Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
7810WB Coax - RG-8 Type
For more Information
please call
1-800-Belden1
General Description:
RG-8 type, 10 AWG solid .108" bare copper-covered aluminum conductor, gas-injected foam HDPE
insulation, Duobond® II + tinned copper braid shield (95% coverage), flooded water-resistant polyethylene
jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
10
Solid
Dia. (in.)
BCCA - Bare Copper Covered Aluminum .108
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
Gas-injected FHDPE - Foam High Density Polyethylene .285
Outer Shield
Outer Shield Material:
Layer # Outer Shield Trade Name Type Outer Shield Material
1
Bonded Duofoil®
2
Coverage (%)
Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100
Braid TC - Tinned Copper
Outer Shield Flooding Grease:
95
PO - Polyolefin
Outer Jacket
Outer Jacket Material:
PE - Polyethylene
Overall Cable
Overall Nominal Diameter:
0.403 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +75°C
Non-UL Temperature Rating:
80°C
Bulk Cable Weight:
73 lbs/1000 ft.
Max. Recommended Pulling Tension:
150 lbs.
Min. Bend Radius/Minor Axis:
4 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
8/U
Series Type:
RF 400
Page 1 of 3
01-05-2017
Suitability
Suitability - Outdoor:
Yes
Suitability - Aerial:
Yes - When supported by a messenger
Suitability - Burial:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
0.060
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
23.0
Nominal Velocity of Propagation:
VP (%)
86
Nominal Delay:
Delay (ns/ft)
1.17
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
1.34
Nominal Outer Shield DC Resistance:
2
Maximum VSWR:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Max. VSWR
5
6000
1.25:1
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
30
0.7
50
0.9
150
1.5
220
1.8
450
2.7
900
3.8
1500
5.1
1800
5.6
2000
6.0
2500
6.7
3000
7.5
3500
8.2
4500
9.5
5800
11.1
6000
11.4
Max. Power Rating:
Freq. (MHz) Rating (W)
30
3427
50
2588
150
1428
220
1195
450
817
900
575
1500
437
1800
399
2000
375
2500
334
3000
305
Page 2 of 3
01-05-2017
3500
282
4500
247
5800
217
6000
213
Max. Operating Voltage - Non-UL:
Voltage
300 V RMS
Sweep Test
Sweep Testing:
100% Sweep tested to 6 GHz.
Misc. Information (Overall)
Notes (Overall)
Notes: 100% Sweep tested. 6 GHz. Belden® The Wire in Wireless®
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
7810WB 0101000
1,000 FT
82.000 LB
BLACK
C
RF400 WIRELESS 50 OHM COAX WB
7810WB 010500
500 FT
40.500 LB
BLACK
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 4
Revision Date: 10-17-2012
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“7810WB 010500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+35.76278500+4.62728
