77607W 010100
77607W 010100
    BELDEN
    CBL 7COND 16AWG HI FLEX
77607W 010100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 77607W Multi-Conductor - 600V Unshielded, Continous Flexing Applications Up to 14 Million Flex Life Cycles For more Information please call 1-800-Belden1 General Description: 16 AWG stranded (168x38) bare copper conductors, PVC insulation, oil-resistant overall PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material Dia. (in.) 6 16 168x38 BC - Bare Copper 0.067 Total Number of Conductors: 7 Ground Wire Ground Wire (Y/N): Y Ground Wire AWG: 16 Ground Wire Stranding: 168x38 Ground Wire Conductor Material: BC - Bare Copper Ground Wire Insulation Material: PVC - Polyvinyl Chloride Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) PVC - Polyvinyl Chloride 0.022 0.111 Insulation Color Code Chart: Color Description Red Individually Numbered Yellow/Green Ground Outer Shield Outer Shield Separator Material: Tissue Tape, 25% Overlap, Min. Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.040 Overall Cable Overall Nominal Diameter: 0.478 in. Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +90°C Installation Temperature Range: Flexing: -5°C To +90°C Operating Temperature Range: Flexing: -5°C To +90°C Bulk Cable Weight: 320 lbs/1000 ft. Max. Recommended Pulling Tension: 148 lbs. Min. Bend Radius/Minor Axis: 3.800 in. Min. Bend/Installation: 3.800 in. Min. Bend Radius (Continuous Flexing): 3.800 in. Flex Cycle Rating: 14 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: THHN/THWN Singles AWM Specification: UL Style 2587 (600 V 90°C) CSA Specification: 600 V AWM I/II A/B EU Directive 2011/65/EU (ROHS II): Yes Other Specification: AWM/STYLE 10012, AWM/STYLE 2587, AWM I/II A/B, FT1, VDE 0472, Section 803 Oil Test, EU Low Voltage Directive 2014/35/EC, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California Proposition 65 Page 1 of 2 10-02-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 77607W Multi-Conductor - 600V Unshielded, Continous Flexing Applications Up to 14 Million Flex Life Cycles Flame Test CSA Flame Test: FT1 Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) 0.180 Nom. Capacitance Cond. to Other Cond. & Ground: Description Freq. (kHz) Capacitance (pF/ft) Nom. Cond. to Cond 1.000 34.000 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.100 Put Ups and Colors: Item # Revision Number: 0 Putup Ship Weight Color Notes Item Desc Revision Date: 09-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 10-02-2017
77607W 010100
物料型号:BELDEN 77607W
器件简介: - 该电缆由16 AWG(美国线规)的裸铜导体组成,具有PVC绝缘和耐油的PVC整体护套。 - 导体为168x38的裸铜丝,直径为0.067英寸。 - 总共有7根导体,包括一根接地线。
引脚分配: - 绝缘材料为PVC,壁厚为0.022英寸,外径为0.111英寸。 - 绝缘颜色编码:红色为单独编号,绿色/白色为接地线。
参数特性: - 存储温度范围:-40°C至+90°C - 安装温度范围:-5°C至+90°C - 操作温度范围:-5°C至+90°C - 电缆重量:每1000英尺320磅 - 最大推荐拉力:148磅 - 最小弯曲半径(次轴):3.800英寸 - 连续弯曲寿命:可达1400万次
功能详解: - 电缆符合多种标准和环境计划,包括EC/(UL)规范THHN/THWN单线、WM规范UL Style 2587(600V 90°C)、SA规范600V AWM III A/B等。 - 符合欧盟RoHS II指令和REACH法规。
应用信息: - 该电缆适用于连续弯曲应用,具有高达1400万次的弯曲寿命。
封装信息: - 外护套材料为PVC,名义壁厚为0.040英寸。 - 电缆的整体名义直径为0.478英寸。
77607W 010100 价格&库存
很抱歉,暂时无法提供与“77607W 010100”相匹配的价格&库存,您可以联系我们找货
77607W 010100
  • 100+75.09372100+9.63158
