1883A 010U1000
1883A 010U1000
    BELDEN
    2 #24 PP FS FRPVC 1=1000'
1883A 010U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1883A Multi-Conductor - Single-Pair Cable For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (7x32) TC conductors, polypropylene insulation, twisted pair, overall Beldfoil shield (100% coverage), 24 AWG stranded TC drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 24 7x32 TC - Tinned Copper .024 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) PP - Polypropylene .040 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100.000 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.121 in. Pair Pair Color Code Chart: Number Color 1 Black & Red Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +60°C Bulk Cable Weight: 10 lbs/1000 ft. Max. Recommended Pulling Tension: 16 lbs. Min. Bend Radius/Minor Axis: 1.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1883A Multi-Conductor - Single-Pair Cable CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 52 Nom. Inductance: Inductance (µH/ft) .17 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 31 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 58 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 23.5 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 18.5 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2 Amps per conductor @ 25°C Notes (Overall) Notes: The jacket and shield are bonded so both can be removed on automatic stripping equipment. Drain wire is inside foil shield. For cross-connect use with 1408R (et. al.) Snake Cables. Put Ups and Colors: Item # Putup Ship Weight Color 1883A N3UN1000 1,000 FT 14.000 LB GREEN, MIL 2 #24 PP FS FRPVC 1883A N3UN2000 2,000 FT 24.000 LB GREEN, MIL 2 #24 PP FS FRPVC 1883A N3UU1000 1,000 FT 12.000 LB GREEN, MIL 2 #24 PP FS FRPVC 1883A N3U1000 1,000 FT 11.000 LB GREEN, MIL TRANSFER REVIEW (20 TO 30) 1883A 001N1000 1,000 FT 14.000 LB BROWN 2 #24 PP FS FRPVC 1883A 001U1000 1,000 FT 12.000 LB BROWN 2 #24 PP FS FRPVC 1883A 0011000 1,000 FT 11.000 LB BROWN 2 #24 PP FS FRPVC 1883A 002N1000 1,000 FT 14.000 LB RED 2 #24 PP FS FRPVC 1883A 002U1000 1,000 FT 12.000 LB RED 2 #24 PP FS FRPVC 1883A 0021000 1,000 FT 11.000 LB RED 2 #24 PP FS FRPVC 1883A 004N1000 1,000 FT 14.000 LB YELLOW 2 #24 PP FS FRPVC 1883A 004N2000 2,000 FT 24.000 LB YELLOW 2 #24 PP FS FRPVC 1883A 006N1000 1,000 FT 14.000 LB BLUE, LIGHT 2 #24 PP FS FRPVC 1883A 006N2000 2,000 FT 26.000 LB BLUE, LIGHT 2 #24 PP FS FRPVC 1883A 006U1000 1,000 FT 12.000 LB BLUE, LIGHT 2 #24 PP FS FRPVC 1883A 0061000 1,000 FT 11.000 LB BLUE, LIGHT 2 #24 PP FS FRPVC 1883A 007U1000 1,000 FT 12.000 LB VIOLET TRANSFER REVIEW (20 TO 30) 1883A 0071000 1,000 FT 11.000 LB VIOLET 2 #24 PP FS FRPVC 1883A 008N1000 1,000 FT 14.000 LB GRAY 2 #24 PP FS FRPVC Page 2 of 3 Notes Item Desc 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1883A Multi-Conductor - Single-Pair Cable 1883A 008U1000 1,000 FT 12.000 LB GRAY 2 #24 PP FS FRPVC 1883A 0081000 1,000 FT 11.000 LB GRAY 2 #24 PP FS FRPVC 1883A 009U1000 1,000 FT 12.000 LB WHITE TRANSFER REVIEW (20 TO 30) 1883A 0091000 1,000 FT 11.000 LB WHITE 2 #24 PP FS FRPVC 1883A 010N1000 1,000 FT 14.000 LB BLACK 2 #24 PP FS FRPVC 1883A 010U1000 1,000 FT 12.000 LB BLACK 2 #24 PP FS FRPVC 1883A 0101000 1,000 FT 11.000 LB BLACK 2 #24 PP FS FRPVC Revision Number: 2 Revision Date: 08-28-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
1883A 010U1000 价格&库存
很抱歉,暂时无法提供与“1883A 010U1000”相匹配的价格&库存,您可以联系我们找货
