8416 008250
8416 008250
    BELDEN
    2 SH CONDRS PARALLEL PVC
8416 008250 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8416 Coax - Dual Channel Audio Cable For more Information please call 1-800-Belden1 General Description: Dual Channel, 25 AWG stranded (7x33), (3) TC, (4) TCCS, polyethylene insulation, individual TC spiral wrapped shield (90% coverage), PVC jacket, polarity rib on red conductor. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 2 25 7x33 Dia. (in.) TC/TCCS -Tinned Copper/Tinned Copper Covered Steel .021 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) PE - Polyethylene 0.058 Insulation Resistance: Red, Natural Insulation Color Code Chart: Number Color 1 Red 2 Natural Inner Shield Inner Shield Material: Type Inner Shield Material Coverage (%) Spiral Serve TC - Tinned Copper 90 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.106 x 0.213 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 16 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8416 Coax - Dual Channel Audio Cable MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 44 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 36 Max. Operating Voltage - Non-UL: Voltage 90 V RMS Notes (Overall) Notes: For use with head sets, stereo and language labs. Put Ups and Colors: Item # Putup Ship Weight Color 8416 008250 250 FT 4.750 LB GRAY Revision Number: 1 Notes Item Desc 2 SH CONDRS PARALLEL PVC Revision Date: 10-02-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
8416 008250 价格&库存
很抱歉,暂时无法提供与“8416 008250”相匹配的价格&库存,您可以联系我们找货
