Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
83900 Multi-Conductor - High-Temperature Thermocouple Wire
For more Information
please call
1-800-Belden1
General Description:
20 AWG solid conductors, FEP insulation, unshielded, FEP jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
Solid
Iron
1
Solid
Constantan
Total Number of Conductors:
2
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
FEP - Fluorinated Ethylene Propylene .010
Outer Shield
Outer Shield Material:
Unshielded
Outer Jacket
Outer Jacket Material:
Overall Cable
Overall Nominal Diameter:
0.076 x 0.128 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-70°C To +200°C
Non-UL Temperature Rating:
200°C
Bulk Cable Weight:
13 lbs/1000 ft.
Min. Bend Radius/Minor Axis:
1.250 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
PLTC, CL3P
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
ANSI Specification:
MC 96.1-1982 Type J
Flame Test
UL Flame Test:
UL910 Steiner Tunnel
Plenum/Non-Plenum
Plenum (Y/N):
Yes
Page 1 of 2
01-05-2017
Surface Printing (Overall)
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
Description
DCR @ 20°C (Ohm/1000 ft)
IRON
62
CONSTANTAN 308
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
83900 001100
100 FT
2.000 LB
BROWN
83900 0011000
1,000 FT
14.000 LB
BROWN
83900 001500
500 FT
7.000 LB
BROWN
Notes
Item Desc
2#20 TYPE J THERMOCOUPLE
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 06-29-2011
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
01-05-2017
很抱歉,暂时无法提供与“83900 0011000”相匹配的价格&库存,您可以联系我们找货
