1872A F6HA1000
1872A F6HA1000
    BELDEN
    CAT6+ 4PRB U/UTP CMR RIB
1872A F6HA1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1872A Multi-Conductor - Enhanced Category 6 Bonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT6+ (350MHz), 4-Bonded-Pairs, U/UTP-Unshielded, Riser-CMR, Premise Horizontal Cable, 23 AWG Solid Bare Copper Conductor, Polyolefin Insulation, Ripcord, PVC Jacket Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, POE, POE+,100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, Noisy Environments Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 23 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.365 0.165 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.365 x 0.165 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C Bulk Cable Weight: 29 lbs/1000 ft. Max. Recommended Pulling Tension: 45 lbs. Min. Bend Radius/Minor Axis: 0.500 in. Min. Bend/Installation: 1.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR Page 1 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1872A Multi-Conductor - Enhanced Category 6 Bonded-Pair Cable CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes Other Standards: ISO/IEC 11801 ed 2.1 (2008) Class E EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 6 - TIA 568.C.2 Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: UL1666 Vertical Riser CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1874A Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15.0 Maximum Capacitance Unbalance (pF/100 m): 49 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 510 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 25 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 7.500 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) 1 1.900 75.3 75.3 73.4 73.4 20.000 4 3.700 66.3 66.3 62.6 62.6 23.000 8 5.300 61.8 61.8 56.5 56.5 24.500 10 5.900 60.3 60.3 54.4 54.4 25.000 16 7.500 57.2 57.2 49.7 49.7 25.000 20 8.400 55.8 55.8 47.3 47.3 25.000 25 9.500 54.3 54.3 44.9 44.9 24.300 31.25 10.600 52.9 52.9 42.2 42.2 23.600 62.5 15.400 48.4 48.4 33.0 33.0 21.500 Page 2 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1872A Multi-Conductor - Enhanced Category 6 Bonded-Pair Cable 100 19.800 45.3 45.3 25.5 25.5 21.000 155 25.100 42.4 42.4 17.3 17.3 21.000 200 29.000 40.8 40.8 11.8 11.8 21.000 250 32.800 39.3 39.3 6.5 6.5 18.000 300 36.400 38.1 38.1 1.7 1.7 18.000 350 39.800 37.1 37.1 -2.6 -2.6 17.000 400 43.000 36.3 36.3 14.000 450 46.000 35.5 35.5 14.000 500 48.900 34.8 34.8 14.000 550 51.800 34.2 34.2 14.000 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ACRF (dB) Min. PSACRF (dB) 1 100 ± 12 100 ± 15 67.8 64.8 4 100 ± 12 100 ± 15 55.7 52.8 8 100 ± 12 100 ± 15 49.7 46.7 10 100 ± 12 100 ± 15 47.8 44.8 16 100 ± 12 100 ± 8 43.7 40.7 20 100 ± 12 100 ± 8 41.8 38.8 25 100 ± 15 100 ± 8 39.8 36.8 31.25 100 ± 15 100 ± 8 37.9 34.9 62.5 100 ± 15 100 ± 8 31.8 28.9 100 100 ± 15 100 ± 8 27.8 24.8 155 100 ± 15 100 ± 8 24.0 21.0 200 100 ± 15 100 ± 8 21.7 18.8 250 100 ± 20 100 ± 8 19.8 16.8 300 100 ± 20 100 ± 8 18.3 15.3 350 100 ± 22 100 ± 8 16.9 13.9 400 100 ± 32 100 ± 8 15.8 12.8 450 100 ± 32 100 ± 8 14.7 11.7 500 100 ± 32 100 ± 8 13.8 10.8 550 100 ± 32 100 ± 8 13.0 10.0 Notes (Overall) Notes: Belden IBDN. Jacket sequentially marked at 2 ft. intervals. Values above 350 MHz are engineering information only. Third party verified to ANSI/TIA-568-C.2, Category 6. Put Ups and Colors: Item # Putup Ship Weight Color 1872A F6HA1000 1,000 FT 36.000 LB GRAY, DARK PEARL Notes Item Desc 1872A F6H1000 1,000 FT 34.000 LB GRAY, DARK PEARL 1872A X6GA1000 1,000 FT 36.000 LB GOLD X6G 1872A X6G1000 1,000 FT 34.000 LB GOLD X6G 1872A 002A1000 1,000 FT 36.000 LB RED 1872A 0021000 1,000 FT 34.000 LB RED 1872A 003A1000 1,000 FT 36.000 LB ORANGE 1872A 0031000 1,000 FT 34.000 LB ORANGE 1872A 004A1000 1,000 FT 36.000 LB YELLOW 1872A 0041000 1,000 FT 34.000 LB YELLOW 1872A 005A1000 1,000 FT 36.000 LB GREEN, DARK 1872A 0051000 1,000 FT 34.000 LB GREEN, DARK 1872A 006A1000 1,000 FT 36.000 LB BLUE, LIGHT 1872A 0061000 1,000 FT 34.000 LB BLUE, LIGHT 1872A 007A1000 1,000 FT 36.000 LB VIOLET 1872A 0071000 1,000 FT 34.000 LB VIOLET 1872A 009A1000 1,000 FT 36.000 LB WHITE 1872A 0091000 1,000 FT 34.000 LB WHITE C CAT6+ 4PRB U/UTP CMR REEL 1872A 0101000 1,000 FT 34.000 LB BLACK C CAT6+ 4PRB U/UTP CMR REEL CAT6+ 4PRB U/UTP CMR RIB C CAT6+ 4PRB U/UTP CMR REEL CAT6+ 4PRB U/UTP CMR RIB C CAT6+ 4PRB U/UTP CMR REEL CAT6+ 4PRB U/UTP CMR RIB C CAT6+ 4PRB U/UTP CMR REEL CAT6+ 4PRB U/UTP CMR RIB C CAT6+ 4PRB U/UTP CMR REEL CAT6+ 4PRB U/UTP CMR RIB C CAT6+ 4PRB U/UTP CMR REEL CAT6+ 4PRB U/UTP CMR RIB C CAT6+ 4PRB U/UTP CMR REEL CAT6+ 4PRB U/UTP CMR RIB C CAT6+ 4PRB U/UTP CMR REEL CAT6+ 4PRB U/UTP CMR RIB C CAT6+ 4PRB U/UTP CMR REEL CAT6+ 4PRB U/UTP CMR RIB Notes: C = CRATE REEL PUT-UP. Revision Number: 6 Revision Date: 06-09-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 3 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1872A Multi-Conductor - Enhanced Category 6 Bonded-Pair Cable All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 4 of 4 02-01-2017
1872A F6HA1000 价格&库存
很抱歉,暂时无法提供与“1872A F6HA1000”相匹配的价格&库存,您可以联系我们找货
