/GIFHDPE SH FR PVC 1694A 009N1000 1,000 FT 45.000 LB WHITE 1694A 0091000 1,000 FT 45.000 LB WHITE 1694A 010N1000 1,000 FT 45.000 LB BLACK 1694A 0101000 1,000 FT 45.000 LB BLACK C #18 PE/GIFHDPE SH FR PVC 1694A 010500 500 FT 22.500 LB BLACK C #18 PE/GIFHDPE SH FR PVC 1694A 0105000 5,000 FT 225.000 LB BLACK CN #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC C #18 PE/GIFHDPE SH FR PVC #18 PE/GIFHDPE SH FR PVC Notes: C = CRATE REEL PUT-UP. N = FINAL PUT-UP LENGTH MAY VARY -0% TO +10% FROM LENGTH SHOWN. Revision Number: 17 Revision Date: 06-17-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
1694A 0041000 价格&库存
很抱歉,暂时无法提供与“1694A 0041000”相匹配的价格&库存,您可以联系我们找货
1694A 0041000
  • 305+36.52782305+4.73470
  • 610+31.99453610+4.14710
