1700A-DEC-GRY-1000
1700A-DEC-GRY-1000
    BELDEN
    1700A-DEC-GRY-1000
1700A-DEC-GRY-1000 数据手册
Product: 1700A CAT5E+ Horizontal Bonded-Pair, 4pr, UTP, LS-PVC Jkt, CMR Product Description CAT5e+ (350MHz), 4-Bonded-Pair, U/UTP-unshielded, Riser-CMR, Premise Horizontal cable, 24 AWG solid bare copper conductors, polyolefin insulation, ripcord, PVC jacket Technical Specifications Product Overview Premise Horizontal Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, Noisy Environments ^ US Patent #'s 5606151; 5734126, CMR, Riser Suitable Applications: Physical Characteristics (Overall) Conductor AWG Stranding 24 Solid Material No. of Pairs BC - Bare Copper 4 Conductor Count: 8 Total Number of Pairs: 4 Insulation Material Polyolefin Bonded-Pair: Yes Color Chart Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Outer Jacket Material Material Nominal Diameter Ripcord PVC - Polyvinyl Chloride 0.202 in Yes Electrical Characteristics Conductor DCR Max. Conductor DCR Max. DCR Unbalance 90 Ohm/km 3% Capacitance Max. Capacitance Unbalance Nom.Mutual Capacitance 66 pF/100m 15 pF/ft Delay Frequency [MHz] 100 MHz Max. Delay Max. Delay Skew Nominal Velocity of Propagation (VP) [%] 537.6 ns/100m 25 ns/100m 70 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) Min. PSNEXT [dB] Min. PSACR [dB] Min. PSACRF (PSELFEXT) [dB] Min. RL (Return Loss) [dB] Max./Min. Input Impedance (unFitted) Max./Min. Fitted Impedance Min. TCL [dB] Min. ELTCTL [dB] 1 MHz 2.0 dB/100m 69.3 dB 67.3 dB 65.8 dB 20.0 dB 100 ± 12 Ohm 105 ± 10 Ohm 40.0 dB 35.0 dB 4 MHz 4.0 dB/100m 60.3 dB 56.3 dB 53.8 dB 23.0 dB 100 ± 12 Ohm 100 ± 10 Ohm 40.0 dB 23.0 dB 8 MHz 5.7 dB/100m 55.8 dB 50.1 dB 47.7 dB 24.5 dB 100 ± 12 Ohm 100 ± 10 Ohm 40.0 dB 16.9 dB 10 MHz 6.4 dB/100m 54.3 dB 47.9 dB 45.8 dB 25.0 dB 100 ± 12 Ohm 100 ± 10 Ohm 40.0 dB 15.0 dB 16 MHz 8.1 dB/100m 51.2 dB 43.1 dB 41.7 dB 25.0 dB 100 ± 12 Ohm 100 ± 10 Ohm 38.0 dB 10.9 dB 20 MHz 9.1 dB/100m 49.8 dB 40.7 dB 39.8 dB 25.0 dB 100 ± 12 Ohm 100 ± 10 Ohm 37.0 dB 9.0 dB 25 MHz 10.2 dB/100m 48.3 dB 38.2 dB 37.8 dB 25.0 dB 100 ± 15 Ohm 100 ± 10 Ohm 36.0 dB 7.0 dB 31.25 MHz 11.4 dB/100m 46.9 dB 35.5 dB 35.9 dB 25.0 dB 100 ± 15 Ohm 100 ± 10 Ohm 35.1 dB 62.5 MHz 16.4 dB/100m 42.4 dB 26.0 dB 29.9 dB 25.0 dB 100 ± 15 Ohm 100 ± 10 Ohm 32.0 dB 100 MHz 21.0 dB/100m 39.3 dB 18.3 dB 25.8 dB 25.0 dB 100 ± 15 Ohm 100 ± 10 Ohm 30.0 dB 155 MHz 26.6 dB/100m 36.4 dB 9.8 dB 22.0 dB 19.0 dB 100 ± 18 Ohm 100 ± 10 Ohm 28.1 dB 200 MHz 30.4 dB/100m 34.8 dB 4.4 dB 19.8 dB 19.0 dB 100 ± 18 Ohm 100 ± 10 Ohm 27.0 dB 250 MHz 34.4 dB/100m 32.3 dB 17.8 dB 18.0 dB 100 ± 20 Ohm 100 ± 10 Ohm 26.0 dB 300 MHz 38.0 dB/100m 28.1 dB 14.3 dB 18.0 dB 100 ± 20 Ohm 100 ± 10 Ohm 350 MHz 41.4 dB/100m 27.1 dB 12.9 dB 17.0 dB 100 ± 20 Ohm 100 ± 10 Ohm 400 MHz 44.5 dB/100m 26.3 dB 11.8 dB 17.0 dB 100 ± 22 Ohm 100 ± 10 Ohm 450 MHz 47.6 dB/100m 25.5 dB 10.7 dB 17.0 dB 100 ± 22 Ohm 100 ± 10 Ohm Segregation class according EN50174-2: a Voltage UL Voltage Rating 300 V RMS Temperature Range Installation Temp Range: 0°C To +50°C UL Temp Rating: 75°C Storage Temp Range: -20°C To +75°C Operating Temp Range: -20°C To +75°C Mechanical Characteristics Bulk Cable Weight: 22 lbs/1000ft Max Recommended Pulling Tension: 40 lbs Min Bend Radius During Installation: 2.0 in Min Bend Radius/Minor Axis: 0.5 in Standards NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMR ISO/IEC Compliance: 11801 ed 2.1 (2008) Class D CPR Euroclass: Eca Data Category: Category 5e ANSI Compliance: S-90-661-2012 Category 5e, ANSI/NEMA WC-63.1 Category 5e Telecommunications Standards: ANSI/TIA-568-C.2 Category 5e IEEE Specification: IEEE 802.3bt Type 1, Type 2, Type 3 Third Party Performance Verification: Category 5e Applicable Environmental and Other Programs Environmental Space: Riser EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: Yes EU CE Mark: Yes EU REACH SVHC Compliance (yyyy-mm-dd): 2017-07-10 EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 MII Order #39 (China RoHS): Yes Suitability Suitability - Aerial: No Suitability - Burial: No Suitability - Hazardous Locations: No Suitability - Indoor: Yes Suitability - Non-Halogenated: No Suitability - Oil Resistance: No Suitability - Outdoor: No Suitability - Sunlight Resistance: No Flammability, LS0H, Toxicity Testing C(UL) Flammability: FT4 UL Flammability: UL 1666 Riser ISO/IEC Flammability: 60332-1 UL voltage rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1701A Part Number Variants Item # Color Putup Type Length UPC/EAN 1700A 0101000 Black Reel 1,000 ft 612825121589 1700A 010U1000 Black UnReel 1,000 ft 612825121572 1700A 0061640 Blue Reel 1,640 ft 612825121527 1700A 0063000 Blue Reel 3,000 ft 1700A 006U1000 Blue UnReel 1,000 ft 612825121503 1700A.00305 Gray Reel 305 m 1700A 008U1000 Gray UnReel 1,000 ft 612825121534 1700A F2V1000 Gray Reel 1,000 ft 612825121398 1700A F2V3000 Gray Reel 3,000 ft 612825121404 1700A F2VU1000 Gray UnReel 1,000 ft 612825121381 1700A.K0305 Gray Reel 305 m 1700A 0051000 Green Reel 1,000 ft 612825121497 1700A 005U1000 Green UnReel 1,000 ft 612825121480 1700A 0031000 Orange Reel 1,000 ft 612825121459 1700A 003U1000 Orange UnReel 1,000 ft 612825121442 1700A B021000 Purple Reel 1,000 ft 612825121374 1700A B02U1000 Purple UnReel 1,000 ft 612825121367 1700A 0021000 Red Reel 1,000 ft 612825121428 1700A 0023000 Red Reel 3,000 ft 612825121435 1700A 002U1000 Red UnReel 1,000 ft 612825121411 1700A 0091000 White Reel 1,000 ft 612825121558 1700A 0093000 White Reel 3,000 ft 612825121565 1700A 009U1000 White UnReel 1,000 ft 612825121541 1700A 004U1000 Yellow UnReel 1,000 ft 612825121466 8719605003881 8719605003928 Footnote: C - CRATE REEL PUT-UP. Patent: https://www.belden.com/resources/patents Product Notes Notes: Electrical values are expected performance based on cable testing and representative performance within a typical Belden system. Values above 350 MHz are for Engineering Information Only. Print Includes Descending Footage Markings from Max. Put-Up Length to 0. History Update and Revision: Revision Number: 0.358 Revision Date: 04-08-2020 © 2020 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
1700A-DEC-GRY-1000 价格&库存
很抱歉,暂时无法提供与“1700A-DEC-GRY-1000”相匹配的价格&库存,您可以联系我们找货
