8452 010250
8452 010250
    BELDEN
    BELDEN - 8452 010250 - UNSHIELDED MULTICONDUCTOR CABLE 2 CONDUCTOR 18AWG 250FT
8452 010250 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8452 Portable Cordage - UL/CSA Types: STOW, SV, SVT For more Information please call 1-800-Belden1 General Description: SV rubber jacket, 300V, 60ºC, cotton serve separator, serrated jacket, UL/CSA listed, color code: black, white. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 2 18 42x34 BC - Bare Copper Total Number of Conductors: 2 Type of Cordage: SV Insulation Insulation Material: Insulation Material Wall Thickness (in.) Rubber .017 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) Rubber .037 Overall Cable Overall Cabling Fillers: Jute Overall Cabling Color Code Chart: Color Black White Overall Cabling Separator Material: Cotton Serve Overall Nominal Diameter: 0.245 in. Mechanical Characteristics (Overall) UL Temperature Rating: 60°C Bulk Cable Weight: 34 lbs/1000 ft. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: SV CSA Specification: SV EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/13/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8452 Portable Cordage - UL/CSA Types: STOW, SV, SVT CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test CSA Flame Test: FT2 Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 10 Amps per conductor @ 25°C 7 Amps per conductor @ 25°C over 50 ft. Dielectric Withstand Voltage: 1500 V AC Applied For 1 Min. Notes (Overall) Notes: Jacket Finish: Serrated (45 Serrations - 8 Degrees Apart) Put Ups and Colors: Item # Putup Ship Weight Color 8452 010U500 500 FT 19.000 LB BLACK 8452 0101000 1,000 FT 38.000 LB BLACK 8452 010250 250 FT 9.500 LB BLACK 8452 010500 500 FT 19.000 LB BLACK Notes Item Desc 2#18 EPDM CS SBR TYPE SV C 2#18 EPDM CS SBR TYPE SV 2#18 EPDM CS SBR TYPE SV C 2#18 EPDM CS SBR TYPE SV Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 11-06-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
8452 010250 价格&库存
很抱歉,暂时无法提供与“8452 010250”相匹配的价格&库存,您可以联系我们找货
