70046LV.00100
70046LV.00100
    BELDEN
    BELDEN - 70046LV.00100 - Multipair Cable, Screened, 1 Pair, 2.5 mm², 328 ft, 100 m
70046LV.00100 数据手册
LSZH Speaker cables Product Bulletin PB00179 LSZH Speaker cables Belden Speaker cables use OFHC conductors offer Top Performance. Top range of speaker cables complying to the CPR Euroclass requirements up to B2ca. Belden LSZH OFHC Speaker cables answer the need for an CPR Euroclass rated, high-end speaker cable with distinct performance and installation benefits. Enhanced Sound Performance Construction details The copper conductors of Brilliance Low Cap OFHC Speaker cable have been manufactured using an upright shaft manufacturing process. The result of this process is a highconductivity copper conductor that is inherently free of impurities. The range of products consists of 2 x 1.5 mm2, 2 x 2.5mm2, 4 x 2.5mm2 and 2 x 4.0 mm2. These are available in CPR Euroclass ratings: Euroclass program The Euroclass program provides rankings based on the following criteria: Euroclasses are uniform assessment methods or classifications that reflect real-life environments for building products based on reactionto-fire performance. Based on the cable’s performance, it is placed into the Euroclass system that indicates its behavior during a fire. - B2ca-s1,d1,a1 - Cca-s1,d1,a1 - Dca-s2,d2,a1 • Contribution to expanding a fire (rating from “no contribution” to “high contribution,” with several levels in between) • Smoke production development (rating from “limited production” to “strong production”) • Burning falling particles/droplets (rating from “no” to “high”) • Class corrosiveness/acidity of combustion gases (ranging from “low corrosiveness” to “high corrosiveness”) © Copyright 2019, Belden Inc. www.beldensolutions.com www.belden.com Description Part No. Euroclass No. of Cond. Standard Lengths [m] Standard Diameter over Weight [kg] Insulation [mm] DC Resistance conductor [Ω/km] Nominal O.D. [mm] 1.5 mm2 Stranded (30 x 0.25mm2) Conductors | Oxygen-free Bare Copper | Conductors Cables LSZH Insulation | LSZH Jacket Red and Black cores 70045 Dca-s2,d2,a1 2 100 62.1 2.3 < 13 6.3 72.6 2.3 < 13 6.8 72.6 2.3 < 13 6.8 2.7
70046LV.00100 价格&库存
很抱歉,暂时无法提供与“70046LV.00100”相匹配的价格&库存,您可以联系我们找货
