Detailed Specifications & Technical Data
METRIC MEASUREMENT VERSION
76303WS Multi-Conductor - 300V Foil/Spiral Shield, Continuous Flexing Data Applications Up to 6 Million Flex Life Cycles
For more Information
please call
1-800-Belden1
General Description:
22 AWG stranded (19x34) tinned copper conductors, PVC insulation, Aluminum/Polyester Foil Shield,
Tinned copper spiral shield, 90% coverage, oil-resistant PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
3
22
19x34
TC - Tinned Copper
Insulation
Insulation Material:
Insulation Material
Wall Thickness (mm)
PVC - Polyvinyl Chloride 0.254
Insulation Color Code Chart:
Number Color
1
Black
2
Red
3
White
Outer Shield
Outer Shield Material:
Layer # Type Outer Shield Material Coverage (%)
1
Tape
2
Serve TC - Tinned Copper
Aluminum/Mylar
100.000
90.000
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (mm)
PVC - Polyvinyl Chloride 1.016
Overall Cable
Overall Nominal Diameter:
5.512 mm
Mechanical Characteristics (Overall)
Bulk Cable Weight:
50.599 Kg/Km
Max. Recommended Pulling Tension:
100.529 N
Min. Bend Radius/Minor Axis:
43.180 mm
Min. Bend/Installation:
43.180 mm
Min. Bend Radius (Continuous Flexing):
43.180 mm
Flex Cycle Rating:
6 Million Flexes
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CM
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
MII Order #39 (China RoHS):
Yes
Customer Part Number Reference Specification:
AWM/STYLE 10002, AWM/STYLE 2661, CSA AWM I/II A/B, EU Directive 2011/65/EU(RoHS2), REACH
Regulation (EC 1907/2006), California Proposition 65
Flame Test
CSA Flame Test:
FT4
Suitability
Suitability - Burial:
Yes
Electrical Characteristics (Overall)
Nom. Inductance:
Inductance (µH/m)
0.558
Page 1 of 2
10-02-2017
Nom. Capacitance Conductor to Conductor:
Freq. (MHz) Capacitance (pF/m)
0.001
124.678
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/km)
50.199
Nominal Outer Shield DC Resistance:
DCR @ 20°C (Ohm/km)
20.014
Max. Operating Voltage - UL:
Voltage
300V
Notes (Overall)
Notes: Temperature Range -10 to 105°C(static), +5 to 105°C (dynamic)
Put Ups and Colors:
Item #
Revision Number: 0
Putup
Ship Weight
Color
Notes
Item Desc
Revision Date: 09-27-2017
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Page 2 of 2
10-02-2017
很抱歉,暂时无法提供与“76303WS 008500”相匹配的价格&库存,您可以联系我们找货
