Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
8233 Coax - RG-11/U Type
For more Information
please call
1-800-Belden1
General Description:
14 AWG solid .064" bare copper conductor, gas-injected foam HDPE insulation, bare copper double
shields (95% and 80% coverage), polyethylene jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material Dia. (in.)
1
14
Solid
BC - Bare Copper
.064
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
Gas-injected FHDPE - Foam High Density Polyethylene .285
Inner Shield
Inner Shield Material:
Type Inner Shield Material Coverage (%)
Braid BC - Bare Copper
95
Inner Jacket
Inner Jacket Material:
Inner Jacket Material Nom. Dia. (in.)
PE - Polyethylene
.365
Outer Shield
Outer Shield Material:
Type Outer Shield Material Coverage (%)
80
Outer Jacket
Outer Jacket Material:
PE - Polyethylene
Overall Cable
Overall Nominal Diameter:
0.475 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-55°C To +80°C
Non-UL Temperature Rating:
80°C
Bulk Cable Weight:
112 lbs/1000 ft.
Max. Recommended Pulling Tension:
170 lbs.
Min. Bend Radius/Minor Axis:
5 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
Page 1 of 3
01-05-2017
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
11/U
Suitability
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes
Suitability - Aerial:
Yes, when supported by a messenger wire
Suitability - Burial:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
75
Nom. Inductance:
Inductance (µH/ft)
0.097
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
16.1
Nominal Velocity of Propagation:
VP (%)
84
Nominal Delay:
Delay (ns/ft)
1.20
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
2.600
Nom. Inner Shield DC Resistance:
1.700
Nominal Outer Shield DC Resistance:
1.500
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1.000
0.140
3.600
0.300
10.000
0.400
71.500
1.100
135.000
1.600
270.000
2.300
360.000
2.600
540.000
3.300
720.000
3.800
750.000
4.000
1000.000
4.600
1500.000
5.900
2250.000
7.400
3000.000
9.000
4500.000
12.500
Max. Operating Voltage - Non-UL:
Voltage
300 V RMS
Minimum Return Loss:
Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB)
5.000
850.000
21.000
850.000
4500.000
15.000
Page 2 of 3
01-05-2017
Sweep Test
Sweep Testing:
100% Sweep tested 5 MHz to 4.5 GHz.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
8233 0101000
1,000 FT
119.000 LB
BLACK
C
RG-11/U TYPE TRIAX
8233 0102000
2,000 FT
240.000 LB
BLACK
C
RG-11/U TYPE TRIAX
8233 010500
500 FT
63.000 LB
BLACK
C
RG-11/U TYPE TRIAX
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 3
Revision Date: 06-26-2013
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“8233 010500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+43.38373500+5.59662
