76601TS 008100
76601TS 008100
    BELDEN
    CBL 1PR 24AWG SHLD MACHFLEX
76601TS 008100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 76601TS Multi-Conductor - 300V Shielded, Continuous Flexing Data Applications Up to 6 Million FLex Life Cycles For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (10x34) tinned copper conductors, PVC insulation, aluminum/polyester foil shield, tinned copper braid shield, 85% coverage, oil-resistant overall PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 24 10x34 TC - Tinned Copper 0.024 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) PVC - Polyvinyl Chloride 0.010 0.044 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Foil Shield Alum/Mylar 100.000 Braid 85.000 Tinned Copper Outer Shield Drain Wire AWG: Component AWG Stranding Drain Wire Conductor Material Drain Wire 26 7x34 TC - Tinned Copper Outer Shield Separator Material: Tissue Tape, 25% Overlap, Min. Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.040 Overall Cable Overall Nominal Diameter: 0.204 in. Pair Pair Color Code Chart: Number Color 1 BLACK-RED Mechanical Characteristics (Overall) Bulk Cable Weight: 28 lbs/1000 ft. Max. Recommended Pulling Tension: 11.700 lbs. Min. Bend Radius/Minor Axis: 2 in. Min. Bend/Installation: 2 in. Min. Bend Radius (Continuous Flexing): 3.100 in. Flex Cycle Rating: 6 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM AWM Specification: UL Style 20006 CSA Specification: 600 V AWM I/II A/B EU Directive 2011/65/EU (ROHS II): Yes Other Specification: AWM/STYLE 10002, AWM/STYLE 2661, CM, AWM I/II A/B, C(UL) TYPE CMG, FT4, EU Low Voltage Directive 2014/35/EC, EU Directive 2011/65/EU(RoHS2) Flame Test CSA Flame Test: FT4 Suitability Sunlight Resistance: Yes Page 1 of 2 10-02-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 76601TS Multi-Conductor - 300V Shielded, Continuous Flexing Data Applications Up to 6 Million FLex Life Cycles Sunlight Resistance: Yes Electrical Characteristics (Overall) Nom. Characteristic Impedance: Description Impedance (Ohm) Characteristic Impedance 54.000 Nom. Inductance: Inductance (µH/ft) 0.190 Nom. Capacitance Cond. to Other Cond. & Ground: Description Freq. (kHz) Capacitance (pF/ft) Mutual Capacitance 1.000 35.000 Ground Capacitance 1.000 63.000 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 29.000 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.900 Notes (Overall) Notes: Temperature Range -10 to 105°C(static), +5 to 105°C (dynamic) Put Ups and Colors: Item # Revision Number: 0 Putup Ship Weight Color Notes Item Desc Revision Date: 09-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 10-02-2017
76601TS 008100 价格&库存
很抱歉,暂时无法提供与“76601TS 008100”相匹配的价格&库存,您可以联系我们找货
76601TS 008100
  • 100+18.66639100+2.42195
