72002NH.02305
72002NH.02305
    BELDEN
    BELDEN - 72002NH.02305 - Networking Cable, DataTuff® Industrial Ethernet, LSZH, 2 Pair, Screened, Ca...
72002NH.02305 数据手册
Part Number: 72002NH INDUSTRIAL ETHERNET EUROPE Product Description DataTuff Industrial ETHERNET Cat 5e 2 Pair, 26 AWG, Overall Foil + 80% Braid, No Halogen Jacket, UL AWG 21286 Technical Specifications Product Overview Environmental Space: Indoor - Euroclass Eca Physical Characteristics (Overall) Conductor AWG Stranding 26 Stranded Material Construction n x D No. of Pairs BC - Bare Copper 7x0.16 mm 2 Conductor Count: 8 Total Number of Pairs: 4 Conductor Size: 26 AWG Insulation Material Nominal Diameter Diameter +/- Tolerance PP - Polypropylene 0.98 mm 0.05 mm Color Chart Number Color Pair 1 White/Blue & Blue Pair 2 White/Orange & Orange Outer Shield Material Type Material Min. Coverage [%] Tape Aluminum/Polyester Braid TC - Tinned Copper 80 % Note: Aluminum outside Outer Jacket Material Material Color Nominal Diameter Diameter +/- Tolerance Min. Wall Thickness Nominal Wall Thickness LSZH / FRNC (UV stabilised and oil resistant) Black 6 mm 0.3 mm Construction and Dimensions Min Elongation at Breakof Conductors: 10 % Min Elongation at Breakof Insulation: 100 % Cabling Description Filler 2 pairs and 2 fillers twisted to cable core covered with a polyester foil Polypropylene (2x) Min Elongation at Breakof Jacket: 100 % Min Tensile Strength of Jacket: 9 MPa Electrical Characteristics 0.8 mm 0.8 mm Conductor DCR Max. Conductor DCR Max. DCR Unbalanced Within Pair [%] 140 Ohm/km 2 Ohm Capacitance Max. Capacitance Unbalance Max. Mutual Capacitance 1.6 pF/m 56 pF/m Shielding: SF/UTP - Overall Braid + Foil Impedance Nominal Characteristic Impedance Nominal Characteristic Tolerance Nominal Input Impedance 100 Ohm 5 Ohm 100 +/- 15 Ohm Delay Max. Delay Skew Nominal Velocity of Propagation (VP) [%] 40 ns/100m 60 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) Min. NEXT [dB] Min. ACRF (ELFEXT) [dB] Min. RL (Return Loss) [dB] 0.772 MHz 67 dB 19.4 dB 1 MHz 3.2 dB/100m 65.3 dB 63.8 dB 20 dB 4 MHz 6 dB/100m 56.3 dB 51.8 dB 23 dB 10 MHz 9.5 dB/100m 50.3 dB 43.8 dB 25 dB 16 MHz 12.1 dB/100m 47.2 dB 39.7 dB 25 dB 20 MHz 13.6 dB/100m 45.8 dB 37.8 dB 25 dB 25 MHz 15.3 dB/100m 44.3 dB 35.8 dB 24.3 dB 31.25 MHz 17.1 dB/100m 42.9 dB 33.9 dB 23.6 dB 62.5 MHz 24.8 dB/100m 38.3 dB 27.9 dB 21.5 dB 100 MHz 32 dB/100m 35.3 dB 23.8 dB 20.1 dB Current Element Max. Recommended Current [A] Conductor 1.1 A Voltage Voltage Rating [V] 450 V DC and 300 V AC Temperature Range Installation Temp Range: -5°C To +50°C Operating Temp Range: -40°C To +80°C Mechanical Characteristics Oil Resistance: IEC 60811-2-1 Max Recommended Pulling Tension: 40 N Min Bend Radius (W/o Pulling Strength): 60 mm Min Setting Radius: 30 mm Standards ISO/IEC Compliance: ISO/IEC 11801 Ed. 2.2:2002/A2:2010/C1:2011 and ISO/IEC 24702 CPR Euroclass: Eca CENELEC Compliance: EN 50173-1 Ed. 3:2011 Data Category: Category 5e ANSI Compliance: ANSI/TIA/EIA 568-B.2-1 (2002) Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2016-01-06 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1-2 Amount of Halogen acc. to IEC 60754-1 & EN50267-1: Zero Part Number Variants Item # Color 72002NH.02305 Black 72002NH.02500 Black 72002NH.02B100 Black Patent: https://www.belden.com/resources/patents History Revision Number: 2 © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
72002NH.02305
1. 物料型号:72002NH 2. 器件简介:DataTuff工业以太网Cat 5e电缆,2对26 AWG,整体箔加80%编织屏蔽,无卤素护套,符合UL AWG 21286技术规格。 3. 引脚分配:4对导线,每对由7根0.16mm的裸铜线组成。 4. 参数特性: - 导体直流电阻(DCR)最大140欧姆/公里,不平衡对内最大2欧姆。 - 电容不平衡最大1.6pF/m,互电容最大56pF/m。 - 屏蔽:SF/UTP - 整体编织加箔。 - 特性阻抗100欧姆,输入阻抗100 +/- 15欧姆。 - 延迟差异最大40ns/100m,传播速度60%。 - 高频性能在不同频率下有详细的插入损耗、NEXT、ACRF(ELFEXT)和RL(Return Loss)数据。 5. 功能详解:适用于工业环境,具有优良的电气特性和机械特性,满足多种国际标准和环境认证。 6. 应用信息:适用于室内欧洲环境,符合ISO/IEC和ANSI标准,适用于Data Category 5e。 7. 封装信息:黑色LSZH/FRNC(UV稳定和耐油)护套,最小壁厚0.8mm,具有优良的耐化学性和耐磨性。
72002NH.02305 价格&库存
很抱歉,暂时无法提供与“72002NH.02305”相匹配的价格&库存,您可以联系我们找货
