7911A N3U1000
7911A N3U1000
    BELDEN
    COMPOSITE CABLE FRPVC PARA
7911A N3U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7911A Composite - Composite Data, Audio, Video, Security and Control Cable For more Information please call 1-800-Belden1 General Description: Siamese Composite - (1) Cat 5e 4-bonded-pair 24 AWG unshielded plus (1) Series 6 Coax with Duobond Plus® Bonded Tri-shield, polyolefin insulation on the pairs; Gas-injected FPE Insulation on the coax, overall F-R PVC jacket. Usage (Overall) Suitable Applications: HDTV, DBS, CATV, CCTV, Multimedia, Voice, Video, Data, High Speed Internet, Networked Computing, Distributed Video, Distributed Audio, Security Monitoring, Energy Monitoring Coax Physical Characteristics Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 18 Solid BC - Bare Copper 0.040 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FPE - Foam Polyethylene 0.180 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material % Coverage (%) 1 Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 2 Braid AL - Aluminum 77 3 Tape Bonded Aluminum Foil-Polyester Tape w/Shorting Fold 100 Bonded Duofoil® Electrical Characteristics Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.097 Maximum Capacitance Conductor to Shield: Capacitance (pF/ft) 16.200 Nominal Velocity of Propagation: VP (%) 83.000 Nominal Delay: Delay (ns/ft) 1.200 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.400 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.600 Minimum Structural Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5.000 1000.000 20.000 1000.000 2250.000 15.000 2250.000 3000.000 10.000 Nom. Attenuation: Page 1 of 4 01-09-2015 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7911A Composite - Composite Data, Audio, Video, Security and Control Cable Freq. (MHz) Attenuation (dB/100 ft.) 5.000 0.500 55.000 1.400 211.000 2.600 500.000 4.100 750.000 5.100 862.000 5.500 1000.000 6.000 1450.000 7.800 1800.000 8.600 2250.000 9.800 3000.000 11.300 Max. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 5.000 0.670 55.000 1.600 211.000 2.870 500.000 4.480 750.000 5.590 862.000 5.980 1000.000 6.540 1450.000 8.000 1800.000 8.800 2250.000 10.000 3000.000 11.900 Max. Operating Voltage - UL: 300 V RMS Shield Effectiveness: Start Frequency (MHz) Stop Frequency (MHz) Shield Effectiveness (dB) 5.000 50.000 105.000 50.000 1000.000 125.000 Twisted Pair Physical Characteristics Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 4 24 Solid BC - Bare Copper 0.020 Insulation Insulation Material: Insulation Material Dia. (in.) PO - Polyolefin 0.035 Twisted Pair Color Code Chart: Number Color 1 White/Blue Stripe and Blue 2 White/Orange Stripe and Orange 3 White/Green Stripe and Green 4 White/Brown Stripe and Brown Electrical Characteristics Nom. Mutual Capacitance: Capacitance (pF/ft) 15.000 Nominal Velocity of Propagation: VP (%) 70.000 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.380 Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: Third party verified to TIA/EIA-568-B.2, Category 5E Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. PSNEXT (dB) Min. PSACR (dB) Min RL (dB) Page 2 of 4 01-09-2015 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7911A Composite - Composite Data, Audio, Video, Security and Control Cable 1.0 2.000 62.3 60 20.000 4.0 4.100 53.3 49 23.000 8.0 5.800 48.8 43 24.500 10.0 6.500 47.3 41 25.000 16.0 8.200 44.3 36 25.000 20.0 9.300 42.8 34 25.000 25.0 10.400 41.3 31 24.300 31.25 11.700 39.9 28 23.600 62.5 17.000 35.4 19 21.500 100 22.000 32.3 11 20.100 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Min. PSELFEXT (dB) 1.0 100 +/- 15% 60.8 4.0 100 +/- 15% 48.7 8.0 100 +/- 15% 42.7 10.0 100 +/- 15% 40.8 16.0 100 +/- 15% 36.7 20.0 100 +/- 15% 34.7 25.0 100 +/- 15% 32.8 31.25 100 +/- 15% 30.9 62.5 100 +/- 15% 24.8 100 100 +/- 15% 20.8 Physical Characteristics (Overall) Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material F-R PVC - Flame Retardant Polyvinyl Chloride Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.278 x 0.529 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 50.000 lbs/1000 ft. Max. Recommended Pulling Tension: 131.000 lbs. Min. Bend Radius/Minor Axis: 3.000 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: NEMA WC-63.1, Category 5e Applicable Patents: Country www.belden.com/p Page 3 of 4 01-09-2015 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7911A Composite - Composite Data, Audio, Video, Security and Control Cable Flame Test UL Flame Test: UL1666 Riser CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Notes (Overall) Notes: OVerall jacket sequentially marked. Put Ups and Colors: Item # Revision Number: 0 Putup Ship Weight Color Notes Item Desc Revision Date: 03-10-2014 © 2015 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 4 of 4 01-09-2015
7911A N3U1000 价格&库存
很抱歉,暂时无法提供与“7911A N3U1000”相匹配的价格&库存,您可以联系我们找货
