82240 877U500
82240 877U500
    BELDEN
    #20 FEP RG58/U FLMRST
82240 877U500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82240 Coax - RG-58/U Type For more Information please call 1-800-Belden1 General Description: RG-58/U type, 20 AWG solid .032" bare copper conductor, plenum, FEP teflon insulation, tinned copper braid shield (95% coverage), Flamarrest® jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 20 Solid BC - Bare Copper .032 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Trade Name Insulation Material Teflon® Dia. (in.) FEP - Fluorinated Ethylene Propylene .107 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® LS PVC - Low Smoke Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.159 in. Mechanical Characteristics (Overall) Operating Temperature Range: 0°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 24 lbs/1000 ft. Max. Recommended Pulling Tension: 47 lbs. Min. Bend Radius/Minor Axis: 1.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 58/U Flame Test UL Flame Test: NFPA 262 Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82240 Coax - RG-58/U Type CSA Flame Test: FT6 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 8240 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 53 Nom. Inductance: Inductance (µH/ft) 0.070 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 26.4 Nominal Velocity of Propagation: VP (%) 69.5 Nominal Delay: Delay (ns/ft) 1.48 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10.2 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.7 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.5 10 1.2 50 3.0 100 4.3 200 6.4 400 9.7 700 13.7 900 16.1 1000 17.3 Nom. Power Rating: Freq. (MHz) Rating (W) 1 4798.7 10 1937.2 50 782.4 100 542.2 200 370.3 400 248.5 700 177.7 900 153.0 1000 143.2 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Operating Voltage - Non-UL: Voltage 1400 V RMS Notes (Overall) Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc. Put Ups and Colors: Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82240 Coax - RG-58/U Type Item # Putup Ship Weight Color 82240 010U500 500 FT 13.500 LB BLACK Notes Item Desc #20 FEP RG58/U FLMRST 82240 877U1000 1,000 FT 26.000 LB NATURAL #20 FEP RG58/U FLMRST 82240 877U500 500 FT 13.500 LB NATURAL 82240 8771000 1,000 FT 26.000 LB NATURAL #20 FEP RG58/U FLMRST C #20 FEP RG-58/U FLMRST Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-27-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
82240 877U500 价格&库存
很抱歉,暂时无法提供与“82240 877U500”相匹配的价格&库存,您可以联系我们找货
