7107W 003250
7107W 003250
    BELDEN
    CBL 18COND 20AWG HI FLEX
7107W 003250 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7107W Multi-Conductor - 300V C-TC+ Control Cables for Extreme Flexing For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (74x38) bare copper conductors, PVC insulation, Unshielded, Oil- and Abrasion-resistant PVC Jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 17 20 74x38 BC - Bare Copper Total Number of Conductors: 18 Ground Wire Ground Wire (Y/N): Y Ground Wire AWG: 20 Ground Wire Stranding: 74x38 Ground Wire Conductor Material: BC - Bare Copper Ground Wire Insulation Material: PVC - Polyvinyl Chloride Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride 0.015 Insulation Color Code Chart: Color Description Red Individually Numbered Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) TPE - Thermoplastic Elastomer 0.053 Overall Cable Overall Nominal Diameter: 0.480 in. Mechanical Characteristics (Overall) Operating Temperature Range: -50°C To +90°C Other Temperature Range: Flexing: -5°C To +90°C UL Temperature Rating: 90°C (UL AWM Style 2587) Bulk Cable Weight: 184 lbs/1000 ft. Max. Recommended Pulling Tension: 260 lbs. Min. Bend Radius (Continuous Flexing): 5.500 in. Flex Cycle Rating: 10 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: PLTC AWM Specification: UL Style 2587 (600 V 90°C), UL Style 21486 (1000 V 90°C) CSA Specification: AWM I/II A/B EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7107W Multi-Conductor - 300V C-TC+ Control Cables for Extreme Flexing EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes EU REACH SVHC Present: Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 FT4/IEEE 1202 Vertical Tray Flame Test CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Burial: Yes Sunlight Resistance: Yes Oil Resistance: Yes - Oil Res II Non-halogenated: No Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 8.8 Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7107W 0031000 1,000 FT 147.000 LB ORANGE C 17 #20 + GRD PVC TPE 7107W 003250 250 FT 47.500 LB ORANGE C 17 #20 + GRD PVC TPE 7107W 0035000 5,000 FT 765.000 LB ORANGE 17 #20 + GRD PVC TPE Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 10-02-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 01-05-2017
7107W 003250 价格&库存
很抱歉,暂时无法提供与“7107W 003250”相匹配的价格&库存,您可以联系我们找货
7107W 003250
  • 250+152.75555250+19.74528
