3086A U3R1000
3086A U3R1000
    BELDEN
    CBL 1PR/20AWG 1PR/16AWG SH
3086A U3R1000 数据手册
Part Number: 3086A DeviceBus® for Honeywell System, (1 pr) 16 AWG (19x29) TC & (1 pr) 20 AWG (19x32) TC, PVC/PVC & FPE/PVC, Foil Shld, CL2 Product Description One 16 AWG pair stranded (19x29) tinned copper conductors and one 20 AWG pair stranded (19x32) tinned copper conductors, PVC insulation (power), foam polyethylene (FPE) insulation (data), individual Beldfoil® shield (100% coverage), PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding Material No. of Pairs 16 19x28 TC - Tinned Copper 1 20 19x32 TC - Tinned Copper 1 Conductor Count: 4 Total Number of Pairs: 2 AWG Size: 16 Insulation Element Material Nominal Wall Thickness 16 PVC - Polyvinyl Chloride 20 FPE - Foamed Polyethylene 0.0415 in 0.016 in Color Chart Number Color 1 (16 AWG) Blue & Brown 2 (20 AWG) Black & White Inner Shield Material Type Material Material Trade Name Coverage [%] Drainwire Material Tape Aluminum Foil-Polyester Tape Beldfoil® 100 % Outer Shield Material Material Drainwire Construction n x D Unshielded 19x32 mm Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.398 in 0.04 in Construction and Dimensions Stranding Lay Length 2 in Electrical Characteristics Conductor DCR Element Nominal Conductor DCR Nominal Outer Shield DCR 16 AWG 3.6 Ohm/1000ft 5.5 Ohm/1000ft Drainwire AWG TC - Tinned Copper 20 20 AWG 10 Ohm/1000ft Capacitance Element Nom. Capacitance Conductor to Conductor 20 AWG Pair Only 12 pF/ft Impedance Nominal Characteristic Impedance 120 Ohm 120 Ohm High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 0.125 MHz 0.18 dB/100ft 0.5 MHz 0.35 dB/100ft 1 MHz 0.47 dB/100ft Delay Nominal Velocity of Propagation (VP) [%] Nominal Velocity of Propagation (VP) Description 20 AWG Pair Only 76 % High Freq Element Frequency [MHz] Max./Min. Input Impedance (unFitted) 20 AWG Pair Only 0.125 MHz 120 Ohm 20 AWG Pair Only 0.5 MHz 1 MHz Current Element Max. Recommended Current [A] 16 AWG 7.0 Amps per Conductor 20 AWG 3.5 Amps Voltage UL Voltage Rating 300V RMS Temperature Range UL Temp Rating: 80°C Storage Temp Range: -40°C To +80 °C Operating Temp Range: -30°C To +80°C Mechanical Characteristics Bulk Cable Weight: 78.8 lbs/1000ft Max Recommended Pulling Tension: 121 lbs Min Bend Radius/Minor Axis: 4 in Standards NEC/(UL) Specification: CL2 UL AWM Style: 2464 CSA AWM Specification: AWM I/II A CPR Euroclass: Eca Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1685 UL Loading CSA Flammability: FT1 Part Number Plenum (Y/N): No Variants Item # Color Footnote 3086A U3R1000 GRAY U3R C 3086A U3R500 GRAY U3R C Footnote: C - CRATE REEL PUT-UP. Product Notes Notes: Mini-Cable (Trunk) © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
3086A U3R1000 价格&库存
很抱歉,暂时无法提供与“3086A U3R1000”相匹配的价格&库存,您可以联系我们找货
3086A U3R1000
  • 1000+66.976711000+8.67621
