Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
7807A Coax - RG-58 Type
For more Information
please call
1-800-Belden1
General Description:
RG-58 type, 17 AWG solid .044" bare copper conductor, gas-injected foam HDPE insulation, Duofoil®
(100% coverage) + tinned copper braid shield (95% coverage), polyethylene jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material Dia. (in.)
1
17
Solid
BC - Bare Copper
.044
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
Gas-injected FHDPE - Foam High Density Polyethylene .116
Outer Shield
Outer Shield Material:
Layer # Outer Shield Trade Name Type Outer Shield Material
1
Duofoil®
2
Coverage (%)
Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100
Braid TC - Tinned Copper
95
Outer Jacket
Outer Jacket Material:
PE - Polyethylene
Overall Cable
Overall Nominal Diameter:
0.195 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +75°C
Non-UL Temperature Rating:
80°C
Bulk Cable Weight:
27 lbs/1000 ft.
Max. Recommended Pulling Tension:
25.400 lbs.
Min. Bend Radius/Minor Axis:
2 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
58/U
Series Type:
RF 200
Suitability
Plenum/Non-Plenum
Plenum (Y/N):
No
Page 1 of 3
01-05-2017
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
.061
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
23.5
Nominal Velocity of Propagation:
VP (%)
85
Nominal Delay:
Delay (ns/ft)
1.19
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
3.3
Nominal Outer Shield DC Resistance:
4.2
Maximum VSWR:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR
5
6000
1.25:1
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
5.000
0.750
10.000
1.100
30.000
1.600
50.000
2.100
150.000
3.700
220.000
4.500
450.000
6.500
900.000
9.200
1500.000
12.000
1800.000
13.200
2000.000
14.000
2500.000
15.700
3000.000
17.500
4500.000
22.000
5800.000
25.200
6000.000
26.000
Max. Power Rating:
Freq. (MHz) Rating (W)
30
1070
50
813
150
450
220
372
450
256
900
178
1500
136
1800
123
2000
117
2500
104
3000
94
3500
87
4500
76
5800
67
6000
66
Max. Operating Voltage - Non-UL:
Voltage
Page 2 of 3
01-05-2017
300 V RMS
Sweep Test
Sweep Testing:
100% Sweep tested to 6 GHz
Notes (Overall)
Notes: Belden® The Wire in Wireless®
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
7807A 0101000
1,000 FT
26.000 LB
BLACK
C
RF200 WIRELESS 50 OHM COAX PO
7807A 010500
500 FT
15.000 LB
BLACK
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 3
Revision Date: 07-19-2013
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“7807A 010500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+16.89245500+2.18549
