1868E 500M
1868E 500M
    BELDEN
    BELDEN - 1868E 500M - Networking Cable, Screened, Cat5e, 26 AWG, 0.13 mm², 1640 ft, 500 m
1868E 500M 数据手册
Product: 1868E Cat 5e Patch Cable, F/UTP, PVC, 4 Pair, AWG 26, Indoor Product Description Cat. 5e (100MHz), 4-Pair, F/UTP Foil shielded, Work Area Patch Cable, 26 AWG stranded (7x34) bare copper conductors, Polyethylene insulation, Beldfoil® shield, AWG 26 stranded (7x34) tinned copper drainwire, PVC jacket, RJ-45 compatible Technical Specifications Product Overview Suitable Applications: Work area cable; Support current and future Category 5e applications, such as: 1000Base - T (Gigabit Ethernet), 100 Base - T, 10 Base - T, FDDI, ATM Physical Characteristics (Overall) Conductor Element AWG Stranding Individual pair 26 7x34 Material No. of Pairs BC - Bare Copper 4 Conductor Count: 8 Total Number of Pairs: 4 Insulation Element Type Material Nominal Diameter Individual pair Dielectric Polyethylene 0.95 mm Bonded-Pair: No Color Chart Number Color Pair 1 Black/Blue & Blue Pair 2 Black/Orange & Orange Pair 3 Black/Green & Green Pair 4 Black/Brown & Brown Outer Shield Material Type Material Coverage [%] Tape Aluminum/Polyester 100 % Outer Shield Table Note: Drainwire Material Drainwire AWG Drainwire Position Stranded tinned copper 26 (7xAWG34) Under foil Aluminum facing inside in contact with drain wire Outer Jacket Material Material Nominal Diameter Diameter +/- Tolerance Max. Diameter Min. Wall Thickness Nominal Wall Thickness PVC - Polyvinyl Chloride 5.4 mm 0.3 mm Construction and Dimensions Min Elongation at Breakof Conductors: 10 % Min Elongation at Breakof Insulation: 100 % Min Elongation at Breakof Jacket: 100 % Min Tensile Strength of Jacket: 9 MPa Electrical Characteristics Conductor DCR 5.9 mm 0.4 mm 0.45 mm Max. Conductor DCR Max DCR Unbalanced Between Pairs [%] Max. DCR Unbalanced Within Pair [%] 145 Ohm/km 4% 2% Capacitance Max. Capacitance Unbalance Max. Mutual Capacitance 1,600 pF/m 56 pF/m Impedance Nominal Characteristic Impedance 100 Ohm Delay Max. Delay Skew Min. Velocity of Propagation 40 ns/100m 60 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) Min. NEXT [dB] Min. PSNEXT [dB] Min. ACR [dB] Min. PSACR [dB] Min. ACRF (ELFEXT) [dB] Min. PSACRF (PSELFEXT) [dB] Min. RL (Return Loss) [dB] Min. TCL [dB] Min. ELTCTL [dB] 1 MHz 3.2 dB/100m 65.3 dB 62.3 dB 62.1 dB 59.1 dB 64 dB 61 dB 20 dB 40 dB 35 dB 4 MHz 6 dB/100m 56.3 dB 53.3 dB 50.3 dB 47.3 dB 52 dB 49 dB 23 dB 34 dB 23 dB 10 MHz 9.5 dB/100m 50.3 dB 47.3 dB 40.8 dB 37.8 dB 44 dB 41 dB 25 dB 30 dB 15 dB 16 MHz 12.1 dB/100m 47.2 dB 44.2 dB 35.2 dB 32.2 dB 39.9 dB 36.9 dB 25 dB 28 dB 10.9 dB 20 MHz 13.5 dB/100m 45.8 dB 42.8 dB 32.2 dB 29.2 dB 38 dB 35 dB 25 dB 27 dB 9 dB 31.25 MHz 17.1 dB/100m 42.9 dB 39.9 dB 25.8 dB 22.8 dB 34.1 dB 31.5 dB 23.3 dB 25.1 dB 5.5 dB 62.5 MHz 24.8 dB/100m 38.4 dB 35.4 dB 13.6 dB 10.6 dB 28.1 dB 25.1 dB 20.7 dB 22 dB 100 MHz 32 dB/100m 35.3 dB 32.3 dB 3.3 dB 0.3 dB 24 dB 21 dB 19 dB 20 dB High Freq Table Note: Limits below 4 MHz are for information only. Reference standard: ISO/IEC 61156-5 ed. 2.0 (2009) General Electrical Parameters Notes: Reference standard: ISO/IEC 61156 - 5 ed. 2.0 (2009) Coupling Attenuation Class: Type II Segregation class according EN50174-2: a Transfer Impedance Frequency [MHz] Description Transfer Impedance 1 Mhz Grade 2 Max. 50 mOhm/m 10 Mhz Max. 100 mOhm/m 30 Mhz Max. 200 mOhm/m 100 Mhz Max. 1000 mOhm/m Current Max. Recommended Current [A] 1.5 A Voltage Voltage Rating [V] 72 V Temperature Range Installation Temp Range: 0°C To +50°C Operating Temp Range: -30°C To +60°C Mechanical Characteristics Bulk Cable Weight: 31 kg/km Max Recommended Pulling Tension: 45 N Min Bend Radius During Installation: 42 mm Min Bend Radius During Operation: 21 mm Standards ISO/IEC Compliance: ISO/IEC 11801 Ed. 2.2:2002/A2:2010/C1:2011 CENELEC Compliance: EN 50173-1 Ed. 3:2011 Data Category: Category 5e ANSI Compliance: ANSI/TIA 568.2-D (2018) IEEE Specification: PoE: IEEE 802.3bt Type 1, Type 2, Type 3 Applicable Environmental and Other Programs Environmental Space: Indoor EU RoHS Compliance Date (yyyy-mm-dd): 2003-01-01 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1 Burning Load: 395 kJ/m Part Number Variants Item # Color Length 1868E.011000 Blue 1,000 m 1868E.01500 500 m Blue 1868E.001000 Gray 1,000 m 1868E.00500 Gray 500 m 1868E.00B100 Gray 100 m 1868E.K0500 500 m Gray Patent: https://www.belden.com/resources/patents History Update and Revision: Revision Number: 0.222 Revision Date: 09-17-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
1868E 500M 价格&库存
很抱歉,暂时无法提供与“1868E 500M”相匹配的价格&库存,您可以联系我们找货
