Part Number: 74001E
DataTuff® Industrial Ethernet Cat 5e Permanent Installation Cable
Product Description
DataTuff Industrial ETHERNET, Cat5e 4PR, 1 Gb/s, AWG 24(1), Solid Conductor, Foil + 80% Braid, PVC jacket, UL AWM 2464
Technical Specifications
Product Overview
Environmental Space:
Indoor - Euroclass Eca
Physical Characteristics (Overall)
Conductor
AWG Stranding
24
Solid
Material
No. of Pairs
BC - Bare Copper 4
Conductor Count:
8
Total Number of Pairs:
4
Conductor Size:
24 AWG
Insulation
Material
Nominal Diameter Diameter +/- Tolerance
PP - Polypropylene 1.1 mm
0.05 mm
Color Chart
Number
Color
Pair 1
White/Blue & Blue
Pair 2
White/Orange & Orange
Pair 3
White/Green & Green
Pair 4
White/Brown & Brown
Outer Shield Material
Type
Material
Min. Coverage [%]
Tape Aluminum/Polyester
Braid TC - Tinned Copper 80 %
Note:
Aluminum outside
Outer Jacket Material
Material
PVC - Polyvinyl
Chloride
Color Nominal Diameter Diameter +/- Tolerance Min. Wall Thickness Nominal Wall Thickness
Black
7 mm
0.3 mm
Construction and Dimensions
Min Elongation at Breakof Conductors:
10 %
Min Elongation at Breakof Insulation:
100 %
Cabling
Description
4 pairs twisted to cable core covered with a polyester foil
Min Elongation at Breakof Jacket:
100 %
Min Tensile Strength of Jacket:
15 MPa
0.8 mm
0.8 mm
Electrical Characteristics
Conductor DCR
Max. Conductor DCR Max. Conductor Loop Max. DCR Unbalanced Within Pair [%]
93.8 Ohm/km
19 Ohm/1000ft
2 Ohm
Capacitance
Max. Capacitance Unbalance Max. Mutual Capacitance
1.6 pF/m
56 pF/m
Shielding:
SF/UTP - Overall Braid + Foil
Impedance
Nominal Characteristic Impedance Nominal Characteristic Tolerance Nominal Input Impedance
100 Ohm
5 Ohm
100 +/- 15 Ohm
Delay
Max. Delay Skew Nominal Velocity of Propagation (VP) [%]
40 ns/100m
60 %
Current
Element
Max. Recommended Current [A]
Conductor 1.4 A
Voltage
Voltage Rating [V]
450 V DC and 300 V AC
Temperature Range
Installation Temp Range:
-15°C To +60°C
Operating Temp Range:
-40°C To +80°C
Mechanical Characteristics
Oil Resistance:
IEC 60811-2-1
Max Recommended Pulling Tension:
80 N
Min Bend Radius (W/o Pulling Strength):
70 mm
Min Setting Radius:
35 mm
Standards
ISO/IEC Compliance:
ISO/IEC 11801 Ed. 2.2:2002/A2:2010/C1:2011 and ISO/IEC 24702
CPR Euroclass:
Eca
CENELEC Compliance:
EN 50173-1 Ed. 3:2011
Data Category:
Category 5e
ANSI Compliance:
ANSI/TIA/EIA 568-B.2-1 (2002)
Applicable Environmental and Other Programs
EU RoHS Compliance Date (yyyy-mm-dd):
2016-01-08
Suitability
Suitability - Sunlight Resistance:
Yes - Black only
Flammability, LS0H, Toxicity Testing
ISO/IEC Flammability:
Part Number
Variants
Item #
Color
74001E.012000 Black
74001E.01305
Black
74001E.01500
Black
74001E.01B100 Black
IEC 60332-1-2
Patent:
https://www.belden.com/resources/patents
History
Revision Number:
5
© 2018 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief
at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product
Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and
regulations based on their individual usage of the product.
很抱歉,暂时无法提供与“74001E.01305”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.080241+4.42960
- 50+27.0381550+3.51430
- 100+24.16915100+3.14140
- 305+21.30015305+2.76850
